Old Thu, Jun-07-2018, 07:57:32 PM   #41
silvergray545
silvergray545's Avatar
Default Re: Streamline bumper thrown in the trash , OE one now fitted.
Originally Posted by Volke View Post
You're giving BMW way too much credit. The CSL box was designed back in like 2001. Take it from a hydraulics engineer, CFD simulation wasn't very good, user friendly or wide spread back then. It's pretty unlikely they even did any significant amount of it.
The only real thing that matters about the trumpets is the length and the diameter at the small end anyway. The diameter opening at the small end is restricted by having to fit up to the ITB, so that won't be any different. Unless they make the length significantly longer or shorter than the OE trumpets, which it doesn't look like they're doing, you will see zero difference in the dyno plots. Even if the length is a little different, all you will see is a small change in the RPM peak power/torque occur at. Shorter will shift the peak power a little to the right, and longer a little to the left. The trumpet opening or curvature isn't significantly different either.
The quality and fitment we will have to wait and see given their track record, but this OEM snobbiness about performance is pretty ridiculous.
Think about this for a second. Streamline can’t make a bumper fit right. To the point where the OP threw it away. You think this guy is going to beat a professional engineering team out of his garage? Everyone needs to stop thinking Streamline is the next best thing since the E46 M3.
2004 BMW M3 6MT - TiAg/Gray
2016 BMW M3 ZCP 6MT - AW/SO
2014 VW GLI 6MT - Black/Black
E46 M3 Build Journal
Old Thu, Jun-07-2018, 07:59:14 PM   #42
I think the idea is that any joe blow nowadays can model fluid dynamics on any ol' computer and achieve what Williams F1 did 2 decades ago.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · zero options · ~3200lbs · JOURNAL
_
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 S pipes 2.5" + 200 cell HFC · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pullies · WPC'd OE bearings · oil catch can · fan/SAP/washer delete · CSL battery
GroundControl S/A Koni (Hyperco/Eibach 300/550) + tall RSMs · Hotchkis front sway (med) · rear strut bar · TMS camber & subframe plates · SPC alum rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing · Mason clutch pedal + brass bushing · TMS black pedals · delrin brake pedal bushing
OE CSL trunk · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · 12mm/10mm F/R spacers · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack · Pioneer/CDT/Eclipse/Kicker
Old Thu, Jun-07-2018, 08:02:56 PM   #43
Volke
Reputation: 0 Volke is on a distinguished road
This. And we can do it faster too. For example, today we can do batch runs where you have the software automatically change a dimension in increments and spit out results for all of them. Very easy to optimize designs this way.
Making a large, awkward piece like a bumper fit consistently in production is a lot harder than making a small trumpet. It doesn't have anything to do with design. It's an apples and oranges comparison. No aftermarket company will ever meet OE fit quality because nobody can afford to spend as much on quality molds as BMW can. The larger the piece, the harder it is.
Peter
Mechanical Engineer
Jump to top Volke is offline   Reply With Quote
Old Thu, Jun-07-2018, 08:07:19 PM   #44
silvergray545
I’d be more than happy to take back what I said if Streamline proves me wrong. All I’m saying is, nobody needs to know fluid dynamics to make a bumper fit.
Sorry for the “OEM snobbishness” but it’s amazing when a product fits and works as intended. And this is coming from a person that has a ton of aftermarket products on their car.
Old Thu, Jun-07-2018, 08:28:20 PM   #45
Volke
For the curious, OE car bumpers are usually made with injection molding. It means they CNC machine a solid, inflexible, 2+ piece mold out of metal, put the 2 halves together and inject molten plastic into it. This is how they get consistent fit. The downside is that each mold costs likely over $50k, possibly over $100k for the set even. BMW can afford to do this because they will sell tens of thousands of the vehicles.
Aftermarket companies would be lucky to sell 10% of the BMW volumes, so they really can't afford this kind of investment. Aftermarket companies usually make a fiberglass mold using an original panel as the base and then lay the carbon fiber by hand into the mold. It's very hard to ensure a consistent output like this at a price people will actually pay. It's very hard to do. Body panels is one of those things that you're better off going OEM 80-90% of the time if you want a perfect fit.
Peter
Mechanical Engineer
Old Thu, Jun-07-2018, 08:33:46 PM   #46
BMWjunkie11
That guy
BMWjunkie11's Avatar
Reputation: 0 BMWjunkie11 is on a distinguished road
Aftermarket companies would be likely to sell 10% of the BMW volumes, so they really can't afford this kind of investment. Aftermarket companies usually make a fiberglass mold using an original panel as the base and then lay the carbon fiber by hand into the mold. It's very hard to ensure a consistent output like this at a price people will actually pay. It's very hard to do. Body panels is one of those things that you're better off going OEM 80-90% of the time if you want a perfect fit.
This is why I asked for a picture of the fitment. There are so many replica parts out there, some fit better than others. Yes I've seen plenty of threads about bad fitment but there are some companies who seem to produce some pretty good fitting reps. I guess I just want to see how far off it really was; I want to know if it was a little off or completely off the chart with the fitment.
2002 Jet Black/Grey ///M3
Full Supersprint Race Exhaust l PSDesigns Velocity Stack Kit l TMS Pulleys l TTFS Custom Alpha-N Tune l Work Brombachers
"Bags are for dead hookers"
Jump to top BMWjunkie11 is offline   Reply With Quote
Old Thu, Jun-07-2018, 08:55:19 PM   #47
ksa74f
ksa74f's Avatar
Reputation: 0 ksa74f is on a distinguished road
Scotland
For those asking how it fitted the pic below says it all.
We modified the crap out of the side brackets but still had a 10mm gap
Cheers Kev
Jump to top ksa74f is offline   Reply With Quote
Old Thu, Jun-07-2018, 09:31:34 PM   #48
cozmo kraemer
cozmo kraemer's Avatar
Reputation: 0 cozmo kraemer is on a distinguished road
These were some of the fitment pictures posted in the bumper thread by a customer that received and installed their bumper from the GB thread. This one looks to fit pretty good.
That 10mm gap above is definitely unacceptable.
2004 E46M3 - BBS RGR - RE11, BMW Motorsport 3.91, Eibach Pro Street S Coilovers (500/600), GC plates, Swaintech coated SSV1 Headers/SS catted/resonated section 1, Karbonious CSL intake, Shrick 280/272 cams, CSL DME Conversion, TTFS tune, OEM CSL front and rear seats
2010 - X5 4.8 Msport - the boring daily driver
My Journal
Jump to top cozmo kraemer is offline   Reply With Quote
Old Thu, Jun-07-2018, 09:38:30 PM   #49
///M Dream
Real Madrid C.F.
///M Dream's Avatar
Reputation: 0 ///M Dream is on a distinguished road
Don't think anyone here is saying that all of streamlines products don't fit. The glaring issue is that the consistency of their products is off. This is a larger and more evident problem when the company claims OE fitment, as Streamline did. Combine that with a terrible refund procedure and policy and you have a serious issue.
Current: 2006 Interlagos Blue ZCP ///M3
Past: F80 M3. E46 330i ZHP. B8 S4. E92 M3. E46 M3.
Jump to top ///M Dream is offline   Reply With Quote
Old Fri, Jun-08-2018, 03:25:54 PM   #50
BMWjunkie11
That guy
Not going to lie, I feel like once a bumper comes off from it's factory install, 9/10 times it won't go back on like they put it on at the factory, it's like the factory has some witchcraft to get the perfect fitment.
Joking aside, I can live with a little gap between the bumper and the light/fender, but not lining up properly would drive me insane; I mean in this picture it does not remotely line up, nevermind the gap, just look at how it won't line up. That it totally unacceptable at that price point. Maybe I'm to harsh, but I would have been very upset about this.
Discussing Streamline bumper thrown in the trash , OE one now fitted. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
