Old Fri, May-18-2018, 01:10:18 PM   #1
m3arod
Reputation: 0 m3arod is on a distinguished road
Angry E36 M3 Fuel Trims stuck at -8.1
Hey guys I own a 1998 M3 coupe and I continue getting Fuel deviation codes for both banks. I've replaced both pre cat o2 sensors, cvv w/ hoses, maf, and intake boot. Before I replaced the o2 sensors only codes i had were for them. Now that they're replaced I have the fuel deviation codes and when I look at live data all readings from o2 and maf are correct but when I go to the fuel trims they're stuck. I have Noticed I'm going through fuel alot faster recently, PLEASE any help or suggestions will be appreciated!
Jump to top m3arod is offline   Reply With Quote
Old Fri, May-18-2018, 04:48:28 PM   #2
Default Re: E36 M3 Fuel Trims stuck at -8.1
What injectors and tune?
Old Fri, May-18-2018, 06:16:42 PM   #3
m3arod
Stock dme software and stock injectors.
Old Fri, May-18-2018, 06:54:53 PM   #4
What O2 sensors did you use?
Old Fri, May-18-2018, 07:10:06 PM   #5
m3arod
NTK O2 Sensors
Old Fri, May-18-2018, 07:19:54 PM   #6
JitteryJoe
Does it matter is the pre-cat sensors are reversed? Asking 'cause I don't know if that could be an issue.
Old Fri, May-18-2018, 07:45:58 PM   #7
It matters, yes. Front header to rear harness plug and rear header to front harness plug.
Old Fri, May-18-2018, 07:50:18 PM   #8
m3arod
Yeah I've confirmed the O2 sensors are connected to the correct location
Old Fri, May-18-2018, 10:20:27 PM   #9
frbz
The S50b32 is a euro only engine, does your software recognize the US S52 engine?
Jump to top frbz is offline   Reply With Quote
Old Fri, May-18-2018, 10:53:25 PM   #10
That’s a Snap-On unit. It’s reading through the OBD2 port. Euro cars don’t even have that. Every OBD2 outputs the same, it’s a set standard. The values are likely showing correctly.
Discussing E36 M3 Fuel Trims stuck at -8.1 in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
