Old Sat, Jun-09-2018, 01:04:28 AM   #1
JitteryJoe
Default How do I wire this fan?
I'm installing a Zionsville radiator with an attached fan. I removed both the stock mechanical and electric axillary fan. Anyone know how I wire this new one up? There are two wires for the new fan and three for the stock electric fan (high & low?). I'm trying to do it this weekend and I'm afraid I won't get through to Zionsville until next week.
Thanks a lot! Joe
Jump to top JitteryJoe is online now   Reply With Quote
Old Sat, Jun-09-2018, 01:08:55 AM   #2
JPoland
Broken My Wallet
JPoland's Avatar
Reputation: 0 JPoland is on a distinguished road
Default Re: How do I wire this fan?
Thanks a lot! Joe
Good call on the Zionsville. Where you have those unterminated wires I have a connector that goes to a harness. That goes to an external relay. My radiator came with all this and a wiring diagram. Yours did not? Don't worry, we can get you squared away this weekend.
~Joe
Jump to top JPoland is offline   Reply With Quote
Old Sat, Jun-09-2018, 01:34:41 AM   #3
It should be brown (ground) and Blue (12v) if I remember correctly.
Old Sat, Jun-09-2018, 05:16:24 AM   #4
JitteryJoe
Mine is a single fan speed setup.
This is from Zionsville site:
"Auxiliary Fan Delete I.
This is the recommended approach. With this option, the SPAL electric fan is wired into the existing car harness and operates on the auxiliary fan circuit. However, to remove the factory auxiliary fan, one must dismantle the front end of the car. Itís a lot of extra work, but the results are worth it. This package includes the necessary wiring components for single (high) speed operation"
I think I just need to get the neutral and power off the old fan harness.
Thanks!
Old Sat, Jun-09-2018, 05:17:29 AM   #5
JitteryJoe
Thanks Braymond. I'll confirm with the Bentley book. I thought there was more to it but apparently not.
Old Sat, Jun-09-2018, 12:09:41 PM   #6
Are you using a fan wiring kit or modifying the stock aux fan wiring? If using stock wiring, bridge the sender to relay wires so the fan will start runing at the low temp. You can then bridge the power wires but Inthink it is also OK to use just the high speed power wire.
For new wiring, you can use the stock wires to trigger and power and ground a new relay and then use new wiring to ground the fan and power from the new relay to fan.
Or some combination of the above. Itís not complicated once you understand how it works.
Most important is to be patient and careful and thoughtful. For example, if using new wiring, ideally use a water proof relay/connector or put the new relay in a water proof area like the fuse box. And run and secure and crimp and splice and terminal and ground properly.
Old Sat, Jun-09-2018, 03:00:34 PM   #7
JitteryJoe
You completely lost me. Can I just connect the existing aux fan wiring to new fan?
Thanks!
Old Sat, Jun-09-2018, 04:57:24 PM   #8
mitch500
mitch500's Avatar
Reputation: 0 mitch500 is on a distinguished road
I just kept my aux fan In place and wired in the spal fan to the rad switch/spal relay.
97 E36 M3 Coupe Alpine white
s54 swap in progress
Jump to top mitch500 is online now   Reply With Quote
Old Sat, Jun-09-2018, 06:46:41 PM   #9
Don't stress doing a push/pull config with the aux fan in place. With it removed the cooling is quite good provided the puller spal is working.
Old Sat, Jun-09-2018, 09:11:18 PM   #10
JitteryJoe
I have only one fan, the new Spal. I'm not re-installing the original pusher aux fan. I can just wire the existing aux fan wiring to it? The three wire setup shown in the first post using just the 2 wires (brown & blue).
Thanks.
Discussing How do I wire this fan? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
