Old Wed, Jun-13-2018, 10:10:42 PM   #1
BMW>Everything
Reputation: 0 BMW>Everything is on a distinguished road
Default Launching Over 4k RPM?
So I have some very sticky tires, (275/40/17) Hoosier Slicks!
My tune has launch control set at 4k RPM and I can literally dump the clutch and my car will not slip or spin at all on the STREET!
I'll be going to the drag strip with a prepped track and even more grip so I want the best possible 1/4 time.
So my question is should I just keep increasing my launch RPM until my tires start losing traction?
I make around 315WHP, and I had Stage 3 clutch installed 5k miles ago, and reinforced subframe, 4.10 diff, all new suspension and drive-line bushings replaced 15k miles ago.
The only thing that isn't replaced is my driveshaft and transmission. Both have 140k miles.
So whats the max I could do without hurting anything too badly??
Jump to top BMW>Everything is offline   Reply With Quote
Old Wed, Jun-13-2018, 10:14:35 PM   #2
Paulo M
Default Re: Launching Over 4k RPM?
I don’t have anything to add but I’m very interested in what you run, please let us know how you do. Would’ve been perfect if it was on street tires since that’s what I’ll be on when I run mine.
If you’re a good driver I can see you running mid 12’s consistently.
BREMBO BBS DIXIS
Old Wed, Jun-13-2018, 10:41:13 PM   #3
M3_Pilot
I think you’re better off slipping the clutch as opposed to just dumping the clutch and increasing your launch rpm.
2004 Jet Black/Cinnamon 6MT
Jump to top M3_Pilot is online now   Reply With Quote
Old Wed, Jun-13-2018, 11:12:46 PM   #4
BMW>Everything
Originally Posted by M3_Pilot View Post
I think youíre better off slipping the clutch as opposed to just dumping the clutch and increasing your launch rpm.
Why do you say that? If my clutch can deliver that power instantly when I dump it, isn't that faster acceleration then slipping it?
Old Wed, Jun-13-2018, 11:35:05 PM   #5
M3_Pilot
I think youíre bound to break a drivetrain component by launching the car from letís say 5000 rpm with sticky tires on a sticky dragway. Iím sure the axles would be the first thing to give with that level of impulse.
Old Thu, Jun-14-2018, 03:45:03 AM   #6
10speed
Reputation: 0 10speed is on a distinguished road
I do Pro Solo, which is basically autocross with a drag start.
I am running the stock clutch, flywheel, and diff with 295 Hoosier A7s.
I have to rev to 3000 RPM, slip the clutch and feed throttle to avoid too much wheel spin.
The best 60' times I have seen a 1.8s, but usually it's 2.0s.
Jump to top 10speed is offline   Reply With Quote
Old Thu, Jun-14-2018, 03:50:40 AM   #7
10speed
I think if your car is putting down the power without too much wheel spin then more revs will be OK.
One technique I have seen some guys do:
1.) set up the car in the staging lights
2.) engage e-brake
3.) load the drivetrain e-brake engaged
4.) rev and drop the clutch/e-brake same time
this spares the drivetrain more force due to the slack you are removing.
Old Thu, Jun-14-2018, 07:25:40 AM   #8
Normally you test how high on rpm you can go before there is wheel spin, yes, if you start getting some wheel spin, you can back off rpm or start slipping/engaging the clutch slower. However, you mention that you dont want to hurt the drivetrain, I feel like that is a bit of an oxymoron - you have a race clutch and slicks which will hook up and deliver the requested power, so some other weak link might give (maybe your driveshaft ujoint, maybe your guibo, maybe you halfshaft cv joints, etc).
Old Thu, Jun-14-2018, 07:33:57 AM   #9
erickrayos
Reputation: 0 erickrayos is on a distinguished road
axle's will be the next weakest link.. the driveshaft on these cars are pretty beefy from stock and can handle more than your 315 can deliver.
Jump to top erickrayos is online now   Reply With Quote
Old Thu, Jun-14-2018, 08:57:40 AM   #10
HassanEido
HassanEido's Avatar
Lebanon
Send it. When it breaks mend it.
Mods:
-Custom CF airbox
-SSV2 catless headers, Custom 2.5" dual sec1, Custom sec2 2.5" dual with e9xM X pipe, SuperSprint Race inspired custom section 3..
-Cat Cams 280 272.
-Custom dyno tune
364.1 whp 287.8 wtq
Discussing Launching Over 4k RPM? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
