Old Thu, Jun-14-2018, 02:34:56 AM   #1
EricSMG
40 something
Default Blackstone results not good
87k miles, second owner, average ~6k mile oil change internal its entire life. Lots of redlining, but also lots of super short drives.
Iron: 24 (10 avg)
Copper: 36 (8 avg)
Lead: 49 (5 avg)
Blackstone is concerned. They recommend checking again at 4k miles.
Is this a "stop driving immediately and have the rod bearings replaced" scenario?
Any input welcomed.
Thanks
Edit: motor runs like a raped ape. Definitely on the "strong" side of the spectrum - this is my 5th 46M and it's a fast one. Also zero funky noises ever, cold, hot, never.
2004 E46 M3 6MT SG/Black
Old Thu, Jun-14-2018, 02:55:32 AM   #2
///M Dream
Real Madrid C.F.
///M Dream's Avatar
Reputation: 0 ///M Dream is on a distinguished road
Default Re: Blackstone results not good
Replace them. Either way you know they’re coming up. Better safe
Current: 2006 Interlagos Blue ZCP ///M3
Past: F80 M3. E46 330i ZHP. B8 S4. E92 M3. E46 M3.
Jump to top ///M Dream is offline   Reply With Quote
Old Thu, Jun-14-2018, 02:56:41 AM   #3
Good
@GOOD_M3
Good's Avatar
Iron: 24 (10 avg)
Copper: 36 (8 avg)
Lead: 49 (5 avg)
Any input welcomed.
Thanks
My experience with having high amounts of lead and copper was really odd. I did a couple tests and it never got better, so I had the rod bearings replaced. After taking a look at the old bearings, there really wasn’t much damage at all, nothing like any pictures you see. It kinda had me lost faith in taking a oil analysis.
EXTERIORJCSL 1X1 DIFFUSER | VÖRSTEINER CSL BUMPER
PREVENTATIVE ▌VANOS BEISAN LOCKDOWN: UPPER GUIDE CHAIN | SOLENOID COIL PACK | OIL PUMP DISK | SMG PUMP/MOTOR RELOCATED
EXHAUSTSUPERSPRINT EXHAUST ~ OVERSIZED STEPPED V1 HEADERS | RACE CATTED SEC 1 | RESONATED X-PIPE SEC 2 | SPORT (GEN 2) SEC 3
BRAKES ▌STOCK CSL/ZCP ROTORS | PORSCHE 996 BREMBO CALIPERS | SS LINES
WHEELS[/SIZE] ▌STOCK ZCP BBS 19" | 75MM ECS/TMS F&R WHEEL STUD CONVERSION
SUSPENSIONTURNER MOTORSPORT 30MM FRONT SWAY BAR | KW V2 COILOVERS | GROUND CONTROL CAMBER PLATES | SDW RTABS
ENGINE ▌TUNED BY PAUL-CLAUDE | KARBONIUS CSL AIRBOX (ALPHA N), OEM SNORKEL (FLAP DELETE), OIL CATCH CAN
TRANSMISSION ▌'255' CSL SMG DME TUNE | INERTIA SMG DME UPDATE | WARM-UP LIGHT RECALIBRATION
Instagram: https://www.instagram.com/good_m3/?hl=en
Youtube: https://www.youtube.com/channel/UCOW...3N7QDfZ5NSzriA
Journal: http://www.m3forum.net/m3forum/showthread.php?t=599036
Old Thu, Jun-14-2018, 03:13:22 AM   #4
jtt777
jtt777's Avatar
Reputation: 0 jtt777 is on a distinguished road
your rod bearings are going, get them taken care of in the near future. i don't know its a stop driving immediately but i wouldn't be bringing it to track events or hard redlineing it over and over again until this is sorted.
2004 PY BMW M3
Jump to top jtt777 is offline   Reply With Quote
Old Thu, Jun-14-2018, 05:31:49 AM   #5
Texaz3
Is this your first analysis or have you done them before? If done before, what were the numbers then?
I honestly don't think this is a stop driving immediately scenario, but if the metals are similar in the next one after 4K miles, I would replace them. Just for peace of mind. Its a $1500 vs new engine.
You mention a lot of short drives - how was your oil viscosity and flashpoint? Was it good/adequate for 10w60 after 6K? Any fuel in the sample? Which oil did you run?
Old Thu, Jun-14-2018, 06:27:53 AM   #6
It's tough Eric because we've been taught from early on to do the rod bearings, especially with a report like that. Like Good said though, I've seen and heard of a few instances where reports were bad, but there was plenty life yet.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · zero options · ~3200lbs · JOURNAL
_
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 S pipes 2.5" + 200 cell HFC · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pullies · WPC'd OE bearings · oil catch can · fan/SAP/washer delete · CSL battery
GroundControl S/A Koni (Hyperco/Eibach 300/550) + tall RSMs · Hotchkis front sway (med) · rear strut bar · TMS camber & subframe plates · SPC alum rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing · Mason clutch pedal + brass bushing · TMS black pedals · delrin brake pedal bushing
OE CSL trunk · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · 12mm/10mm F/R spacers · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack · Pioneer/CDT/Eclipse/Kicker
Old Thu, Jun-14-2018, 06:43:20 AM   #7
HassanEido
HassanEido's Avatar
Lebanon
I think it's obvious that you need to do the bearings man.
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Thu, Jun-14-2018, 07:31:49 AM   #8
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Just do the bearings bud and get them out of the way. Better safe than sorry.
Old Thu, Jun-14-2018, 07:46:49 AM   #9
Wanted to add that you'd really want to see a pattern before making assumptions. Ideally.
_
Old Thu, Jun-14-2018, 08:00:18 AM   #10
mrgizmo04
mrgizmo04's Avatar
Yeah tough to say, report could be bad. If you take it "easy" next 4k miles before the next oil analysis, I would expect the numbers to come down by nature of taking it easier and shorter interval, so that report would not give me much piece of mind. At your mileage (87k), I'd gear up for doing them.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Discussing Blackstone results not good in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
