Old Thu, Aug-16-2007, 01:18:18 PM   #1
jav1
jav1's Avatar
Reputation: 0 jav1 is on a distinguished road
Default E46 maintenance / DIY support ?
I've always loved the E46 M3 and with prices down, I'm tempted to get one to replace an older Porsche that the kids don't fit into any more. This would be more of a toy than a daily driver since I log a lot of miles (my daily driver is an '03 jetta TDi with close to 150K). Within my budget, it looks like an '01-03 would be the ticket and other than the 100k engine ext. war. , I'd likely be on my own for maintenance and repairs. Normally, this wouldn't be a concern as I'm very intimate with a wrench but I'm wondering how much of a burden this would be with an E46 M3? Are there guys doing DIY service? Is DIY service very difficult without special BMW tools? Is the M3 very service intensive?
Any insights would be appreciated.
Jump to top jav1 is offline   Reply With Quote
Old Thu, Aug-16-2007, 01:39:04 PM   #2
It's a very easy car to DIY, though nothing beats of a porsche for that (well, maybe really old american cars).
Most of the time you're fine with common tools. There are a few specific jobs that require specific tools. For general maintenance you'll need a shim kit from BMW (car needs a valve job on inspections) and one time you'll need an RTAB tool
Other than that, unless you break something unusual, everything is pretty straight forward and easy to work on. The only reason I ever go to any sort of shop anymore is
state inspection
tire mounting
alignment and corner balancing
Old Thu, Aug-16-2007, 02:16:26 PM   #3
Pujel
Pujel's Avatar
Reputation: 0 Pujel is on a distinguished road
German cars (like German guns) go together and come apart so easily IMO. Very user friendly. They come up with some nifty ways of attaching things without lots of little nuts and bolts to lose. If you're mechanically inclined, I think you would enjoy working on the car.
2002 M3 SMG
All stock for now... unless you consider OEM front strut brace on an 02 a mod...
...In which case you'll really like my sunroof shade delete....
...and my titanium shadow "crackle" effect on passenger door handle...
Jump to top Pujel is offline   Reply With Quote
Old Thu, Aug-16-2007, 02:24:38 PM   #4
lmtfi
lmtfi's Avatar
Join your local BMWCCA chapter. Many have DIY weekend days at BMW dealers and indy shops where you can get advice and use of their tools.
Old Thu, Aug-16-2007, 02:24:39 PM   #5
spta97
spta97's Avatar
Reputation: 0 spta97 has disabled reputation
Once you figure it out. They are a far cry from a Japanese car that only requires a 10mm socket and #2 phillips screw driver to dismantle
This site gives a lot of great DIY info, but bookmark this site as well:
Mad Russian
Jump to top spta97 is offline   Reply With Quote
Old Thu, Aug-16-2007, 02:31:51 PM   #6
jav1
jav1's Avatar
Thanks guys- that makes me feel a little better. How about the frequency /likelyhood of things like CEL? Is there a software interface that is available to us (Like Vag-Com for VW) ?
Obioban -thanks for yourt insights and info on tracking. DE events would be part of this experience. How has your M3 held up to track use?
Old Thu, Aug-16-2007, 04:25:31 PM   #7
ThatOneGuy
In the left lane, flashing to pass.
ThatOneGuy's Avatar
Reputation: 0 ThatOneGuy is on a distinguished road
Germany
You may find this helpful: http://www.m3forum.net/m3forum/showt...vice+intervals
The Blog
Jump to top ThatOneGuy is offline   Reply With Quote
Old Thu, Aug-16-2007, 04:36:35 PM   #8
The key to avoiding lights is disconnecting the battery before doing anything that involved unplugging sensors. And if you do trigger one... if you get friendly with a local independent BMW shop I bet they'll turn them off again for free. I've never set any off on my car, but I did on my buddy's M5 (forgot to disconnect battery when replacing steering wheel, set off the airbag light) and got it turned off for free, no questions asked.
The car's great on the track. The ONLY thing you need to go is track specific pads, good brake fluid, and maybe stainless lines. Everything else is just for your own enjoyment/speed.
The car holds up very well in all respects-- mine gets
tracked
drag raced (though not that often, and by this I mean at a drag strip)
autoxed
driven hard on the street
driven in the snow
driven in the rain
driven in 104 heat
... and she never misses a beat
If you're going to track the car (actually, I'd recommend this to anyone, but especially if you track the car), I would add the following suggestions:
1) Do oil changes twice as often as the car suggests. For me, that's about every 6k miles.
2) On every inspection (BMW inspection 1 & 2, not state inspection), change the diff and tranny fluid. That doesn't take much effort (only once every ~25,000 miles) but it will make those components last much longer. Life time fill is bogus.
If you're buying an 01 or 02, make sure the rod bearing recall has been done. If the car is nearing or past 50,000 miles, you're probably also looking at
Shocks
RSM
RTABs
Inspection 2 items (including, but not limited to, air filters, fuel filter, spark plugs, etc)
Old Thu, Aug-16-2007, 05:08:54 PM   #9
jav1
jav1's Avatar
thatoneguy- thanks for the link... it was an interesting read.
Obioban - I will do a search but pardon my ignorance as I do not recognize some of the acronyms you used (rsm/rtab)?
EDIT : I found the acronyms in the faq section. BTW, the cars I'm looking at have had the recall done and are in the 50-75k mile range.
Old Thu, Aug-16-2007, 05:16:06 PM   #10
kkamakasi
울산박
kkamakasi's Avatar
Reputation: 0 kkamakasi is on a distinguished road
South Korea
RSM- rear shock mounts
RTAB - rear trailing arm bushing
Jump to top kkamakasi is offline   Reply With Quote
WTB: Kevlar or Aluminum Bumper support for e46 M3. TakeOverM3 Parts for Sale/Wanted 1 Sat, Aug-02-2008 04:49:16 PM
Where can I buy aluminum bumper support for e46 M3? TakeOverM3 E46 M3 (2001-2006) 2 Sat, Aug-02-2008 05:46:44 AM
DIY Maintenance and upgrades for my new M3 PyleDriver E46 M3 (2001-2006) 40 Tue, Jan-29-2008 11:55:40 PM
WTB : 2001 Metal bumper support for E46 M3!!! Wasa Parts for Sale/Wanted 3 Sun, May-13-2007 09:48:50 PM
e46 m3 carbon Fiber support bar - front monkeyjuice5051 Parts for Sale/Wanted 5 Fri, Aug-18-2006 04:34:18 PM
Discussing E46 maintenance / DIY support ? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
