Old Sat, Oct-22-2016, 02:44:40 PM   #1
HassanEido
HassanEido's Avatar
Lebanon
Default Main bearings
So whats the consensus on main bearings? Ive done my rod bearings @130k miles, now 25k miles later i'm regretting I didnt do the mains as well...so your thoughts guys
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Sat, Oct-22-2016, 04:05:12 PM   #2
cyberlando
cyberlando's Avatar
Default Re: Main bearings
In for answers.......I noticed also thatq everyone is always talking about rod bearings and not main bearings.
On my engine rebuild to me it seems like the mains are just as susceptible to wear as the rods
Sent from my SM-G935F using Tapatalk
Engine:
Interior:
Suspension/Handling:
Old Sat, Oct-22-2016, 04:26:38 PM   #3
ThunderMoose
I did mains on my spare. Rod bearings were showing copper but mains were in near perfect shape. I am not sure how long they should last but I don't plan to do these on my primary engine unless I pull for complete rebuild.
#67 2017 NASA TX TT3 Champion
Discussing Main bearings in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
