Old Mon, Jun-11-2018, 11:44:37 PM   #1
Texaz3
Default Rod bearing replacement cost
I did a quick search, but nothing specific came up. Sorry if this has been covered, but wanted to see what was a ball park bearing replacement bill - I think I might do this preventatively at some point soon, so wanted to plan ahead.
Old Mon, Jun-11-2018, 11:48:15 PM   #2
///M3 MD
Reputation: 0 ///M3 MD is on a distinguished road
Roughly $1-1.5k depending on the person/shop you get to do the labor. You should definitely have the oil pump checked out while you’re in there and consider replacing that if it looks like it’s eaten any metal.
2002 Carbon Black/Black 6MT ///M3
Mods: (Mike Miller Maintenance schedule) - Euro Headers - Resonated Section 1 - Dinan Section 3
TTFS Custom Tune
Autosolutions 30% SSK - RE Poly Trans mounts - AKG Poly diff bushings, RTABs and FCABs
Dinan 'Stage 1' Suspension
Jump to top ///M3 MD is online now   Reply With Quote
Old Tue, Jun-12-2018, 12:34:01 AM   #3
mrgizmo04
mrgizmo04's Avatar
Default Re: Rod bearing replacement cost
Here is a thread with your title + "?". 8-12 hours times shop rate should guide you. Many other "while you are in there" tasks like ps/rack/tie rods and suspension related, engine mounts, etc.
http://www.m3forum.net/m3forum/showthread.php?t=433468
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Jun-12-2018, 01:10:38 AM   #4
bimmerfan08
bimmerfan08's Avatar
DIY it and do it for a fraction of the cost. I wrote up a fairly extensive DIY for rod bearings.
Old Tue, Jun-12-2018, 02:42:22 AM   #5
M3_Pilot
Yeah I spent about $450 in parts and did it myself.
2004 Jet Black/Cinnamon 6MT
@jet.m3
Old Tue, Jun-12-2018, 03:49:42 AM   #6
Texaz3
I'm not interested in doing it myself. I honestly have more interesting things to do than spend 15 hours trying to do something I have no idea how to do in a 100+ degree Texas heat. No offense.
Old Tue, Jun-12-2018, 05:16:42 AM   #7
ultimatemj
diy if it’s your ‘bag of tea’
Otherwise find someone that has done a dozen or more, so they can recognize the other items that are due to be replaced while you have everything apart.
WPCcoated+ARPbolts+labor was $1800 for me, and I was happy to pay the mechanic for their experienced work
2004 JB/Blk SMG | 2nd owner | Purchased in 2008 w/24k miles
Key maintenance done: Subframe reinforced | WPC Rod bearings | Beisan Vanos lockdown + chainguide
Refesh maintenance done: Suspension & Driveline rubber replaced | CSB | viton CPV | Coils + plugs+ O2s | Waterpump + Thermostat | Belts & pulleys
OE+ additions: Evolve CSL airbox | Supersprint Exhaust | PE tune | OE CSL trunk | 18” VMR 710 w/PSS | EU2pc Brakes | Koni+Dinan springs| Valentine1 w/StealthOne | Stereo build log
Old Tue, Jun-12-2018, 02:32:37 PM   #8
BearDeXPS
BearDeXPS's Avatar
where are you located in Texas?
Jump to top BearDeXPS is online now   Reply With Quote
Old Tue, Jun-12-2018, 02:33:58 PM   #9
Texaz3
Located in Fort Worth.
Old Tue, Jun-12-2018, 02:36:19 PM   #10
mitch500
mitch500's Avatar
Reputation: 0 mitch500 is on a distinguished road
Like sitting on the couch watching TV in your AC.
97 E36 M3 Coupe Alpine white
s54 swap in progress
Jump to top mitch500 is offline   Reply With Quote
Discussing Rod bearing replacement cost in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
