Old Tue, Jun-12-2018, 03:15:23 PM   #11
racee78
racee78's Avatar
Reputation: 0 racee78 is on a distinguished road
Default Re: Rod bearing replacement cost
Originally Posted by bimmerfan08 View Post
DIY it and do it for a fraction of the cost. I wrote up a fairly extensive DIY for rod bearings.
I’ve read both yours and SYT_Shadow’s.. thanks to both of you as I’ll be tackling this soon.
Jump to top racee78 is offline   Reply With Quote
Old Tue, Jun-12-2018, 03:35:48 PM   #12
bimmerfan08
bimmerfan08's Avatar
Glad they are getting put to good use and are an aid for members of the community.
Old Tue, Jun-12-2018, 03:56:44 PM   #13
Texaz3
Originally Posted by mitch500 View Post
Like sitting on the couch watching TV in your AC.
Oh please. Look me up, its not like I have not done my share of DIYs. Let's not bring this BF attitude here, pal. I know my limitations, and doing RBs in my garage is not what I want to do. My time is more valuable to me and I will gladly pay somebody to do this.
Old Tue, Jun-12-2018, 04:07:17 PM   #14
mitch500
mitch500's Avatar
Reputation: 0 mitch500 is on a distinguished road
Calm down it's a joke.
97 E36 M3 Coupe Alpine white
s54 swap in progress
Jump to top mitch500 is offline   Reply With Quote
Old Tue, Jun-12-2018, 05:15:51 PM   #15
///M Dream
Real Madrid C.F.
///M Dream's Avatar
Reputation: 0 ///M Dream is on a distinguished road
I wipe my own ass...
Current: 2006 Interlagos Blue ZCP ///M3
Past: F80 M3. E46 330i ZHP. B8 S4. E92 M3. E46 M3.
Jump to top ///M Dream is offline   Reply With Quote
Old Tue, Jun-12-2018, 05:36:37 PM   #16
aznniche
aznniche's Avatar
Two days to complete my bearings in my garage.
Old Tue, Jun-12-2018, 06:12:54 PM   #17
HassanEido
HassanEido's Avatar
Lebanon
Much less than an engine replacement
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Tue, Jun-12-2018, 07:04:20 PM   #18
steeezm3
steeezm3's Avatar
Reputation: 0 steeezm3 is on a distinguished road
So far I have 3 quotes in Raleigh: $950, $1800 and $2300 all parts & labor.
I'm not sure if the one for $950 is because it's where I bought the car, but it seems so low that it's mildly concerning... Although they seem to know their way around an E46 M3.
For the guys that did it yourself... Is the job more time consuming than actually difficult?
Evolution of bad decisions
ITR > E46 M > ITR > E46 M > NSX > E92 M > F80 M > E46 M
Jump to top steeezm3 is offline   Reply With Quote
Old Tue, Jun-12-2018, 08:18:28 PM   #19
mrgizmo04
mrgizmo04's Avatar
It is tricky in it's own way. You have a few annoyances like taking off ps and ps pump to get to a couple oil pan bolts, you have to lower or remove the entire front subframe to get the oil pan out. You need some special tools like an engine support bar. Reassembling, outside of rod bolt torque procedure, getting the oil pan lined up with some rtv is not fun, you need to make sure you don't eff up the engine mounts and they line up with the heat shield when bolting up the subframe and lowering the engine from the support bar. Doing this yourself on jackstands is quite a bit of hopping around checking everything in small increments, because safety first. So yeah, time consuming and tricky due to the number of things you need to keep track of with that engine hovering over you supported by an $80 bar from Amazon or Harbor Freight.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Wed, Jun-13-2018, 12:53:57 AM   #20
bimmerfan08
Looking back on it, if I wasn't replacing all the parts that I refreshed, it probably would have taken me 6-7 hours at a moderate pace. It's not overly difficult, just time-consuming because of all the parts that need to be removed to access the bearings.
Discussing Rod bearing replacement cost in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
