Old Tue, Jun-21-2016, 03:48:06 PM   #11
legacyej25
Reputation: 0 legacyej25 is on a distinguished road
Default Re: Titan Shadow trim repaint
Is there any reason why this wouldn't work on the inner door arm rest pieces as well? Looks great OP.
2002 Carbon Black on Cinnamon
Jump to top legacyej25 is offline   Reply With Quote
Old Tue, Jun-21-2016, 06:36:13 PM   #12
TheM
Reputation: 0 TheM is on a distinguished road
Time will tell. I just painted mine. Bottom is the painted one and top is the other side obviously not done yet. Paint matches really well I think.
Jump to top TheM is offline   Reply With Quote
Old Tue, Jun-21-2016, 06:37:52 PM   #13
legacyej25
Looks great to me. Thanks for posting this DIY it's probably my next project. How long did it take to dry between coats? And also what is the purpose of wet sanding?
Old Tue, Jun-21-2016, 06:50:23 PM   #14
TheM
Just 5 minutes between coats - simple really. Wet sanding removes the old paint and puts micro scratches in the surface so the new paint can adhere properly.
Old Tue, Jun-21-2016, 06:56:41 PM   #15
Dauito21
Reputation: 0 Dauito21 is on a distinguished road
Looks good!
Jump to top Dauito21 is offline   Reply With Quote
Old Tue, Jun-21-2016, 08:54:41 PM   #16
BTB
BTB's Avatar
This is awesome. I tried doing mine in gloss black, and it looks good from some distance, but shows every imperfection up close, not to mention the orange peel. Think I'll have to do this instead.
My Journal
Old Wed, Jun-22-2016, 01:47:33 PM   #17
legacyej25
Can anyone chime in on what grit to use for wetsanding? I believe its a high grit but I'm not sure.
My shopping list is:
1. Simple green
2. Scotchbright
3. Acetone
4. Krylon matte finish
5. sandpaper (grit)
6. Duplicolor perfect match (Medium gray Metallic)
Old Wed, Jun-22-2016, 01:52:59 PM   #18
BTB
BTB's Avatar
1.Simple green
2.Scotchbright
3.Acetone
4.Krylon matte finish
5.sandpaper (grit)
6.Duplicolor perfect match (Medium gray Metallic)
I used 800, 1500, and 2000 grit sandpaper on mine, which I think is plenty smooth. Can be found at Walmart, 3m wet or dry. I also had some lower grit stuff to take off the stock finish.
My Journal
Old Wed, Jun-22-2016, 01:55:04 PM   #19
legacyej25
Thank you, this is very helpful. I'll post pictures up as I tackle this.
Old Wed, Jun-22-2016, 01:56:48 PM   #20
BTB
BTB's Avatar
No problem, and please do! I think I might have to redo mine in this finish over the weekend
My Journal
Discussing Titan Shadow trim repaint in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
