Old Tue, Jun-12-2018, 02:53:21 PM   #31
Default Re: High-Gloss Shadowline (exterior) Trim - Pictures
Originally Posted by jared212 View Post
Here is one for local pickup in PA. https://www.ebay.com/itm/2000-2006-B...E/232688160238
Prussian motors. They're local to me, and run by good people
Old Tue, Jun-12-2018, 02:56:57 PM   #32
Kcalhoun27
Reputation: 0 Kcalhoun27 is on a distinguished road
This seems like respray to me. Tape it off, sand it lightly, find a good black color youre happy with, spray/clear and then enjoy your new look.
Unless you make $1200 in a few hours then its a no brainer.
And if you do, then congrats, go buy your new trim lol
Jump to top Kcalhoun27 is offline   Reply With Quote
Old Tue, Jun-12-2018, 03:42:17 PM   #33
Completely agreed. This feels like an instance where you could get 100% the same result with paint as with the same result.
In fact, my M5 (comes stock with high gloss shadowline) developed an imperfection. I had them respray and blend it while it was in the body shop for something else, and at this point I can't even tell where the imperfection was-- the paint is indistinguishable from the original high gloss shadowline.
And it was easy enough that they did it for free!
Old Tue, Jun-12-2018, 04:59:41 PM   #34
robgill
I'd rather be at the track.
robgill's Avatar
Reputation: 0 robgill is on a distinguished road
I wrapped my trim in gloss black when I had it off to fix the rear window seals. I wanted it to match my roof (also gloss black wrap), grills/gills (ECS gloss black) and M3 badge (F80 gloss black).
First thing I ever wrapped and it was a pretty easy diy. It has held up exceptionally well over 2 years and still looks brand new. Highly recommended.
My '02 E46M Build Thread
Jump to top robgill is offline   Reply With Quote
Old Tue, Jun-12-2018, 05:01:38 PM   #35
Don’t forget there is more to the Glans Schwarz trim than the roofledge piece. You can paint your rubber version lower trim but I don’t believe the OEM version is just paint. It may be an integrated hard cap over the rubber.
51367891911
51367891912
51327890453
51327890454
The forward quarter glass trim comes only in matte but these might look good matched too.
51368209401
51368209402
Old Tue, Jun-12-2018, 07:39:15 PM   #36
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Originally Posted by kokgo20 View Post
Why not try to wet sand them, polish to gloss
Or paint them? I believe it would be cheaper
Honestly, because my stock trim is in good condition and at over $500 a side, I don't want to risk mucking them up and being stuck with trim that is worse off than the stock matte finish. Wet sanding, polishing, clear-coating, or wrapping...none of those options guarantee the same look of the high-gloss shadowline trim. Would rather just do it right the first time....price depending.
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized Catless section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune.
Active Group-Buys (PM if Interested): OE CSL Bootlids, Supersprint Headers/Exhaust MEGA thread, New Supersprint Oversized Twin-Piped Section 2 ...and more to come!
Old Tue, Jun-12-2018, 07:41:19 PM   #37
Then pay a pro to redo your stock pieces for like $200
_
Old Tue, Jun-12-2018, 07:43:08 PM   #38
Dr M3an M3
Dr M3an M3's Avatar
Thought about pulling the trigger on these, but the pictures are a little un-clear and the description mentions that the trim's "finish has some minor fading and tarnish, but there is no serious damage."
Are these the only two pieces needed for the Shadowline trim on the E46 M3? Just the long swoopy trim piece that goes on either side...that's the only piece that comes in high-gloss?
Interesting that painting it was a perfect match. Maybe this is the best action after all.
IG: DrM3anM3
Old Tue, Jun-12-2018, 07:46:36 PM   #39
Dr M3an M3
Dr M3an M3's Avatar
Donít forget there is more to the Glans Schwarz trim than the roofledge piece. You can paint your rubber version lower trim but I donít believe the OEM version is just paint. It may be an integrated hard cap over the rubber.
51367891911
51367891912
51327890453
51327890454
51368209401
51368209402
Thank you sir! Once again, you are providing the information I was hoping for.
IG: DrM3anM3
Old Tue, Jun-12-2018, 07:50:13 PM   #40
Laguna01///M3
PapaSmurf
Laguna01///M3's Avatar
Reputation: 0 Laguna01///M3 is on a distinguished road
I painted all my trim gloss black including the mirrors, grills, side vents. Even the chrome around the Roundels, which I have yet to install.
Trim comes off easily. Little tricky to mask but well worth it. Replaced the lowers with new matte versions, as these couldn't be painted.
Only crap pics I have at the moment.
EURO.techniks
@WBUCCO
Jump to top Laguna01///M3 is offline   Reply With Quote
Discussing High-Gloss Shadowline (exterior) Trim - Pictures in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
