Old Fri, Aug-18-2017, 04:07:32 AM   #11
alexjames23
alexjames23's Avatar
Reputation: 0 alexjames23 is on a distinguished road
Default Re: infamous 3rd gear grind
Hate to bring back on old thread from the dead, but I have this problem exactly with my 2002 M3.
Here is my thread, as I'm curious if any further information has been gathered regarding this problem as of mid 2017: http://www.m3forum.net/m3forum/showt...p?p=1067708462
2002 M3 Cabrio / Steel Gray / Cinnamon / 6MT / VMR V703s / MR Strut Bar / Manzo Headers / MR Muffler / Autopower Rollbar / B-Spec Tune / Turner Pulleys / GC Street School / Bav SS Brake Lines / CDV delete / Alpine SPS-410s / Pioneer TS-A1306C / Sony XMN1004 / Stubby antenna / iSimple BT
Jump to top alexjames23 is offline   Reply With Quote
Old Wed, Jun-13-2018, 07:33:10 PM   #12
M3Pete
Reputation: 0 M3Pete is on a distinguished road
My 2nd and 3rd gear synchros are bad on the 6 speed 420g tranny I sourced for my E36 auto to manual swap, so i just took it out and sent it to Metric Mechanic in Missouri. Good reviews and owner has tons of experience with working on these transmissions and has figured out how to make the synchros better than new. I will let folks know how it turns out when I get it back and put everything back together, but it should be good to know that there are options out there besides just living with slow-shifting or 'fixing' by replacing with junkyard trannies--and then finding out what you got isn't much better that what you had. In my case, it would shift fine if slow-shifted below 3500-3800 rpm. Anything above that, no matter how gingerly it was shifted, it would grind. I was using the UUC recipe of Redline ATFs and also had LubroMoly added at the recommendation of UUC. I installed a Stage 2 organic clutch and LW flywheel as part of the swap, and that mix is supposed to keep the gear-rattle noise at idle down. I have done some reading since I removed and shipped the tranny, and now see some posts that say anything other than the BMW-spec fluid can cause the synchros to be too slippery and cause grinding because the synchros don't have enough friction to slow the gears down. Not sure if that is accurate or not, but I never got a chance to try switching the fluid and seeing if it made a difference...
Jump to top M3Pete is offline   Reply With Quote
Old Thu, Jun-14-2018, 04:45:22 AM   #13
alexjames23
Awesome, thanks for the info! Let us know how that synchro rebuild goes.
I'm switching to oem BMW fluid and will report back with results. I still have the grinding, but have trained myself to slow shift 2-3 and 3-4 (sometimes will grind as well). I hope I caught the problem early enough.
Old Thu, Jun-14-2018, 07:15:19 AM   #14
Just to confirm, Metric is rebuilding your 6 speed 420g tranny or your 5 speed zf tranny for the E36? On their site they list ~$4600 for the 420g...http://metricmechanic.com/ultimate-t...sion-rebuilds/
Old Thu, Jun-14-2018, 11:18:46 PM   #15
conniem3
conniem3's Avatar
Reputation: 0 conniem3 is on a distinguished road
I have the same issue as everyone here, switched from Redline to Ravenol. Didn't really help the issue at all, but all other gears are smoother \_(ツ)_/
I've heard that the tensioner spring (or something like that) could be the culprit, which is like a $5 soring, except you have to drop half the tranny or so to get it out and check. Some say that fixed the issue entirely, others not. At that point, if you don't have a transmission lined up it's a waste of labor.
I know TM sells the 420gs too with a core refund, but that's still about $4K. The most reasonable route for me will be to purchase a SMG trans and re use my 6mt bellhousing for the swap. Seems most cost effective and SMGs are usually more healthy than used 6MT even if they're low miles.
Wish there was a way to do surgery on these and replace only the synchro...
2001 BMW IR E46 M3 6MT + Buildjournal B-Spec Tune
Build Thread / Album
IG: connie.m3
Jump to top conniem3 is offline   Reply With Quote
Old Fri, Jun-15-2018, 12:57:54 AM   #16
M3Pete
I had an auto and swapped it to the 6 speed 420g since I have a 3.38 rear. I had a '97 M3 sedan with the ZF five speed and it was a smoother shifting trans, but on the highway, it always felt like it was missing a gear, so I figured I would go the 6 speed route. Maybe not the best idea in hindsight. The trans was a lot more costly to source, and now that I am having it rebuilt, my budget is WAY blown. But I will have an essentially new 420g (some say better than new, with the improvements Metric Mechanic has made to them) in my Hellrot Red '99 convertible when done. And since my car only has 56k on the clock, it should be the last thing I will have to worry about going forward. While they have it apart they are putting the a Euro E36 M3 input shaft in it which will make it the same size as the E36 (vs the larger E46 M3 input shaft it had while it lived in a US M3). We will see how it all turns out....
BTW, one thing I will say is removing the tranny, clutch, etc. the second time is a lot easier and quicker than the first go-round. Not that I want to do this a third time, but just sayin'!
Old Fri, Jun-15-2018, 03:54:20 AM   #17
Nice. Given Metric's price, have you looked into Turner's offering at all?
Yeah, you def get faster at doing them, lol.
Old Fri, Jun-15-2018, 04:14:07 AM   #18
forzanerazzurri
forzanerazzurri's Avatar
Reputation: 0 forzanerazzurri is on a distinguished road
The third gear grind is always interesting to hear about. My third gear is probably my smoothest gear. Running oem fluid. Its second that is notchy for me and even then it's only at low rpm shifts. If im flying the whole gearbox just rows like butter.
Jump to top forzanerazzurri is offline   Reply With Quote
Old Fri, Jun-15-2018, 04:46:44 AM   #19
dothraki
Reputation: 0 dothraki is on a distinguished road
Same. My 2nd grinds mostly at low RPMs and at low speeds. 3rd is fine.
Jump to top dothraki is offline   Reply With Quote
Old Fri, Jun-15-2018, 06:25:45 AM   #20
HassanEido
HassanEido's Avatar
Lebanon
Same here
Mods:
-Custom CF airbox
-SSV2 catless headers, Custom 2.5" dual sec1, Custom sec2 2.5" dual with e9xM X pipe, SuperSprint Race inspired custom section 3..
-Cat Cams 280 272.
-Custom dyno tune
364.1 whp 287.8 wtq
Discussing infamous 3rd gear grind in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
