Old Wed, Sep-06-2017, 03:35:16 AM   #961
m2pc
m2pc's Avatar
Reputation: 0 m2pc is on a distinguished road
Default Re: SMG troubleshooting FAQ
Originally Posted by turbosig View Post
2004 Vert 98K and this finally happened to me. Drove today in NJ with temps in low 90's. At first Cog light came out, car drove and shifted just fine. Stopped the car for maybe 15 minutes to pick up my son and the Cog light was still on upon restarting the car, but now the SES light was on as well. Drove another 3 miles and the car fell out of 4th gear to N, was able to shift it back into gear almost immediately. Parked the car within 10 minutes from that and pulled the codes with my OBII reader. Got P1717.
Attachment 205995
Attachment 205996
I let the car cool down for a few hours. Started it again to pull it into the garage and the Cog light is off but SES still on. Pulled the codes again, same thing P1717.
I ordered a Salmon relay and will change that but wondering if any of you had experience with this and what your check list / troubleshooting solutions are after replacement of the Salmon Relay???
If it is the heat related sensor....its just very interesting as I use to drive this car on the 101 in LA during summer for years without any issues and the temps in the mid 90' degrees. Drive it in NJ where I lived for the past 7 years and this is the first time this has happened.
My car is at around 85K now and this has been getting worse with each summer! The rest of the year the car is fine, but this summer has been especially hot here and it's maddening at times!
It's worse when I'm running around town doing errands and the car sits and heat soak sets in. I'm currently exploring options and the best choice IMHO is to relocate the whole assembly to a cooler part of the engine bay, like the "front battery area" on my car near the passenger side firewall:
http://www.m3forum.net/m3forum/showt...=544689&page=1
Seems Burkhart is making an extension kit for the cabling and the hydraulic lines now:
https://burkhart-engineering.com/epa...Products/54230
https://burkhart-engineering.com/epa...Products/54379
2003 E46 M3 | 74K Miles | Silver Gray Metallic | StopTech Drilled Rotors | PBR Deluxe Pads | Optima Yellow Top Battery w/Custom Bracket
Jump to top m2pc is offline   Reply With Quote
Old Wed, Sep-06-2017, 05:14:22 PM   #962
turbosig
turbosig's Avatar
Reputation: 0 turbosig is on a distinguished road
Thank you for your thoughts. I should get the Salmon Relay on Friday and I will swap that first and check the fluid. Clear the codes and see what happens.
'04 M3 by way of Sunny SoCal to NJ/Philly
Jump to top turbosig is offline   Reply With Quote
Old Fri, Sep-08-2017, 02:14:25 AM   #963
thomn8r
thomn8r's Avatar
Reputation: 0 thomn8r is on a distinguished road
2003 M3 with 122k
This morning when I unlocked my car, I didn't hear the pump kick on. Hmm. Sure enough, it wouldn't go into gear. Took the '57 356 to work, and when I got home I swapped out the relay - I had a spare relay in the car already, along with the torx driver. Just ordered another relay off of Amazon
The only downer to the whole scenario is I couldn't find my USB/OBD-II dongle so I could fire up INPA go in and look at and clear the codes.
Jump to top thomn8r is offline   Reply With Quote
Old Mon, Sep-11-2017, 02:38:03 PM   #964
turbosig
turbosig's Avatar
Just following up for everyone here. Got the Salmon Relay, replaced that and then checked the SMG fluid. It was very very low at cold condition. I added Pentosin and then warmed the car up. Checked fluid again and it was still low so I added more. Cleared the P1717 SES light code. No Cog showing upon start up. I then did a test drive at S3, S4, S5 and S6 driving and shifting as fast as possible. So far things seem to be fine, but with Fall coming and Winter - she will be in the garage soon snoozing away. But fingers crossed no other issues.
Old Sun, Mar-04-2018, 07:39:59 PM   #965
Genes1s
Genes1s's Avatar
Reputation: 0 Genes1s is on a distinguished road
Default SMG codes on scanner but no Cog Wheel light on
I was looking at 02 SMG E46 M3 (118K Miles) yesterday and I was using Schwaben/Foxwell Scanner.The cog wheel light wasn't on nor blinking (no CEL either) during my 15-20 minutes drive and about 20 minutes sitting idles. Test drove was fine, SMG was fully functioning. I did, however, picked up a bunch of SMG codes from the scanner.
Code 17: Activation, solenoid valve, clutch (OBDII P1740)
Code 3B: Acuation, Cluch, Dynamic.
Code 61: Voltage Supply.
Code 32: Selection Angle Can't engage (OBDII P1758)
Code 38: ON period, hydraulic unit (OBDII P1717)
What's you guys thought on these?
Walk away?
Thanks
00-03 Nissan Maxima HID Retrofit
Chassis and Suspension
2000 Sunlit Sand Maxima SE 5Spd.
1997 Arctic Silver E36 M3/4/5.
1997 Techno Violet E36 M3/2/5. Sold
Jump to top Genes1s is offline   Reply With Quote
Old Wed, May-02-2018, 04:47:15 AM   #966
Brunoe462000
Reputation: 0 Brunoe462000 is on a distinguished road
I've had some issues with my 2002 m3 smg warning light recently...i just changed the salmon relay and still the light comes on... there seems to be no issues tho.. it shifts fine up and down.. the only thing i do notice sometimes is this ... if i am driving lets say 40mph in any gear and let off the gas and coast the RPMs will not gradually decrease.. the RPMs will drop to 1k almost as if the clutch disengages.. then when i go to step on the gas the RPMs will jump back up to where they should be and the clutch seems to engage.... it doesn't do this all the time.. i also have a P0011 P0014 vans code but i don't think that has anything to do with this issue.. or does it ? i don't post on here often.. i like to read mostly but i have yet to find anyone with this similar problem.. hopefully someone can chime in. thanks
Jump to top Brunoe462000 is offline   Reply With Quote
Old Tue, Aug-14-2018, 07:08:37 AM   #967
steel
Reputation: 0 steel is on a distinguished road
I have this same problem and i get a 3B trouble code frequency 41. any ideas on whats wrong
Jump to top steel is offline   Reply With Quote
Old Tue, Aug-14-2018, 03:06:32 PM   #968
zivagolee
@zivagolee
Reputation: 0 zivagolee is on a distinguished road
This was very useful in helping me diagnose my SMG issues:
https://burkhart-engineering.com/SMG-Wiki/en
2003 Orient Blue M3
https://www.instagram.com/zivagolee
Jump to top zivagolee is offline   Reply With Quote
Old Mon, Aug-27-2018, 07:37:08 PM   #969
ZZM3
ZZM3's Avatar
Reputation: 0 ZZM3 is on a distinguished road
Hello, I have a 04 M3 SMG, in between shifting gears a horn (honking) sound is heard from under the car or engine area, when it 1st started I thought somebody was tapping their horn behind be, then I realized that my car was making the noise, does anybody have any ideas?? No warning light are on and car drives great.
Jump to top ZZM3 is offline   Reply With Quote
Old Mon, Aug-27-2018, 08:08:04 PM   #970
brichter
Unregistered Abuser
brichter's Avatar
Reputation: 0 brichter is on a distinguished road
LOL I've never heard that one before in relation to an SMG, the only thing I can think of is maybe the throwout bearing is making the noise as it moves back and forth on the input shaft sleeve.
2002 AW M3
Jump to top brichter is offline   Reply With Quote
faq, smg, troubleshooting
Troubleshooting Codes AirDoc E36 M3 (1992-1999) 0 Sat, Nov-17-2007 03:49:53 AM
Troubleshooting a problem ----> HELP ! RoadShreader E36 M3 (1992-1999) 43 Sun, Dec-31-2006 07:05:57 PM
Eclipse Troubleshooting crazy32184 E36 M3 (1992-1999) 7 Thu, Jun-09-2005 07:03:15 AM
HELP PLEASE!!! Troubleshooting my ///M! M3nEwBoOtY E36 M3 (1992-1999) 6 Sun, Apr-03-2005 04:37:52 PM
Discussing SMG troubleshooting FAQ in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
