Old Fri, Apr-13-2018, 08:37:31 PM   #11
Turb02
Turb02's Avatar
Default Re: BBS CH curb repair and respray
They haven't been wetsanded or cleared at this point, but will be all done together when they're all ready for that stage in the process.
Sent from my Pixel using Tapatalk
NOT NARDO
Active Autowerke Stage 2.5-AA Headers-Supersprint-Meisterschaft-Vorsteiner-Brembo-AC Schnitzer-BBS-CSL
6MT swapped-RTD shifter-Amber Gang
Jump to top Turb02 is offline   Reply With Quote
Old Fri, Apr-20-2018, 11:26:08 PM   #12
Turb02
Turb02's Avatar
Clear coat is still wet, but it's getting closer!
NOT NARDO
Old Sat, Apr-21-2018, 02:56:34 AM   #13
Turb02
Turb02's Avatar
Wheel 4
I love this color!! OEM BMW color should look secksy against TiAg
NOT NARDO
Old Sat, Apr-21-2018, 04:27:57 AM   #14
Turb02
Turb02's Avatar
Last pics before wetsanding...
NOT NARDO
Old Sat, Apr-21-2018, 03:40:10 PM   #15
kokgo20
kokgo20's Avatar
Are you planning on polishing after wet sanding?
Build thread
Old Sat, Apr-21-2018, 03:44:26 PM   #16
Turb02
Turb02's Avatar
Depends on if I finish respraying my hood before getting to the polish step for the wheels. I miss driving my car and it's been in pieces for way too long.
Weather is getting nicer and I just want to drive.
NOT NARDO
Old Mon, Apr-23-2018, 04:12:44 AM   #17
rbg
Reputation: 0 rbg is on a distinguished road
Nice job! Did you prime the edge after sanding?
BTW, how do you like DWS06? I am choosing between DWS06 and A/S3+ now. Costco has pretty good deal on A/S 3+, but DWS06 should be better all season I guess.
Jump to top rbg is offline   Reply With Quote
Old Mon, Apr-23-2018, 03:26:34 PM   #18
AttaQ
Reputation: 0 AttaQ is on a distinguished road
Love the color, nice job!
Jump to top AttaQ is offline   Reply With Quote
Old Fri, Apr-27-2018, 07:48:18 PM   #19
Turb02
Turb02's Avatar
Thanks! Learning is expensive though. I could have had a professional refinish them for much less than what I have in them so far...but it's fun.
Here they are in direct sunlight. Well, 3 of them. I had to start over on one of them.
NOT NARDO
Old Fri, Apr-27-2018, 08:18:31 PM   #20
oceansize
Kwisatz Haderach
oceansize's Avatar
Looks as though it turned out great. You sound like me. It starts off with this thought "I will save myself money and do it myself" and then by the time I'm done "learning" and generally screwing things up plus buying/renting tools I could have paid someone to do it. Oh well, nice sense of satisfaction when done.
2003 M3 Convertible SMG w/Hardtop | GC Coilovers and Camber Plates 500/600 | ESS VT1-475 Gen 3 Supercharger | Stoptech Brakes
Apex ARC-8 19" Hypersilver | CSL SMG (and 255) Tune | Rogue Eng. Diablo Exhaust w/ SS Tips | Rogue Eng. Rasp Pipe
Discussing BBS CH curb repair and respray in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
