Old Wed, Jun-13-2018, 12:34:35 AM   #1
nuc1
Meh
nuc1's Avatar
Reputation: 0 nuc1 is on a distinguished road
Default HVAC Relocation Bracket Door/Cover
Does anyone know if the door/cover (opens when you push on it) on the HVAC relocation bracket is removable? Part number 51167001408 found here: https://www.ecstuning.com/b-genuine-...t/51167001408/
Looking into a project and wanted to see if anyone else has tried to remove the door before I tear my dash apart.
Thanks,
Mike
02 TiAg/Black 6MT
Go
- BW CSL Intake - Dinan ITBs - Ported & Polished Head - Schrick 288/280 - ARP Head/Main/Rod Bolts - Epic Rod Bearings - CP Pistons - Beisan VANOS - Okada Coils - SS V1 Stepped Headers & Catless Sec 1 - OEM Sec 2 - AA Gen 6 Sec 3 - OEM CSL MAP & Pressure Rail - CSL Software - 4.10 Polished Diff - TTFS Tune
Stop
- Brembo 355F/345R - Stoptech Pads (Street) - GC Street/Track SA 525/550
Show
- OEM Euro Front Bumper - OEM CSL Trunk - Polished OEM 19s - OEM Euro Folding Mirrors - OEM LEDs w/ BFD - Sunroof Delete - Apple iPad Mini - Pioneer - JL Twk88 - JL 300/2 - JL 500/1 - JL 12W6 - Focal K2P
18 Acura MDX White/Black Family Truckster
11 Tundra Super White/Black Actual Truckster
Jump to top nuc1 is offline   Reply With Quote
Old Wed, Jun-13-2018, 05:55:01 AM   #2
kokgo20
kokgo20's Avatar
Default Re: HVAC Relocation Bracket Door/Cover
It can be removed from both sides
Build thread
Old Wed, Jun-13-2018, 11:24:02 AM   #3
nuc1
Meh
nuc1's Avatar
How does it come off? Canít see any screws/bolts etc.
Thanks,
Mike
02 TiAg/Black 6MT
Go
Stop
Show
Old Wed, Jun-13-2018, 01:38:20 PM   #4
kokgo20
kokgo20's Avatar
Originally Posted by nuc1 View Post
How does it come off? Can’t see any screws/bolts etc.
Thanks,
Mike
No screws, you wedge a small flat head between the hinge and the side. It’s cliped on.
FYI if u r planning on putting it back together it’s not easy at all.
Build thread
Old Wed, Jun-13-2018, 02:30:18 PM   #5
dutchhome
Reputation: 0 dutchhome is on a distinguished road
I took one apart to replace one of the gears. It wasn't too difficult, but I had it out of the car.
Sent from my Pixel 2 using Tapatalk
Jump to top dutchhome is offline   Reply With Quote
Old Wed, Jun-13-2018, 11:19:16 PM   #6
nuc1
Meh
nuc1's Avatar
No screws, you wedge a small flat head between the hinge and the side. Itís cliped on.
FYI if u r planning on putting it back together itís not easy at all.
Thanks guys.
Mike
02 TiAg/Black 6MT
Go
Stop
Show
Discussing HVAC Relocation Bracket Door/Cover in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
