Old Sun, Jun-10-2018, 07:48:30 PM   #1
DasBlitzAuto
Reputation: 0 DasBlitzAuto is on a distinguished road
Default Yes Another Misfire Thread this ones weird.
Hey guys I apologize to do this to you but I'm having some misfire issues. All started about a month ago was at tracking the car. Came around a turn hit the throttle CEL came on car felt like it dropped a cyl. Pull the codes faulted cyl 1 misfire. Swapped the coils with 1 + 2. Drove again same thing happened pulled the codes now fault cyl 4. Hard faulted 4 many times after. Pulled the plug looked really screwed up. So i changed plugs, boots and coils. Problem solved?? Put around 200 miles on it no problems.
Fast forward to track day this weekend. Got about 8 laps gets CEL drops a cyl again. Faults Nbr 4. Spoke to a few people they say dirty fuel injector. Cleaned the injector by applying 12v to injector and back flow all the crap out of it. Cleared codes, go to start car wont run and faults Cyl 5 and sometimes 6.
Started it today very intermittent. I can hear it running good then dropping out on and off as I rev still faulting 5 and 6.
Any ideas?? Maybe O2 sensor? Anything else I can look into?
1997 Estorilblau E36 M3
TCKR DA Suspension - Turner Sways - Active Autowerke Intake/Exhaust - 17x9 ARC8 - Hankook RS4 245/40/17 Square - UUC EVO Short Shifter - Kirk Rollbar - Sparco Evo 2s - MOMO Monte Carlo Wheel - Motion Motorsport Underpanel
Jump to top DasBlitzAuto is offline   Reply With Quote
Old Mon, Jun-11-2018, 05:57:18 PM   #2
JPoland
Broken My Wallet
JPoland's Avatar
Reputation: 0 JPoland is on a distinguished road
Default Re: Yes Another Misfire Thread this ones weird.
Check to make sure you have good electrical grounds.
~Joe
Jump to top JPoland is offline   Reply With Quote
Old Tue, Jun-12-2018, 12:14:54 AM   #3
DasBlitzAuto
So just an update that may make more sense. Tried to start the car today from cold wont idle without my foot on the gas. Decided to look at my o2 sensor voltages. Cold they both read Bank 1: .920v Bank 2: .960v. Car starts to warm up will now idle on its own. Once it reached operating temp. Bank 1 fluctuating from .1 to .9 Bank 2 sits at .960v. When it stops misfiring which it does here and there they both fluctuate between .1 to .9v respectively. Once i hear it drop out again back to .960 on bank 2.
Thanks in advance.
Discussing Yes Another Misfire Thread this ones weird. in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
