Old Fri, Jun-01-2018, 01:10:24 AM   #11
RisBMW
Reputation: 0 RisBMW is on a distinguished road
Default Re: Anyone running 245/40/17s?
Thanks folks... ordering PS 4s from Costco.
$184+ tax/ea out the door. Heck, if I have issues I don't feel like fixing I can always return them.
But Dad it's PURPLE!!!
"Some days you're the Statue and some days you're the Pigeon"
Jump to top RisBMW is offline   Reply With Quote
Old Fri, Jun-01-2018, 03:09:43 AM   #12
Nate047
Nate047's Avatar
I would get some small spacers just in case, dunno how much of a drop those springs provide but you may have some additional negative camber in your future too. Either way, it will make the car look and drive better soooo...
Old Fri, Jun-01-2018, 03:11:20 AM   #13
NolliM3
NolliM3's Avatar
Originally Posted by westopher View Post
There is no chance of rubbing in the rear unless something is damaged or aligned horribly. Stock is 245/40 on 17x8.5et 41 on later model e36 m3s. Front is dependant on your coilovers/suspension set up. It’s likely you will have no problem there either though that can’t be solved by spacers if you have a coil setup that will cause rubbing issues.
I had rubbing in the rear, but then, the suspension was very gone!
Old Fri, Jun-15-2018, 02:00:05 AM   #14
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
I do run a small spacer up front of 3mm
Topo Chico
Old Fri, Jun-15-2018, 01:00:50 PM   #15
Cosmos Kramer
1 of 999
Cosmos Kramer's Avatar
Reputation: 0 Cosmos Kramer is on a distinguished road
I'm running 245's all around on square stock wheels with no rubbing on H&R OE Sports.
'98 Cosmos 3/4/5
Jump to top Cosmos Kramer is offline   Reply With Quote
Old Fri, Jun-15-2018, 01:23:26 PM   #16
ZiMMie
Reputation: 0 ZiMMie is on a distinguished road
Germany
Op shouldn't have any problems with that size..
Sent from my Redmi Note 4 using Tapatalk
#E36S54 #CSLWannabe #TTFS @Mykesf
Jump to top ZiMMie is offline   Reply With Quote
Old Fri, Jun-15-2018, 01:44:32 PM   #17
TXBDan
Reputation: 0 TXBDan has disabled reputation
People have been running 245/40/17s on E36s for about 24 years...
Jump to top TXBDan is offline   Reply With Quote
Old Fri, Jun-15-2018, 02:18:58 PM   #18
bluptgm3
Default Anyone running 245/40/17s?
1995M3 245/40-17 (street tires) on 8.5” ET41 up front, close but no spacer.
1996+M3, the wheel will contact the strut just slightly and tire will rub hard due to Spindle/King Pin/FLCA/FLCAB/Guide Support geometry change.
Old Fri, Jun-15-2018, 05:58:43 PM   #19
TXBDan
Right, so throw a spacer up front. It's practically default.
Discussing Anyone running 245/40/17s? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
