Old Tue, Jun-12-2018, 04:15:19 AM   #1
Kleedzine
Reputation: 0 Kleedzine is on a distinguished road
Default VANOS removal tip
Hi
I am DIYing VANOS overhaul with FULL Beisan system, and stuck at pulling the vanos unit off of the engine.
I have fully retard both camshafts (timing holes are perpendicular to the engine block), and still no luck to pry off the unit.
From various DIY thread and video, there's nothing I have missed.
Is the vanos unit usually hard to remove?
Please let me know if there's any hidden tips.
also, typical 24mm open wrench does not fit on the camshaft hex.
I have been sourcing the wrench, but no success, so I have used adjustable wrench. Still, I am trying to find the right tool for it.
For me, it seems 24mm wrench is a bit loose side of fitment on the hex. is 15/16" wrench fit better? since imperial one is a little smaller.
Any helps, recommendation and comments are welcome.
Peace!
2002 BMW E46 M3 (daily toy)
2014 Toyota Camry hybrid-SOLD
2002 Subaru WRX frenkenSTI - SOLD
2009 Subaru WRX - SOLD
2004 Lexus IS300 - R.I.P
2002 Honda Civic SI - TRADE
Jump to top Kleedzine is online now   Reply With Quote
Old Tue, Jun-12-2018, 04:41:21 AM   #2
bigjae1976
Default Re: VANOS removal tip
Itís a 24mm wrench. You probably need to grind it a little to make the open end a little thinner.
As for it coming off, I usually stick a pry bar in there and GENTLY pry the VANOS. Pry too hard and youíll bust the splined shafts.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Tue, Jun-12-2018, 05:36:58 AM   #3
mrgizmo04
mrgizmo04's Avatar
Pry bar and gently? Lol
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Jun-12-2018, 05:41:34 AM   #4
mrgizmo04
mrgizmo04's Avatar
Pry from the two sides like in this Beisan pic. I used jeweler's flat head screwdrivers. Takes a bit of force.
Originally Posted by Kleedzine View Post
Hi
Peace!
'05 M3 6MT coupe
Old Tue, Jun-12-2018, 05:54:35 AM   #5
aznniche
aznniche's Avatar
Use 1/4 inch extension and stick the square end inside the vanos bolt
bolt open up top and tap it lightly towards the front of the car with a hammer.
Old Tue, Jun-12-2018, 09:57:52 AM   #6
schoonerm3
Reputation: 0 schoonerm3 is on a distinguished road
Ireland
This is how I did it and it meant not damaging, denting or removing any head material.
I got two very thin putty knives like beisan suggest. I got a rubber mallet. I removed the solenoid block and solenoid pack. I used the rubber mallet to hit the vanos unit from the top and also from the bottom ( just enough space to get a swing). The vibrations eventually allowed me get the putty knives in a few mm. I keep hitting the unit with the rubber mallet and every so often I can work the putty knives in a little more. Only when I got the knives in by a good amount would I give it a little leverage and continue to bang the unit with the rubber mallet.
.install long screws at both corners to catch the vanos as it releases.
I really hated how there was material being removed or other signs of damage to the surrounding metal by forcing in screw drivers or even forcing in the putty knives.
My unit was very firmly attached
Jump to top schoonerm3 is offline   Reply With Quote
Old Tue, Jun-12-2018, 04:16:38 PM   #7
Kleedzine
Thank you for the advice.
Does it help, if I remove the two piston cap?
I really don't want to make any damages. So I am trying to be very careful.
Old Tue, Jun-12-2018, 04:36:50 PM   #8
schoonerm3
Ireland
wont make any difference.
The reason its tight is because of the two dowels that are tightly fitted on the two upper corner bolt holes.
Trust me, rubber mallet and use the vibrations to make a little separation and then work in the putty knives
Old Tue, Jun-12-2018, 04:53:24 PM   #9
Kleedzine
The reason its tight is because of the dowel that are tightly fitted on the two upper corner bolt holes.
Trust me, rubber mallet and use the vibrations to break the seal and then work in the putty knives
I see, I will try your method. Thanks alot for your help!
Old Tue, Jun-12-2018, 06:20:15 PM   #10
E30User
Reputation: 0 E30User is on a distinguished road
Is this one of this videos that you have watched? It shows some careful rubber mallet tapping action as others have mentioned.
Jump to top E30User is offline   Reply With Quote
Discussing VANOS removal tip in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
