Old Sun, Mar-13-2011, 04:10:42 AM   #31
IHatePosers
Long Live M3
IHatePosers's Avatar
Reputation: 0 IHatePosers is on a distinguished road
Default Re: The cooling system thread - overhaul DIY
great write up! just used this today to -
-replace clutch fan
-replace upper/lower radiator hoses
-radiator
-water pump
-temperature sensor
Just a heads up regarding the pulleys and belts.
To remove the belts and to put them on - there is a torx located on the pulley to the bottom right of the water pump pulley. Using a LARGE torx (don't remember measurement) will allow you to relieve the tension in the belts and let you put them on easier!
Thanks again for this DIY!
2018 Dodge Durango GT
Originally Posted by Official 2014 Formula 1 Game View Post
Ihateposers says,"ttylkthxbai"
Jump to top IHatePosers is offline   Reply With Quote
Old Sun, Mar-13-2011, 05:24:23 AM   #32
Fastdog911
Fastdog911's Avatar
Reputation: 0 Fastdog911 has disabled reputation
could you have sent the radiator out to be cleaned vs replaced? I don't know if that can be done etc...
[IMG]2002 SMG, Topaz Blue, BHS pulleys, all options. UUC Exhaust, GC Sway bars, SS lines, BHP Pads F1 paddles, GSP brake pedal, Huber Optik 20%, Iforged rims and a bunch of other things.. Sold
1970 911T Tangerine
1972 911T Albert Blue
1970 911E Ossi Blue
Jump to top Fastdog911 is offline   Reply With Quote
Old Sun, Mar-13-2011, 08:20:51 AM   #33
lax01
lax01's Avatar
Reputation: 0 lax01 will become famous soon enough
The common fear on the boards is that the plastic end-tanks will begin to leak and fail after a certain amount of time so its not a matter of it being clean...but just that it is getting old and needs to be replaced. Anyways, the OEM radiator isn't THAT expensive...
-Josh
2017 BMW M2 Performance Edition
2004 Porsche GT3 - sold
2002 M3 Carbon Black - sold
2012 Ducati Streetfigher 848 - sold
Jump to top lax01 is offline   Reply With Quote
Old Sun, Mar-13-2011, 09:55:59 AM   #34
Yeah, BMW radiators have a LONG history of failure, and a new one is only $150. Makes sense to replace it to me!
Old Sun, Mar-13-2011, 03:04:34 PM   #35
IHatePosers
Long Live M3
ian - where are you seeing $150?
i paid $298 for mine from Bimmerworld. Tischer is slightly higher.
please let me know!!! thanks
Old Sun, Mar-13-2011, 03:24:02 PM   #36
337
Frenchie
337's Avatar
Reputation: 0 337 is on a distinguished road
Pelican has it for 287$. Curious as well.
Jump to top 337 is offline   Reply With Quote
Old Sun, Mar-13-2011, 03:24:35 PM   #37
Hmm, looks like prices have gone up since I did it!
I think this is still the cheapest way to do it, though:
http://www.turnermotorsport.com/p-21...or-e46-m3.aspx
Old Sun, Mar-13-2011, 03:30:02 PM   #38
IHatePosers
Long Live M3
oem radiator alone = $313
http://www.turnermotorsport.com/p-13...-radiator.aspx
oem radiator alone from forum sponsor bimmerworld = $289.99
http://store.bimmerworld.com/oem-rep...ators-p36.aspx
i remember people talking about the mishimoto but saying that the openings on the radiator were not in the right places - see that hard to be since the hoses have some flex in them, but I can understand.
wish there were a cheaper alternative.
Old Sun, Mar-13-2011, 03:52:37 PM   #39
Is turner no longer a sponsor on here? The rad alone may be cheaper, but if you're doing the cooling system, buying it piece by piece is more expensive, more work, and you might miss something (random o-ring, etc).
Old Sun, Mar-13-2011, 03:56:24 PM   #40
BlazenXLT
We've had one yes, what about second breakfast?
BlazenXLT's Avatar
Reputation: 0 BlazenXLT is on a distinguished road
Like Ian pointed out, I think the TMS package is one of the best ways to replace the whole system.
On the topic of radiator longevity, mine actually looked to be in good condition when I removed it, aside from being dirty. I have a feeling the the life span of plastic and rubber components are significantly increased when the car is garage kept. In the end, I would still always recommend replacing it a little early. The chance of damaging something more expensive is not worth the risk.
Jump to top BlazenXLT is offline   Reply With Quote
Discussing The cooling system thread - overhaul DIY in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
