Old Thu, May-31-2018, 06:27:43 PM   #281
Nate047
Nate047's Avatar
Default Re: My 99' Hellrot intro
Originally Posted by EYEHAVEYOU View Post
Your ring pictures are amazing! Thanks for sharing
Thank you!
Old Thu, May-31-2018, 08:17:41 PM   #282
Texaz3
lol @ shoes comment I'm a big fan of animal prints.
I like it.
Old Sun, Jun-03-2018, 10:09:57 PM   #283
Nate047
Nate047's Avatar
Got around to putting the new BimmerWorld race wheel studs on yesterday, we ended up being able to remove the broken one from inside the hub pretty easily so that's nice. The rotor had to come off but it was pretty easy to get the broken end of the old stud out with a drill.
Time to do the wheel bearings... Knew it was time anyway but no more delaying.
Same same but different, loving these wheels for track. Gotta get these tires off though...
Damage on the right rear from when the studs broke. Wheel came loose, tire dug into the 3/4 panel and ****ed it up a bit. Kind of hard to see but the two layers separated and the paint got burnt a bit. I don't really care about the paint (car is a real 10-foot special to be honest) but I want to make sure it doesn't rust, AND I need to pull the panel so it's doesn't present a danger to my rear tire. I'm hoping this can be fixed by hammering it back and using the same kind of original body filler/adhesive/whatever you call it that BMW used. Gonna bring it in this week...
Old Mon, Jun-11-2018, 09:57:57 PM   #284
Nate047
Nate047's Avatar
Ugh, car is needing more work than I thought...
Looks like I need to do the valve cover gasket, and something is slowly leaking in the cooling department. I'm not 100% sure where it's coming from, it looks like the coolant overflow tank, but what do you guys think? I don't see any signs of a leak around the water pump or thermostat. Looks like it's dripping from the expansion tank onto the hose and then spraying back into the engine compartment.
Just thinking about what I need before I start taking things off. My plan is the following. LMK what you guys think and if there's additional things I should do "while we're in there" :
Z3M 3-core radiator (existing rad is theoretically about 40k miles old)
New hoses and clamps
New coolant overflow tank (existing one is only 20k miles old, but it's fairly cheap and appears to be leaking)
Coolant tank sensor...?
Valve cover gasket (someone have a list of all the essential replacement items for this job?)
BimmerWorld electric fan conversion
Already done:
Stewart water pump (20k miles)
Thermostat
Chain tensioners
Overflow tank
VANOS
Also the car has been starting more and more rough lately, I was thinking I would inspect the spark plugs and replace if necessary, have my injectors cleaned, clean the MAF and lastly look at the coil packs. Thoughts?
Front wheel bearings still need to be done too. Fuuuuu, the list...
Old Wed, Jul-18-2018, 07:46:36 AM   #285
Nate047
Nate047's Avatar
Finally got around to wrenching a bit... Few weeks ago I did a new rad, overflow tank, hoses, etc... So it's not leaking anymore. Exciting mods!
Did the wheel bearings today. With help from my boy Marc at Bavarian Workshop of course (who am I kidding, he did all the hard work and I pretended to help)
Bit 'o grease all over my shit...
Whole process went easy as hell with the right tools, and a shop, and a lift... Shocking right?!
Next up, track this weekend. It'll be hotter than Satan's buttcrack but it will be fun to throw her around a bit.
THEN, I think next week we'll do the dual fuel pump setup, electric fan conversion, and the damn splitter that has been sitting in my storage until for the last year or whatever. We're going to use Brett's write up as a baseline, I do plan on using the OEM bumper carrier chassis mounts as well so I think some cutting of the MM panel is in the future. I am also excited to get Brett's gurney flaps on the car. Only reason I've been waiting on those is because I don't want to add more rear downforce without some help up front. I think with the flaps and splitter, a couple of fresh trim pieces, and a good detail, this old turd might look presentable yet...
Old Wed, Jul-18-2018, 04:46:51 PM   #286
zerofks
Reputation: 0 zerofks is on a distinguished road
love that color, it's really close to red.
Jump to top zerofks is offline   Reply With Quote
Old Wed, Jul-18-2018, 04:59:57 PM   #287
Nate047
Nate047's Avatar
Heh, that's just me being dumb with IG filters. Color is original, Hell Rot.
Old Wed, Jul-18-2018, 05:45:55 PM   #288
Texaz3
Nice. I just did front wheel bearings on my e46. That 46mm axle nut socket is pretty gigantic! The hardest part was....undoing rotor screws. Mine were stuck so bad, had to drill them out. What a pain.
Old Sun, Jul-22-2018, 06:24:11 PM   #289
Nate047
Nate047's Avatar
Yea man it's always the dumb stuff that ends up being the biggest pain in the ass.
Or, it's the dumb stuff that makes you laugh the hardest. I saw some shit fly in front of me on track yesterday, I thought nothing of it (figured it was a piece of paper or something) buuuuuut as it turns out, the heat got the best of the adhesive...
Old Sun, Jul-22-2018, 08:25:39 PM   #290
NolliM3
NolliM3's Avatar
The badge sits in a grommet that secures it...I even buggered my paint slightly when I changed mine...get the grommet (51141807495).
Discussing My 99' Hellrot intro in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
