Old Sun, May-13-2018, 10:38:33 PM   #1
NolliM3
NolliM3's Avatar
Default Insulation Underneath and Around Transmission
What you all do with this insulation underneath the car around the transmission? It's leaking some stuff that looks like sawdust or in might be fiberglass...it's driving me crazy while I am removing the transmission bolts...getting in my eyes, nose, and mouth as well as on my skin. That's another bad design, especially for people with allergies such as I.
What you all replace it with? Most of the insulation I have seen so far seems to be for in the cabin. Those that do without any insulation, do you find that it gets hotter in the cabin?
Old Sun, May-13-2018, 11:05:15 PM   #2
TheJDub-E36
TheJDub-E36's Avatar
Reputation: 0 TheJDub-E36 is on a distinguished road
Default Re: Insulation Underneath and Around Transmission
I used this http://Rust-Oleum 248656 Automotive ..._Erm-Ab58Z4G22
Simple green to clean everything and 3 to 4 coats.
Jump to top TheJDub-E36 is offline   Reply With Quote
Old Mon, May-14-2018, 02:11:54 AM   #3
Remove it all. Use DEI or similar fiberglass reflective heat tape or heat mat. This is very thin stuff. Works fine. Did mine years ago.
Old Mon, May-14-2018, 04:04:35 AM   #4
avusblu_e36
hmm I just ripped all mine out a while ago..... all seems fine.... Should I put something there ?
Jump to top avusblu_e36 is offline   Reply With Quote
Old Mon, May-14-2018, 11:14:58 AM   #5
If you do not reflect the transmission heat you will feel it through the tunnel
In hot weather. It may not bother you. The factory stuff may deaden sound a little as well as insulate from heat.
Old Mon, May-14-2018, 03:08:48 PM   #6
NolliM3
NolliM3's Avatar
Just perfect...thank you Phil!
Old Mon, May-14-2018, 09:02:54 PM   #7
englishtom1596q
englishtom1596q's Avatar
Cut mine out.. Doesn't make a damn bit off difference
Old Mon, May-28-2018, 02:10:44 AM   #8
Eric M3
shogun
Eric M3's Avatar
Reputation: 0 Eric M3 is on a distinguished road
Japan
my one was hitting the giubo, fixed it 3 years ago, as I have a pit and a transmission jack, it made it easier for us. Exhaust must come off. So we loosened the 6 copper nuts M10 in the front (had 6 new of them) , but did not take them off the bolts, so the exhaust was secured in the front but movable downwards, rear and middle we took off the brackets/rubbers and with the trans jack we lowered the exhaust so far, that we could pull out the silver color metal shroud between exhaust and driveshaft towards the rear, the wires from the O2 sensors were long enough, so even no need to disconnected the O2sensors.
The 'fiber' mat was already damaged from the giubo and the fibers came down, so no change to fix it somehow. So I used a cutter knife and scissors and cut all from the old fiber mat from the end of the trans housing - above giubo - driveshaft off, so all of that mat above/around the giubo and driveshaft is gone now, no more noise. No need to cut much, maybe around 10-15cm width.
To renew the mat complete without taking out the trans seems to be impossible, no access above the transmission.
here some solutions:
some make a spring bracket
others use magnets https://redeyegarage.com/blogs/news/...lever-solution
or aftermerket heat insulation
cut it out
This it is NOT a heat insulation, it is a sound insulation and it does not matter if you cut a portion of it off: P/N 51481977019
The factory insulation (P/N 51481977019) covers the transmission tunnel and firewall. On the firewall it's pinned behind the right front brake hard line. Other items in the way: clutch hard line, fuel lines, power brake booster, ABS pump, heater control valve, throttle cable, fuse box. Basically, replacing the mat with a new factory part means removing the engine + transmission and many other things. That piece of insulation is probably the first thing that goes onto the body during assembly.
My 7 series DIY site: http://twrite.org/shogunnew/topmenu.html
Jump to top Eric M3 is offline   Reply With Quote
Old Thu, May-31-2018, 06:28:06 AM   #9
Versingetrix
Versingetrix's Avatar
Reputation: 0 Versingetrix is on a distinguished road
No interior, no fiber crap underneath, and yeah the trans tunnel gets a bit warm on track...because race car!
Jump to top Versingetrix is offline   Reply With Quote
Old Thu, May-31-2018, 03:01:58 PM   #10
Aeko
Aeko's Avatar
Reputation: 0 Aeko is on a distinguished road
I'm quite positive it is fiberglass which you REALLY should not be getting in to your eyes, nose, or mouth... if you have issues with allergies that bad don't even think about messing with it without gloves, a full face shield, and respirator (this is what I did).
The BMW part description says it is sound deadening material, however I'm sure it does help insulate heat. The suggestions these guys had for the metallized tape is probably the best if you feel the need to replace it. I didn't replace mine and I don't notice a difference. Most people I've seen don't.
Jump to top Aeko is online now   Reply With Quote
Discussing Insulation Underneath and Around Transmission in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
