Old Wed, Jun-13-2018, 06:16:30 PM   #1
UFoh
Reputation: 0 UFoh is on a distinguished road
Default Vibra Technics transmission brace
Hey, is there any truth to what this website says regarding the oe brace causing movement? I'm gonna change my transmission mounts as I can hear them whining a little bit but should I buy this (extremely overpriced) brace or just get some good mounts?
Link to transmission mount brace https://www.vibra-technics.com/bmw/e...ed_m3_s54_only
Jump to top UFoh is offline   Reply With Quote
Old Wed, Jun-13-2018, 07:22:59 PM   #2
Texaz3
Default Re: Vibra Technics transmission brace
Looking at it, I'm very skeptical. Good mounts should do the job just fine.
Jump to top Texaz3 is online now   Reply With Quote
Old Wed, Jun-13-2018, 07:29:30 PM   #3
UFoh
That's what I'm thinking
Old Wed, Jun-13-2018, 08:27:43 PM   #4
Stock brace moves around?
Get some RE black rubber mounts and you'll have the perfect aggressive street setup $60
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · zero options · JOURNAL
-NA S54-
·Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 63mm · SS V1 S pipe 63mm + 200 cell HFC · OE sect 2 60mm · SS Sport 60mm
·Besian · RE pullies/fan delete · WPC rod bearings · GroundControl S/A (Koni/Eibach 440/525) + tall RSMs · TMS Camber & Subframe plates · SPC Adj alloy rear camber arms
·RE Trans Mounts · AKG poly SUB/DIFF 95a · SDW RTAB · Weighted ///M knob + UUC DSSR + delrin carrier bush · OE CSL trunk · APEX 75mm Studs · ZHP 13.7:1 P/S Rack
·Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · Brembo 996 36/40 345mm CSL Textar FF & 28/30 328mm CSL ATE "D738" FF · CM brackets & ss/teflon lines
·Pioneer DEH-80PRS · Eclipse PA5422 · CDT HD-6 + WS-100i · CDT EX-530 · 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 · PPI 1600.4 · CDT HD-6 + HD-100 · CDT EX-530 · DVC 10"
Old Wed, Jun-13-2018, 11:17:46 PM   #5
Chapelle
Chapelle's Avatar
Reputation: 0 Chapelle is on a distinguished road
I believe the VT transmission mount also limits your header choices. Or maybe you just can't run SS V1's...I can't remember.
Rogue transmission mounts seem to be popular around here, so I'm installing them on mine.
Jump to top Chapelle is online now   Reply With Quote
Old Wed, Jun-13-2018, 11:35:14 PM   #6
Volke
Reputation: 0 Volke is on a distinguished road
They say that as a disclaimer but I've never heard of any fitment issues. Stash1 has the 3.5" ARH section 1 and he didn't have any issues. No reason the dual 2.5" SS shouldn't fit.
That's not what the site says.
All they claim is that the OE rubber mounts allow a lot of transmission movement, and if the mounts fail, the transmission is free to move around totally unrestrained.
Other aftermarket mounts allow less transmission movement, but they do not address what happens if the mounts fail.
The VT transmission mounts, like the VT motor mounts, even when they fail, do not allow the transmission to move around totally unrestrained.
They're basically saying that even if the rubber part of their mounts fail, the solid parts will still keep the transmission somewhat restrained.
Peter
Mechanical Engineer
Jump to top Volke is offline   Reply With Quote
Old Fri, Jun-22-2018, 04:11:25 AM   #7
mickloshh1
mickloshh1's Avatar
Reputation: 0 mickloshh1 is on a distinguished road
I changed mine to Vorshlag Red. Very firm and did notice quite a lot of noise but it makes the car sound heaps better on throttle especially up high in the revs.
Total pain in the arse at idle. Shifts are much crispier tho. Can really feel the gears connecting when changing.
2004 M3 Silver Grey 6Spd MT
Jump to top mickloshh1 is offline   Reply With Quote
Old Fri, Jun-22-2018, 11:34:14 AM   #8
The stock brace is stiffer than the VT brace. That said, I'm pretty sure neither moves meaningfully. I'm pretty sure their description is saying the mounts, not the brace, are "too soft".
My SSV1s/section 1 would not clear with the vibratech trans brace.
Old Fri, Jun-22-2018, 02:09:17 PM   #9
Turb02
Turb02's Avatar
Reputation: 0 Turb02 is on a distinguished road
Do you have a link to where this is identified? What tests were done on the car to determine this?
I ask because I installed the VT trans brace when I did my SMG conversion, and Id like to see the data that backs this statement up.
^ may sound like me being a d0uch canoe, but im honestly interested, and may go back to stock if the data backs it up.
NOT NARDO
Active Autowerke Stage 2.5-AA Headers-Supersprint-Meisterschaft-Vorsteiner-Brembo-AC Schnitzer-BBS-CSL
6MT swapped-RTD shifter-Amber Gang
Jump to top Turb02 is offline   Reply With Quote
Old Fri, Jun-22-2018, 02:16:16 PM   #10
ctres
ctres's Avatar
Reputation: 0 ctres is on a distinguished road
What makes you believe VT when they say their brace is stiffer, and what evidence do you have to suggest that an increase in stiffness would actually have any perceptible effect? I'm not sure what evidence Ian has that the stock brace is stiffer and in what plane, etc, but IMO the burden of proof in this case lies on VT since they are the ones making the claim, not BMW.
Jump to top ctres is offline   Reply With Quote
Discussing Vibra Technics transmission brace in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
