Old Tue, Jun-12-2018, 06:08:24 PM   #11
Kleedzine
Reputation: 0 Kleedzine is on a distinguished road
Default Re: VANOS removal tip
Originally Posted by E30User View Post
Is this one of this videos that you have watched? It shows some careful rubber mallet tapping action as others have mentioned.
BMW S54 VANOS DIY - E46 M3, Z4 - YouTube
Yes I have watched it, and it seems very easy to remove it on the video, But in real life, it is not easy task. I am going to try the method later and see how it goes.
2002 BMW E46 M3 (daily toy)
2014 Toyota Camry hybrid-SOLD
2002 Subaru WRX frenkenSTI - SOLD
2009 Subaru WRX - SOLD
2004 Lexus IS300 - R.I.P
2002 Honda Civic SI - TRADE
Jump to top Kleedzine is offline   Reply With Quote
Old Tue, Jun-12-2018, 07:08:14 PM   #12
mrgizmo04
mrgizmo04's Avatar
All those video editing tricks...probably took him quite a bit longer than 5 seconds to hammer it off. Real life is more fun, always takes 10x the time.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Jun-12-2018, 07:45:48 PM   #13
Kleedzine
Yes, the valve cover has been left open for more than a week.
Also trying to find the right 24mm open wrench to fit on the camshaft hex, still no luck, running around hardware stores, deliveries from Amazon, more 'fun'.
Old Tue, Jun-12-2018, 07:49:05 PM   #14
mrgizmo04
mrgizmo04's Avatar
Yep, all part of 10x time .
'05 M3 6MT coupe
Old Wed, Jun-13-2018, 04:35:17 AM   #15
Kleedzine
Originally Posted by schoonerm3 View Post
wont make any difference.
The reason its tight is because of the two dowels that are tightly fitted on the two upper corner bolt holes.
Trust me, rubber mallet and use the vibrations to make a little separation and then work in the putty knives
Rubber mallet method is working great!!
Finally the VANOS is off.
Thanks for the help.
Old Wed, Jun-13-2018, 03:43:58 PM   #16
repoman89
Reputation: 0 repoman89 is on a distinguished road
Do you have a Lowe's nearby? The 24mm Kobalt one they sell fits.
Jump to top repoman89 is offline   Reply With Quote
Old Thu, Jun-14-2018, 04:38:09 PM   #17
Kleedzine
I know it's Canadian Website, but is this the one?
https://www.lowes.ca/combination-wre..._g1187018.html
Discussing VANOS removal tip in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
