Old Wed, Jun-06-2018, 01:36:40 AM   #1
NolliM3
NolliM3's Avatar
Default Installing Braided Stainless Steal Lines
I have installed braided stainless steal lines on cars before...never had so much difficulty until this BMW car...can never seem to get the hard line to the stainless steal part seamlessly...I got one front and one rear done.
Is there some trick to connecting this? I have wasted valuable time monkeying...sometimes, it seems that it catches only to have it come apart as soon as placing the wrench on the nut...and this clip washer adds to the cursing!
Old Wed, Jun-06-2018, 08:05:35 AM   #2
M3AN
mmm... lovely!
M3AN's Avatar
New Zealand
Default Re: Installing Braided Stainless Steal Lines
Really? What brand?
Mine are UUC and just screwed directly on by hand then I tightened them up with the flare wrench.
Are you saying the thread is catching but you can't do it up any more by hand?
E36 ///M3 Coupe | S50B32 | 6 Speed | Estoril Blue | Lotus White | Alu Doors | Individual
18" BBS RC's | Bilstein B8 | Eibach Pro Plus | E46 Rack | Remus Exhaust | Simota Intake
Super Pro RTAB's | Vibra-Technics Mounts | X-Brace | Rally Road Strut Bar & Reinforcements
Old Wed, Jun-06-2018, 02:16:34 PM   #3
NolliM3
NolliM3's Avatar
Originally Posted by M3AN View Post
Really? What brand?
Thanks M3AN for responding. Yes, it's StopTech and I have used that brand before on other cars. Yes, I would start threading by hand...then, it feels as if it catches...put the flare wrench on only for it to come apart again...not sure whether it's the brand, which is a popular one.
Old Wed, Jun-06-2018, 02:38:54 PM   #4
Are you fighting the spring clip? I donít really have any advice, but I have struggled with them before as well due to the spring clip. You just have to line the two parts up as square as possible so the threads line up and be patient Use a regular wrench instead of a flare initially if that helps. If you have a rethreader you could attempt to use it on the hard line. Might be M10x1.0 but not sure. Could be the first thread as messed up or worn badly and not catching.
Old Wed, Jun-06-2018, 08:09:33 PM   #5
NolliM3
NolliM3's Avatar
Originally Posted by pbonsalb View Post
Are you fighting the spring clip? I don’t really have any advice, but I have struggled with them before as well due to the spring clip. You just have to line the two parts up as square as possible so the threads line up and be patient Use a regular wrench instead of a flare initially if that helps. If you have a rethreader you could attempt to use it on the hard line. Might be M10x1.0 but not sure. Could be the first thread as messed up or worn badly and not catching.
Yes Phil, the spring clip is winning too. I actually bought some rethreaded tools just to tackle the front passenger side, which cost me a whole afternoon of fighting. So, I left that for last to do other stuff. Yesterday, I attempted the rear and the passenger side completed with just minor cursing...then, the driver side just wouldn't take. It just seems that I could never duplicate what I did on the two that are completed.
Patience is really the key; however, when it seems that it catches but didn't really, frustration takes over.
Old Thu, Jun-07-2018, 01:36:00 PM   #6
englishtom1596q
englishtom1596q's Avatar
Make sure the SS line is fully seated in the bracket on the car. They have little tabs that need to seat fully. Doing this will mean you won't fight the spring clip. Then I move the hard line nut out of the way and put just the hard line in so you can clearly see if its lined up straight. Then move the nut in and tighten.
Jump to top englishtom1596q is online now   Reply With Quote
Old Fri, Jun-08-2018, 02:11:24 AM   #7
NolliM3
NolliM3's Avatar
That's the problem with the StopTech SS lines...they don't have the tabs...bummer!
Old Sat, Jun-09-2018, 03:36:33 PM   #8
_JohnnyD_
Reputation: 0 _JohnnyD_ is on a distinguished road
I installed all 6 StopTech SS lines in the spring. Not having the tabs or barbs does make it more difficult. I seems like you need 3 hands. The trick Tom mentioned worked really well for me. Sliding the nut up the hard line so that you can align the hard line with the SS line makes a big difference.
Good luck!
Jump to top _JohnnyD_ is offline   Reply With Quote
Old Sun, Jun-10-2018, 03:53:11 AM   #9
NolliM3
NolliM3's Avatar
Good luck!
Talk about needing three hands, only one left to do...the front passenger side and it might be buggered...thanks for wishing me good luck.
Old Sun, Jun-10-2018, 11:32:42 AM   #10
Pull the hard line out, gently. Remove the spring clip. Try threading the ďboltĒ into an m10x1.0 nut or even into the Stoptech line. See if you can do it without the pressure of the spring clip interfering with getting the threads started. Itís a confidence building exercise.
Discussing Installing Braided Stainless Steal Lines in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
