Old Tue, Jun-12-2018, 06:24:09 PM   #31
mrgizmo04
mrgizmo04's Avatar
Default Re: I know this is lame but...Do I have a power loss in my M?
Originally Posted by M3_Dylan View Post
Oh shit I didn't even realize one was post and one was pre, that is weird hit: I used the hex editing tool (i forget the name of the software) and checked the disable o2 sensor box. I plan on getting an actual B spec tune next pay
Yeah, sort out the pre vs post (make sure pre are enabled) and then you should be able to take on that LT again .
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Jun-12-2018, 08:28:07 PM   #32
M3_Dylan
Full of bad ideas
M3_Dylan's Avatar
Reputation: 0 M3_Dylan is on a distinguished road
I don't think I have anything with my pre-cats disabled. I might have installed them wrong at the end of last summer. All I have checked is as follows:
155mph limiter removal
Burble / Pop on lift off
Disable SAP / Cat heating sequence
Disable Cat Protection (disables enrichment)
Disable Cat Efficiency DTCs
Disable Rear O2 DTCs (hardware removed)
The program is MSS5X by ECUWerks
2001 Steel grey M3/6speed. 19" Anthracite Apex Arc 8's (profile 3). Ground Control Coilovers with camber plates. Euro headers, Custom section 1, Grouppe M section 3. E60 sort shifter, Machnt Schenell Stage 1 intake. 19x9.5 ET22 on 245s in the front 19x10.5 ET22 on 275s in the rear
Jump to top M3_Dylan is offline   Reply With Quote
Old Tue, Jun-12-2018, 08:30:24 PM   #33
Drewster
Drewster's Avatar
Sounds like you messed up the pre-cat O2's, or swapped them for the rears?
If you don't have an EGT plugged in, you should disable that as well
Old Tue, Jun-12-2018, 09:42:56 PM   #34
M3_Dylan
Full of bad ideas
M3_Dylan's Avatar
Gotcha! I remember I had like 0 room to work with in there when I was swapping them. Could have messed up the wiring. Would that cause a loss in power?
Old Tue, Jun-12-2018, 10:28:51 PM   #35
cozmo kraemer
cozmo kraemer's Avatar
Reputation: 0 cozmo kraemer is on a distinguished road
It usually throws an SES light and the car really runs poorly.
So, YES.
2004 E46M3 - BBS RGR - RE11, BMW Motorsport 3.91, Eibach Pro Street S Coilovers (500/600), GC plates, SSV1 Headers/CPI slip fit catted/resonated section 1, Karbonious CSL intake, Shrick 280/272 cams, CSL DME Conversion, TTFS tune, OEM CSL front and rear seats
2010 - X5 4.8 Msport - the boring daily driver
My Journal
Previous - '95 M3, '94 FD RX7 (single turbo and LS6 swapped), '98 Integra Type R, '89 325i, '91 318, etc
Jump to top cozmo kraemer is offline   Reply With Quote
Old Tue, Jun-12-2018, 11:27:52 PM   #36
mrgizmo04
mrgizmo04's Avatar
Easy to mess them up, especially because bank1 post sensor is exactly the same as bank2 pre sensor.
'05 M3 6MT coupe
Old Thu, Jun-14-2018, 04:41:28 AM   #37
M3_Dylan
Full of bad ideas
M3_Dylan's Avatar
So today I did 2 things.
1. Deleted my SAP with a block off plate
2. in MS5X Hex editor also ticked the disable SAP and disable EGT monitoring boxes
Car runs alot better. I don't know/think it's all fully there but I drove home from my buddies shop and hooked it up to BMWLogger and this is what I got
https://imgur.com/a/brKbYu3
Old Thu, Jun-14-2018, 06:48:18 AM   #38
You disabled things, but did you disable the assoc dtcs? Second one is a dying precat cly 4-6 O2 sensor.
-NA S54-
·RE Trans Mounts · AKG poly SUB/DIFF 95a · SDW RTAB · Weighted ///M knob + UUC DSSR + delrin carrier bush · OE CSL trunk · APEX 75mm Studs · ZHP 13.7:1 P/S Rack
·Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · Brembo 996 36/40 345mm CSL Textar FF & 28/30 328mm CSL ATE "D738" FF · CM brackets & ss/teflon lines
Old Thu, Jun-14-2018, 07:03:31 AM   #39
mrgizmo04
mrgizmo04's Avatar
What he said + clear adaptations and codes. If you are sure all pre/post o2 sensors between banks are in proper locations and coded properly, if you get that code 38 again, replace the sensor.
'05 M3 6MT coupe
Old Thu, Jun-14-2018, 05:25:43 PM   #40
M3_Dylan
Full of bad ideas
M3_Dylan's Avatar
here's everything I have in hex editor
Disable SAP heating sequence
Disable EGT Monoriting
I cleared all the Codes in BMWLogger. SES hasn't came on yet but I only drove it to work which was 5 minutes about 3-4 miles
Discussing I know this is lame but...Do I have a power loss in my M? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
