Old Tue, Jun-12-2018, 12:15:03 AM   #21
rilla
rilla's Avatar
Reputation: 0 rilla is on a distinguished road
Default Re: High-Gloss Shadowline (exterior) Trim - Pictures
I see it now in pictures of the csl. Cant say I’ve ever noticed it before looking at many pictures of those. Looks sharp on Laguna and estoril
Jump to top rilla is offline   Reply With Quote
Old Tue, Jun-12-2018, 12:40:23 AM   #22
Rakshas
Rakshas's Avatar
Reputation: 0 Rakshas has a spectacular aura about
It is not anodized which is why they do not turn purple or brown like Mercedes do. Anodizing is not durable to heat or UV at all. They are painted, which also explains why people can polish them. They should also be steel.
Yep, the finish is nothing like the one on my benz. Will snap some pictures of the chips on my ZHP's trim later.
Jump to top Rakshas is offline   Reply With Quote
Old Tue, Jun-12-2018, 01:06:52 AM   #23
e46lsb
e46lsb's Avatar
Reputation: 0 e46lsb is on a distinguished road
Originally Posted by jared212 View Post
Here is one for local pickup in PA. https://www.ebay.com/itm/2000-2006-B...E/232688160238
15 minutes from me too.
Individual- inside and out.
Jump to top e46lsb is offline   Reply With Quote
Old Tue, Jun-12-2018, 01:53:47 AM   #24
Brian N
wubalubadubdub
Brian N's Avatar
Originally Posted by rilla View Post
Lots of videos on YouTube showing how to vinyl wrap these. Now someone with silver gray go test the look for me...
I wrapped my 330i B pillars in gloss vinyl. The orange peel was horrible. It also was not nearly as glossy as my black paint.
Not sure if it has gotten better in the last couple years.
-My Journal-
Old Tue, Jun-12-2018, 02:31:21 AM   #25
azmirm5
Reputation: 0 azmirm5 is on a distinguished road
I am in the middle of this mod myself. I purchased the gloss shadow line side frame finisher and the weatherstrip that goes on the doors (between A and B pillars) off a salvager on eBay. Word of caution is that the rubber on Hofmeister kink will most likely be deteriorated, so get close up photos of this area if you can.
For the weatherstrip between the B and C pillar, I bought new from ECS (~$120 per side, about 3x the price of the non-gloss shadownline!) since these are adhesive backed (and a b&^%h to clean the old adhesive off). Most people would never notice the mod, but that's not the point, right? Good luck finding a set for your M3!
Jump to top azmirm5 is offline   Reply With Quote
Old Tue, Jun-12-2018, 03:47:16 AM   #26
I just treat my stock trim with aerospace 303 after every wash which is bi-weekly and the trim has a very deep look and a bit of a sheen to it.
-NA S54-
·RE Trans Mounts · AKG poly SUB/DIFF 95a · SDW RTAB · Weighted ///M knob + UUC DSSR + delrin carrier bush · OE CSL trunk · APEX 75mm Studs
·Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · Brembo 996 36/40 345mm CSL Textar FF & 28/30 328mm CSL ATE "D738" FF · CM brackets & ss/teflon lines
Old Tue, Jun-12-2018, 05:02:58 AM   #27
SlickmisterN
Surrounded By Grapes
SlickmisterN's Avatar
Reputation: 0 SlickmisterN is on a distinguished road
Greece
Or just spray some auto grade clear on your current ones...
Jump to top SlickmisterN is offline   Reply With Quote
Old Tue, Jun-12-2018, 09:04:43 AM   #28
schoonerm3
Reputation: 0 schoonerm3 is on a distinguished road
Ireland
I fitted a brand new set to my m3 when I resprayed it.
Mine is silver Grey
The CSL has them as standard
Jump to top schoonerm3 is offline   Reply With Quote
Old Tue, Jun-12-2018, 01:45:46 PM   #29
kokgo20
kokgo20's Avatar
Why not try to wet sand them, polish to gloss
Or paint them? I believe it would be cheaper
Build thread
Old Tue, Jun-12-2018, 01:51:09 PM   #30
NevEragon
Reputation: 0 NevEragon is on a distinguished road
That trim piece is around $450 a side at dealer cost, even for just standard black. $1200 for a pair sounds about right for MSRP. I wanted to replace mine because the rubber is cracking and coming off on both sides.... but I didn't want to drop $1000.
Jump to top NevEragon is offline   Reply With Quote
Discussing High-Gloss Shadowline (exterior) Trim - Pictures in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
