Old Wed, Jun-13-2018, 11:39:46 PM   #11
grannyknot
Reputation: 0 grannyknot is on a distinguished road
Default Re: E46 M3 throttle balancing
Originally Posted by BBRTuning View Post
I just did this on my S54 for the hell of it, having recently had experience doing this successfully on Porsches at work.
I used a Redline-Weber synchrometer tool to measure actual airflow. Cylinders 1-5 were within ~1.0 kg/h of each other, but cylinder 6 was almost 3 times the others. (many say 0.5 kg/h maximum variance is acceptable).
I was surprised to find this considering that, as you said, the throttles are all connected via a common air rail. I suspect that the air rail does cause some improvement in balance but that significant variances can still show up. The engine of course wants to consume much more air than it is being “allowed” to by the throttles, even at idle, so a particular cylinder with a further-open throttle blade will consume more air. I also believe that the air rail is in a sense self-balancing, within itself, so that it will feed very close to equal air to each cylinder, regardless of individual throttle angles.
Anyway, I was able to get them all to within 0.2-0.3 kg/h without much trouble. As I have a stand-alone ECU, I temporarily disabled the IAC and ran the engine from the throttles only (about 1% opening required for 1000 RPM idle), although I did leave the air rail in place. While this wouldn’t be an acceptable condition to sync the throttles (as the individual throttle sync adjustments are essentially the throttle stops, and at this point the throttles would all be pulled off the stops), I was able to confirm that airflow stayed pretty well balanced even as the throttles open.
I come from the days of balancing each throttle body individually with vacuum ports and adjusting screws but since the s54 doesn't have provision for that am I right to assume you are balancing T/B on your laptop through your standalone ECU?
Jump to top grannyknot is offline   Reply With Quote
Old Sun, Jun-17-2018, 05:06:30 AM   #12
BBRTuning
BBRTuning's Avatar
Reputation: 0 BBRTuning is on a distinguished road
The S54 has adjustable throttle stop screws for each throttle. From the factory the screw heads have black plastic covers on them. The synchrometer tool simply measures airflow through each throttle, and the stop screw is mechanically adjusted so that each throttle is flowing the same amount of air at idle. No electronic adjustment is done, or is possible, since all 6 throttles are controlled by the same throttle linkage and actuator.
///BBRTuning | 2001 LSB M3 6MT | AEM Infinity + flex fuel tuned by me | JE 11.5/Carillo S54 by Pure Performance | Moton Motorsport 3WR + rear coilover, 700/450, no rear bar | Stoptech Trophy BBK 6F/4R 355x32 | Apex SM-10 18x10+25 (x4) | BMW M 4.10 | Turner monoball FCAB/RTABs | Turner lower-rear + Wisefab upper-rear adj. arms | Z3 rack | Lang Racing CF roof | Sparco Evo2 (x2) | AP Race roll bar | full interior 3310lb wet
Jump to top BBRTuning is offline   Reply With Quote
Old Sun, Jun-17-2018, 03:09:51 PM   #13
Even on the stock DME you could do this, as I found that even running the car as standard (off the IAC with the throttles closed at idle) showed enough cylinder-to-cylinder variance to make it worth adjusting. You should be able to start up the car with the airbox removed on the stock DME; you'll probably want to unplug the MAF so the car runs in an "Alpha-N" mode so it will idle.
I bought the standard Redline-Weber synchrometer. The S54 throttles are 50mm ID so any tapered-shape synchrometer made for throttles in that size range should be fine.
I have had some limited success disabling the ICV with the stock ECU. Works for the most part, but have some stalling issue. Might be good enough to make the adjustment work better though?
Old Sun, Jun-17-2018, 03:18:06 PM   #14
bigjae1976
Hmm...would an ICV delete be possible for a track only car?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Discussing E46 M3 throttle balancing in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
