Old Tue, Jun-05-2018, 07:07:54 PM   #21
Default Re: P1188 P1189 - Long list of tests and repairs and no end in sight. Really need hel
Originally Posted by m3arod View Post
You're a very positive and uplifting individual in all of your posts. Hope you continue to being that awesome person. .
What is so hard to understand? You use knock off parts described as Genuine and come ask others to chase your issue for you. Use real parts.
Old Tue, Jun-05-2018, 08:54:27 PM   #22
JaBron_Lames
Reputation: 0 JaBron_Lames is on a distinguished road
You will learn, as every single other person on this forum has come to realize over the last 10+ years, how to parse the information from the message when it comes to the delivery from certain individuals. The knowledge does not come without the "charm" lol.
Jump to top JaBron_Lames is offline   Reply With Quote
Old Wed, Jun-06-2018, 09:09:59 AM   #23
M3AN
321 fun...
M3AN's Avatar
New Zealand
That's not only a rule for here either, that's just Internet 101.
If you can't handle the jandal you're not qualified to drive a browser.
E36 M3 | Estoril | Coupe | S50B32 | 6MT | Remus | BBS | Bilstein | Eibach
Old Wed, Jun-06-2018, 11:34:53 AM   #24
Failure to use Genuine OE or OEM parts will result in less than optimal performance. This is a no brainer.
I donít think this is true for all aftermarket parts. But it is very often true for HFMs and cam sensors and some other parts. It is probably safest to use only BMW or the OEM supplier to BMW, but if you do some research you can find aftermarket alternatives that work fine. These cars are 20-25 years old so a vast amount of info on what parts work or what parts work best is available.
Old Wed, Jun-06-2018, 03:52:16 PM   #25
Whether alternatives are okay or not, what he stated was OE BMW— which it wasn’t.
Old Tue, Jun-12-2018, 03:42:30 PM   #26
m3arod
Reputation: 0 m3arod is on a distinguished road
It was my mistake for putting OEM, it was sold to me as if it was "OEM" . And no one wanted anybody to chase a thing, just was looking for suggestions. Once again thank you for those that actually try to help
Jump to top m3arod is offline   Reply With Quote
Old Tue, Jun-12-2018, 03:57:44 PM   #27
jcasaccio
SuperOldSchool
Reputation: 0 jcasaccio is on a distinguished road
I've put 211 miles on the M3 since friday without a CEL in sight. I came into the shop and checked the live data and the fuel trims are looking good as well. It's blown my mind because I had replaced that MAF about a month or 2 ago and from the live data seemed to be working just fine. But obviously something was wrong with that Bremi MAF I had put in there. I now have a VDO MAF and the vehicle seems to be running perfectly fine. jcasaccio I'd give it a shot, trust me I know how much of a pain its been to figure it out!
Thank you, M3arod! Iím waiting for the injectors to come back from cleaning/ refurb and need to get it all back together for a test drive. I have some negative trims so the jnjectors could be sticking/ leaking. Iíll report back when Iím done.
Jump to top jcasaccio is offline   Reply With Quote
Old Fri, Jun-22-2018, 04:36:41 AM   #28
jcasaccio
SuperOldSchool
Got the injectors back, but havenít had time to install- will be a week or so...
But.... flow results were not what I hoped for. Hoped to see sticking or poor flow. They were not in that bad of shape. Not bad enough to cause my codes, I think. Wonít know until back on the car.
Though PO had fuel pressure tested, I ordered a gauge and will test FP/ FPR...
I also soaked the MAF connector in vinegar - it had some corrosion, which could be doing something... will report back once itís back together
Old Fri, Jun-22-2018, 04:06:11 PM   #29
jcasaccio
SuperOldSchool
One more... I’m not convinced there is not a fuel pressure regulator issue....
If I apply vacuum to the FPR via the hose the connects to manifold, Shoults it hold vacuum or will it bleed off? I am thinking if the FPR or hard plastic line to FPR is bad, I may be getting an air leak there...
Thanks!
Old Fri, Jun-22-2018, 08:54:35 PM   #30
It should hold vacuum.
What is your fuel pressure at idle?
Discussing P1188 P1189 - Long list of tests and repairs and no end in sight. Really need help in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
