Old Tue, Jun-12-2018, 08:00:16 PM   #1
TheGenius46M
TheGenius46M's Avatar
Question CSL Ducting on OEM Bumper Solution?
Going to be installing my CSL manifold this week and I have all four of the factory duct pieces and plan to utilize all of them with the factory bumper. Some individuals have mentioned that the intake hose (bmw 13717896774) is the only piece that can pose an issue, but I am curious if anyone has found a clean way to implement it to the factory bumper that would be appreciated.
If you could post pics of your solution, I think this would be a great reference thread for those of us that want to implement the ducting as oem as possible and don't want a csl bumper.
Here's what I found so far, but looking for something clean and oem plus.
Option 1)
https://forums.m3cutters.co.uk/showthread.php?t=140240
With option 1, I was thinking I could route part 774 to the main grille for ducting and probably just tie wrap it since I can't think of a cleaner way.
Option 2)
Here is the solution I saw without using part number 774 and I'm friends with the guy locally.
http://www.m3forum.net/m3forum/showthread.php?t=383430
Any input would be greatly appreciated. Thanks!
2003 E46 M3 TiAg/Cinnamon 6MT
Karbonius | MCS | Volk | Recaro | OMP | Hyperco | Ground Control | Besian | AKG | Schroth | Bimmerworld | Turner | PFC | CSF | SuperSprint | Radium Engineering |
Bay Area/ Nor Cal Coding and DME Tuning Specialist. PM for inquiries.
Old Tue, Jun-12-2018, 08:15:00 PM   #2
Good
@GOOD_M3
Good's Avatar
Default Re: CSL Ducting on OEM Bumper Solution?
Subbed, just installed my airbox last weekend. I now too need to figure out the air ducting from my stock bumper.
2006 M3 SILBERGRAU COMPETITION
EXTERIORJCSL 1X1 DIFFUSER | VÖRSTEINER CSL BUMPER
PREVENTATIVE ▌ VANOS BEISAN LOCKDOWN: UPPER GUIDE CHAIN | SOLENOID COIL PACK | OIL PUMP DISK
EXHAUSTSUPERSPRINT EXHAUST ~ OVERSIZED STEPPED V1 HEADERS | RACE CATTED SEC 1 | RESONATED X-PIPE SEC 2 | SPORT (GEN 2) SEC 3
BRAKES ▌ STOCK CSL/ZCP ROTORS | PORSCHE 996 BREMBO CALIPERS | SS LINES
WHEELS ▌ STOCK ZCP BBS 19" | 75MM ECS/TMS F&R WHEEL STUD CONVERSION
SUSPENSIONTURNER MOTORSPORT 30MM FRONT SWAY BAR | KW V2 COILOVERS | GROUND CONTROL CAMBER PLATES | SDW RTABS
ENGINE ▌ TUNED BY PAUL-CLAUDE | KARBONIUS CSL AIRBOX (ALPHA N), OEM SNORKEL (FLAP DELETE), OIL CATCH CAN
TRANSMISSION ▌'255' CSL SMG DME TUNE | INERTIA SMG DME UPDATE | WARM-UP LIGHT RECALIBRATION
Instagram: https://www.instagram.com/good_m3/?hl=en
Youtube: https://www.youtube.com/channel/UCOWWdc1VO3N7QDfZ5NSzriA
Jump to top Good is online now   Reply With Quote
Old Wed, Jun-13-2018, 09:33:03 AM   #3
schoonerm3
Reputation: 0 schoonerm3 is on a distinguished road
Ireland
So I have used the oem csl secondary airfeed flexi pipe and connected it to a metal flexi pipe from a vacuum cleaner. Drilled a hole in the brake duct. There is an unused stubby dead end on the brake ducting. It was perfect to tap into and stick a pipe in to collect air.
If you look carfully you can see the oem csl tubing. The only problem is the dame thing vibrates loose off of the karbonious box. I need to think of a way to keep it there.
Jump to top schoonerm3 is offline   Reply With Quote
Old Thu, Jun-14-2018, 05:00:55 PM   #4
repoman89
repoman89's Avatar
Reputation: 0 repoman89 is on a distinguished road
Bump and subscribed. I particularly like option 2 from the OP
Jump to top repoman89 is offline   Reply With Quote
Old Thu, Jun-14-2018, 05:19:28 PM   #5
ultimatemj
Something like the eventuri scoop would be a nice approach
2004 JB/Blk SMG | 2nd owner | Purchased in 2008 w/24k miles
Key maintenance done: Subframe reinforced | WPC Rod bearings | Beisan Vanos lockdown + chainguide
Refesh maintenance done: Suspension & Driveline rubber replaced | CSB | viton CPV | Coils + plugs+ O2s | Waterpump + Thermostat | Belts & pulleys
OE+ additions: Evolve CSL airbox | Supersprint Exhaust | PE tune | OE CSL trunk | 18” VMR 710 w/PSS | EU2pc Brakes | Koni+Dinan springs| Valentine1 w/StealthOne | Stereo build log
Old Sat, Jun-16-2018, 01:40:35 AM   #6
marioec
marioec's Avatar
Reputation: 0 marioec is on a distinguished road
Subbed !!
2002 BMW E46 M3 / Tiag / Imola / TTFS SMG
TTFS Custom Tune
BMC Air Filter & Macht Schnell Intake Boot
STG Headers / Euro Cats / STG SCOZA Muffler
Subframe Reinforced by Active Autowerke / HSD Coilovers /Apex ARC-8 / Michelin PSS / 4.10 Motorsport Gears
Jump to top marioec is offline   Reply With Quote
Old Sat, Jun-16-2018, 02:30:18 AM   #7
Paolo_M3
Paolo_M3's Avatar
Reputation: 0 Paolo_M3 is on a distinguished road
I have zero knowledge on the subject but I'll just throw out an idea.
If you don't care about the OE fog lights, why not go with hard motorsport fog light deletes/brake ducts and route one to the airbox?
2002 E46 M3 TiAg/Black (Sold)
1997 E36 M3 Alpine/Black (Sold)
2003.5 E46 M3 Imola/Black (Sold)
2006 E46 M3 Interlagos/Gray Slicktop (Rear Ended / Sold)
Jump to top Paolo_M3 is offline   Reply With Quote
Old Sat, Jun-16-2018, 02:49:29 PM   #8
HassanEido
HassanEido's Avatar
Lebanon
The stock elbow fits over the stock snorkel. If u can fit a ram air collector near the fog light, the stock snorkel and elbow will blow air right in front of the airbix opening
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Wed, Aug-22-2018, 10:16:10 PM   #9
Sweet Jones
Sweet Jones's Avatar
Reputation: 0 Sweet Jones is on a distinguished road
Mexico
I love the idea of the eventuri scoop, i may have to try that out.
E46 Touring
S54/6 speed, FluidMotorUnion velocity stacks, CSL cams, Swaintech coated headers, Mishimoto radiator, Alpha N tune, 4.10 diff, M3 suspension, Turner Motorsport subframe reinforcement, CSL brakes, 2.5" SS304 Rhom Innovations exhaust.
E46 touring, Version 2
S54/6 speed, polished FluidMotorUnion velocity stacks, CSL cams, Swaintech coated headers, Mishimoto radiator-Mishimoto radiator hoses-Mishimoto electric fan, Alpha N tune, 4.10 diff and RevShift bushings, RTD mini V2 shifter and DSSR, Airlift Performance 3H suspension, Rogue Engineering RaceBrace strut bar, Turner Motorsport subframe reinforcement, PLM SM-AFR wideband, Eonon GA7150A with front and rear cameras, Work Brombachers, Storm Motorwerks interior pieces, CSL brakes and 996 calipers, 2.5" SS304 Rhom Innovations exhaust, Bimmerworld Race diffuser. M3 bodywork and paint.
Jump to top Sweet Jones is offline   Reply With Quote
Old Wed, Aug-22-2018, 10:18:33 PM   #10
C///M
I have a brand new one for sale as I was going to go that exact route but I ended up installing aftermarket brake cooling ducts for track.
Jump to top C///M is offline   Reply With Quote
Discussing CSL Ducting on OEM Bumper Solution? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
