Old Tue, Jun-12-2018, 03:38:24 AM   #21
M3_Dylan
Full of bad ideas
M3_Dylan's Avatar
Reputation: 0 M3_Dylan is on a distinguished road
Default Re: I know this is lame but...Do I have a power loss in my M?
Sounds like yes, it's down on power.
Posted my fault codes I got from BMW logger!
2001 Steel grey M3/6speed. 19" Anthracite Apex Arc 8's (profile 3). Ground Control Coilovers with camber plates. Euro headers, Custom section 1, Grouppe M section 3. E60 sort shifter, Machnt Schenell Stage 1 intake. 19x9.5 ET22 on 245s in the front 19x10.5 ET22 on 275s in the rear
Jump to top M3_Dylan is offline   Reply With Quote
Old Tue, Jun-12-2018, 03:41:14 AM   #22
M3_Dylan
Full of bad ideas
M3_Dylan's Avatar
Are you a VW owner at heart? Lol
OP: "Gosh, this car isn't street racing as well as I hoped"
Car: "Bro I'm f*cking BROKEN"
OP: "you guys think it's injectors? I bet it's injectors"
Car: [still has CEL, but now with hint of sarcasm]
All my VW friends are actually exactly like that. I did just post my fault codes though if you're interested
Old Tue, Jun-12-2018, 04:16:13 AM   #23
Looks like your precat 02s, the important ones for performance, are wonky. Either going out or maybe they were installed incorrectly? Bad pre cat 02s can mess with afr and put you way down on power.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav no xenon no anything JOURNAL
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped SS V1 S pipe + 200 cell HFC OE sect 2 SS Sport BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings TMS Camber & Subf plates RE Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Tue, Jun-12-2018, 04:20:09 AM   #24
mrgizmo04
mrgizmo04's Avatar
Originally Posted by M3_Dylan View Post
Just checked my codes using BMWlogger they are as follows
79 - Exhaust Gas Temp
105- Engine coolant Temperature Implausible
38 - Lambda Sensor Heater pre cat bank 2
39 - Lambda Sensor Heater pre cat Bank 1
I run a European exhaust manifold without cats.
Also had my car at the dealership about a month ago. They did service 1 and didn't say anything to me but idk how good the tecs are there.
I would have expected decimal codes 37 and 38 to pop up, not 38 and 39. 37 and 38 are precat O2 sensors for bank1 and 2 respectively. Codes 39 and 40 are post cat bank1 and 2 respectively.
Are you sure you copied the right codes to the thread?
From the codes (and assuming 37 and 38 rather than 38 and 39), seems your precat o2 sensors, coolant temp sensor and egt sensors are faulty.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Jun-12-2018, 05:20:36 AM   #25
M3_Dylan
Full of bad ideas
M3_Dylan's Avatar
Old Tue, Jun-12-2018, 06:22:37 AM   #26
mrgizmo04
mrgizmo04's Avatar
Interesting. So just bank2 precat O2 is bad and is the more important one. Did you tune out the post cat o2 sensors since you don't have cats?
'05 M3 6MT coupe
Old Tue, Jun-12-2018, 11:11:25 AM   #27
Originally Posted by LINDW4LL View Post
That's fair. Not a big difference at lower speeds, but 107 vs 115 trap is a pretty notable difference in top end power. What do bolt-on N/A M3s trap?
I actually have no idea-- never taken mine to the drag strip since it was brand new.
I got a 12.9 @112 out of my e39 M5 when I accidentally ended up at a drag strip (work function), and my M3 coupe is significantly faster than my M5.
Back in the day I was doing VBOX runs in a friends supercharged e46 M3, and got a best 0-60 of 3.9. That was traction limited for the entire run (though PS2s at the time), so I think that's close to the lower limit of available traction to us on street tires.
... I should see if I can borrow his VBOX. I'm curious what my car can actually do, now
Old Tue, Jun-12-2018, 05:44:29 PM   #28
cozmo kraemer
cozmo kraemer's Avatar
Reputation: 0 cozmo kraemer is on a distinguished road
Did you ever get your timing/knock issue sorted? I know that you were waiting for the weather to warm up, but then I thought I saw that your car was all pulled apart again. I am thinking of retuning with the same tune you got, was just wondering if you ever figured out the issues.
2004 E46M3 - BBS RGR - RE11, BMW Motorsport 3.91, Eibach Pro Street S Coilovers (500/600), GC plates, SSV1 Headers/CPI slip fit catted/resonated section 1, Karbonious CSL intake, Shrick 280/272 cams, CSL DME Conversion, TTFS tune, OEM CSL front and rear seats
2010 - X5 4.8 Msport - the boring daily driver
My Journal
Previous - '95 M3, '94 FD RX7 (single turbo and LS6 swapped), '98 Integra Type R, '89 325i, '91 318, etc
Jump to top cozmo kraemer is offline   Reply With Quote
Old Tue, Jun-12-2018, 06:07:09 PM   #29
My interior is still all torn apart. I'm ~120 hours of work into this project. Might have been a fool's errand
Still, the end is finally starting to be in sight... and next time I drive the car, it'll be 100+ lbs lighter than last time I drove it, while still having a full interior and no loss of functionality!
But, no, didn't get it back to the dyno yet, since replacing the knock sensors.
Old Tue, Jun-12-2018, 06:20:15 PM   #30
M3_Dylan
Full of bad ideas
M3_Dylan's Avatar
Oh shit I didn't even realize one was post and one was pre, that is weird I used the hex editing tool (i forget the name of the software) and checked the disable o2 sensor box. I plan on getting an actual B spec tune next pay
Discussing I know this is lame but...Do I have a power loss in my M? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
