Old Sat, Apr-28-2018, 10:15:42 PM   #1
Ajcanadian
Reputation: 0 Ajcanadian is on a distinguished road
Default E36 M3 heater vaders not working
HI guys, I picked an e36 m3 that sat for a year or so and ever since buying the car the heated seats haven't worked. What should I look for? The panel with the heated seat button lits up when they are pressed. I have manual vaders
Jump to top Ajcanadian is offline   Reply With Quote
Old Sat, Apr-28-2018, 10:44:26 PM   #2
Default Re: E36 M3 heater vaders not working
Continuity test the upper and lower pads. Open circuit = dead heating pads.
Old Tue, May-22-2018, 08:01:32 AM   #3
trading10
Reputation: 0 trading10 is on a distinguished road
If you come up with a good solution to replacing the heating pads, please post here. I watched a video of a guy pulling the covers off vaders, and the ones with the 3 padded slats in the seat and lower back area are not easy to deal with. Replacing the heating pad looks like a pita to me, not to mention expensive, and getting the cover to fit back on there like factory might be nearly impossible. Ymmv.
Jump to top trading10 is offline   Reply With Quote
Old Tue, May-22-2018, 10:31:05 AM   #4
bhennrich
bhennrich's Avatar
Reputation: 0 bhennrich is on a distinguished road
I bought the replacement heating pads from BMW Parts and took the seats to a local auto upholstery shop. They only charged 1 hr labor to replace the heat pads. Just make sure you have spare attachment pieces for the plastic base of foam to seat pan, they are basically one time use if old and brittle
Jump to top bhennrich is offline   Reply With Quote
Old Tue, May-22-2018, 01:07:45 PM   #5
wgknestrick
Reputation: 0 wgknestrick is on a distinguished road
That was super cheap considering you have to remove 4 cushions and covers. I don't think I could've done it much below 2hrs. A tip for the bottom clips is to get a big screw driver to pry up on the rear corners where the clips are. They should pop right out once you know where they are and can apply a decent upward force to them.
Jump to top wgknestrick is offline   Reply With Quote
Old Tue, May-22-2018, 07:16:15 PM   #6
bhennrich
bhennrich's Avatar
I removed the cushions and just took them with the new heating pads to the shop. When they were done I reinstalled them. But I swapped sides to get the bolster wear to the inside of the car. Looks better and works flawlessly
Old Fri, May-25-2018, 01:07:23 AM   #7
trading10
I was already found a local upholstery shop with plans to have them thread some new stitching on the drivers side bolster. I can ask if they would do that and replace the heat pads. Glad to hear you got yours done so inexpensively.
Did you consider aftermarket heat pads? I don't know anything about that, but am curious if non-OE is a good choice.
Old Fri, May-25-2018, 01:09:05 AM   #8
trading10
I didn't know swapping cushions was possible. My passenger seat is in great shape - it's just the drivers side that is a hot mess. Both need the heating pads replaced. Thanks for the tip.
Old Fri, May-25-2018, 01:16:27 AM   #9
bhennrich
bhennrich's Avatar
Backs, bottoms, and headrests are identical. the heating mat for the bottom flips over depending on the side so the power connector is in the correct position.
Old Thu, May-31-2018, 07:32:43 PM   #10
Ajcanadian
I might have had a loose connection or maybe a miracle happened. I used to keep my heated seats on all the time through wintee and one day my bottom end felt like it was on fire. So I guess I lucked out
Discussing E36 M3 heater vaders not working in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
