Old Wed, Jun-22-2016, 02:55:39 PM   #21
TheM
Reputation: 0 TheM is on a distinguished road
Default Re: Titan Shadow trim repaint
Originally Posted by BTB View Post
I used 800, 1500, and 2000 grit sandpaper on mine, which I think is plenty smooth. Can be found at Walmart, 3m wet or dry. I also had some lower grit stuff to take off the stock finish.
There's no reason to go so fine before painting. 1500 and 2000 is so smooth that there's virtually no micro scratches for the paint to grab onto. Go with the coarsest that won't show scratches when done. In fact, my final sanding was done with 600 grit.
Jump to top TheM is offline   Reply With Quote
Old Wed, Jun-22-2016, 03:16:14 PM   #22
BTB
BTB's Avatar
Ahh ok, I'm not the most experienced painter haha. I do recall end up mostly using the 800 as I could hardly tell if the other two were doing anything. Would you still use the finer grit(s) when polishing the clear out afterwards? (assuming gloss clear)
My Journal
Old Wed, Jun-22-2016, 03:20:52 PM   #23
TheM
Yes, you got it - I use 1000 then 1500 and final 2000 before I break out the 3M polishing compound and buffer.
Old Wed, Jun-22-2016, 05:15:26 PM   #24
MSpeedAddict
lol stock
MSpeedAddict's Avatar
Reputation: 0 MSpeedAddict is on a distinguished road
Been considering doing this with my armrests, thanks for posting!
Jump to top MSpeedAddict is offline   Reply With Quote
Old Wed, Jun-22-2016, 06:10:59 PM   #25
04yfz
Nice work and paint looks like a great match.
Pat - Proud E46 Addict
2002 M3 Tiag/Imola Coupe-6MT (SOLD)
2005 325xi Tiag/Tanin - 5MT (SOLD)
2006 M3 Silvergrey/Black Coupe (SOLD)
2006 M3 Tiag/Black Coupe - 6MT (SOLD)
2003 330i ZHP 6MT ---> S54/M3 Conversion (build coming soon)
Old Fri, Aug-12-2016, 01:22:08 AM   #26
TheM
Finally got around to adding a pic of the finished product. Looks and feels great!
2002 M3 SteelGray/Cinnamon, TCKline, Besian, ACT clutch
A pair of Ducatis
Old Fri, Aug-12-2016, 01:37:30 AM   #27
P3trolPete
P3trolPete's Avatar
Reputation: 0 P3trolPete is on a distinguished road
looks good OP i gotta try this!
Jump to top P3trolPete is offline   Reply With Quote
Old Fri, Aug-12-2016, 02:12:01 AM   #28
ctres
ctres's Avatar
Reputation: 0 ctres is on a distinguished road
That looks fantastic! Nice job, I need to give this a try on mine.
Jump to top ctres is offline   Reply With Quote
Old Sat, Aug-13-2016, 07:11:20 PM   #29
Dave B
M3 collector
Dave B's Avatar
Italy
How did you do the area around the speaker?
Old Sat, Aug-13-2016, 07:16:55 PM   #30
TheM
I didn't paint that part - it wasn't peeling like the door handle, so it's still the stock paint. So you can see how well it matches at least!
A pair of Ducatis
Discussing Titan Shadow trim repaint in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
