Old Thu, Mar-15-2018, 01:15:52 AM   #71
Exclusivs
Exclusivs's Avatar
Reputation: 0 Exclusivs is on a distinguished road
Default Re: S54 Vanos Info Thread
Extremely great thread, thank you for taking time compile this together.
Jump to top Exclusivs is offline   Reply With Quote
Old Sun, Mar-18-2018, 05:47:14 AM   #72
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Welcome...
Old Sat, Mar-31-2018, 08:45:18 PM   #73
RynoS54
wuuut wuuuuuut
RynoS54's Avatar
Reputation: 0 RynoS54 is on a distinguished road
Great thread....where can we find the plastic spacers for pre-loading?
CB/GREYandotherstuffs
Jump to top RynoS54 is offline   Reply With Quote
Old Sun, Apr-01-2018, 01:00:13 AM   #74
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Default S54 Vanos Info Thread
Thanks. Most of the timing kits come with them. You could easily make some if you knew the thickness. I can measure mine for you when I get home.
ECSTUNING has them for $20.
https://www.ecstuning.com/b-genuine-...r/83300493838/
Old Sun, Apr-01-2018, 02:20:28 AM   #75
RynoS54
wuuut wuuuuuut
RynoS54's Avatar
thanks again man!
Old Sun, Apr-01-2018, 03:03:28 AM   #76
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
You bet...
M3 S54 Vanos DIY
http://m3support.net/thread/60/e46-m3-vanos-diy
Old Mon, Sep-17-2018, 04:20:56 AM   #77
ftapache
ftapache's Avatar
Reputation: 0 ftapache is on a distinguished road
[CENTER]
Member Dave (Dafoe) stated that you can use the Turbo Toy hub with the Beisan oil pump disk. The Beisan oil pump disk has 4 holes. 2 small holes which would be used with the OEM hub and 2 holes in the regular size that you can use the Turbo Toy hub with.
SWEET! That's good to know that you can double up. Do it once. Cry once.
Revival Journal
Jump to top ftapache is offline   Reply With Quote
Old Mon, Sep-17-2018, 04:34:44 AM   #78
mrgizmo04
mrgizmo04's Avatar
To clarify, you either use your oil pump disc with original holes with turbo toy hub (which has slightly larger tabs), or you use a redrilled disc with smaller holes and original hub. You don't really double up. The main problem you are solving is that original oil pump disc holes are slightly too large for original hub tabs. So you can either put larger tabs in it (turbotoy) or use smaller holes. Hope this makes sense.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Mon, Sep-17-2018, 05:24:19 AM   #79
hogger453
hogger453's Avatar
Reputation: 0 hogger453 is on a distinguished road
Bulgaria
Been there, done that, a long time ago.
Two possibilities exist:
Either we are alone in the universe or we are not.
Both are equally terrifying.
Arthur C. Clarke
Jump to top hogger453 is offline   Reply With Quote
Old Mon, Sep-17-2018, 06:24:48 AM   #80
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Yep that is correct.
2 small holes which would be used with the OEM hub.
2 regular size holes that you can use the Turbo Toy hub.
If your exhaust hub is ok (No tabs broken) get the Beisan oil pump disc with the smaller holes.
If the exhaust hub tabs are broken get the TT Hub and reuse the stock oil pump disc. That is if it's not completely mangled.
beisan, turbo toy, vanos
Discussing S54 Vanos Info Thread in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
