Old Tue, May-01-2018, 02:38:33 AM   #1
SQ13
Default Clutch pedal leaning left—what parts should I replace?
This is my list of parts:
OE clutch pedal (35311158659)
Pedal assembly locking pin (35311158661)
Tension spring (35211158489)
Clutch pedal return spring (21522227764)
Garagistic bronze clutch pedal bushings
Is there anything else that needs to be replaced? Looking at RealOEM, it appears that the pedal assembly locking pin was replaced by a two-piece part (10 to 2x 14)? Should I get two of part 14s instead?
Any reason why I shouldn't give Garagistic my money? Their product and shipping prices seem fair.
Old Tue, May-01-2018, 03:57:59 AM   #2
Default Re: Clutch pedal leaning left—what parts should I replace?
Just the pedal and the bushings. Skip the other parts you selected, they don’t wear.
Old Tue, May-01-2018, 06:36:21 AM   #3
bluptgm3
And you might get by only replacing the bushings.
Old Tue, May-01-2018, 03:01:19 PM   #4
SQ13
Thanks. Will do.
The pedal is old and made of plastic. I might as well replace it since it’s cheap. My E46 pedal has a slight lean, and it’s has fairly new delrin bushings btw.
Old Sun, May-06-2018, 02:06:20 AM   #5
betrezra
I did the metal aftermarket clutch pedal, with new bushings, and new clutch master cyl. GL. A proper working clutch pedal/and shifter MAKE this car.
1999 E36M3 5spd
2001 360Modena 6spd
2018 M2 DCT
Old Sun, May-06-2018, 03:54:35 AM   #6
SQ13
Mason? I'm selling the car soon, so I don't need/want to put fancy, expensive parts on it.
Old Mon, Jun-04-2018, 06:12:37 PM   #7
SQ13
I replaced the pedal and bushings, and it’s much better now but there’s still a slight lean. I don’t know what these cars were like new...is this normal?
I can actually use the clutch stop now, and there are no issues with operation. When depressed, it goes straight down now, instead of going to the left so that’s good. Just wondering if I did something wrong or if there might be a damaged part that needs to be replaced.
Old Mon, Jun-04-2018, 06:44:12 PM   #8
Texaz3
Looks about right to me.
Old Mon, Jun-04-2018, 06:56:57 PM   #9
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
Any noise when depressing it? If it functions properly...
Topo Chico
Old Mon, Jun-04-2018, 09:03:36 PM   #10
wgknestrick
Reputation: 0 wgknestrick is on a distinguished road
This noise is generally eliminated once you swap the M3 compression spring
assembly out for the normal tension spring.
The geometry and mechanics of the M3 clutch spring setup are poor because they don't act in "plane" of the pedal arm. They are offset to one side, eventually causing the clutch lean and squeak. You do gain a bit of clutch pedal force with the tension spring though.
Jump to top wgknestrick is offline   Reply With Quote
Discussing Clutch pedal leaning left—what parts should I replace? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
