Old Mon, Apr-16-2018, 10:19:22 PM   #1
mrRed
Reputation: 0 mrRed is on a distinguished road
Default On track Temporary Limp Mode
On Saturday afternoon, after about 20 mins of lapping (80F outside, , car bogs down on power and goes into limp mode. CEL came on, but could drive the car back into the pits without issue. After half a lap, light went off and car seemed normal again. Next day car ran without issue.
Pulled the codes today and had the following.
First seems to just be secondary air pump, which I'm not all together worried about. 2nd is something related to the clutch switch, which seems to be unrelated.
3rd error is the one I'm not really sure about. It seems like the error might have been a cylinder 2 misfire?Could an overheating/dying coil pack cause that?
Date: 04/16/18 16:48:30
ECU: MSS54DS0
JobStatus: OKAY
Variant: MSS54DS0
RESULT: 3 errors in error memory !
170 Sekundaerluft Mindestdurchfluss
Error frequency : 1
Logistic counter: 37
Motordrehzahl 1440.00 1/min
relative Fuellung 24.80 %
Kuehlwassertemp. 50.00 Grad C
Versorgungsspannung HR 14.40 V
aufgetreten vor (rel. BZ) 9.00 h
Bank 2 zu klein
Fehler momentan nicht vorhanden
sporadischer Fehler
80 Schalterkette Kraftschluss
Error frequency : 5
Error occured 1. times at:
Motordrehzahl 960.00 1/min
relative Fuellung 16.00 %
Geschwindigkeit diskret 0.00 km/h
Versorgungsspannung HR 14.20 V
aufgetreten vor (rel. BZ) 5.10 h
Error occured 2. times at:
Motordrehzahl 920.00 1/min
relative Fuellung 16.80 %
aufgetreten vor (rel. BZ) 4.70 h
Error occured 3. times at:
Motordrehzahl 880.00 1/min
relative Fuellung 17.60 %
Versorgungsspannung HR 14.10 V
aufgetreten vor (rel. BZ) 3.70 h
Kraftschluss im Stillstand
sporadischer Fehler
197 Aussetzer Zyl.2 KAT-sch.
Error frequency : 1
Logistic counter: 77
Motordrehzahl 5000.00 1/min
relative Fuellung 104.00 %
Kuehlwassertemp. 97.00 Grad C
aufgetreten vor (rel. BZ) 3.80 h
ausserhalb FTP-Zyklus
sporadischer Fehler
Jump to top mrRed is offline   Reply With Quote
Old Mon, Apr-16-2018, 10:28:37 PM   #2
Kwakjoe
Kwakjoe's Avatar
Default Re: On track Temporary Limp Mode
Did you have DSC on?
Old Mon, Apr-16-2018, 10:29:23 PM   #3
mrRed
Newp.
Old Mon, Apr-16-2018, 10:32:54 PM   #4
lmtfi
lmtfi's Avatar
Originally Posted by mrRed View Post
Newp.
What does that mean in English?
Old Mon, Apr-16-2018, 10:40:14 PM   #5
mrRed
Nope. DSC was off.
Old Mon, Apr-16-2018, 10:55:07 PM   #6
Kwakjoe
Kwakjoe's Avatar
Nope. DSC was off.
Ah okay the symptoms sound very similar to what happened to me. Although I figured it was my DSC since it was turned on. I'll find out since I'll be heading to the same track this month to test it out.
Old Tue, Apr-17-2018, 12:05:35 AM   #7
bigjae1976
Probably the coil pack.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Tue, Apr-17-2018, 12:31:46 AM   #8
ThunderMoose
you mean "zee coil pack"
#67 2017 NASA TX TT3 Champion
Old Tue, Apr-17-2018, 03:36:01 AM   #9
mrRed
Found the hidden menu. Read out another message...
"Zee Spulenpaket! Das is kaput!"
Watkins Glen in like 10 days, will swap the coil pack and hopefully alles ist gut.
Old Tue, Apr-17-2018, 03:44:18 AM   #10
bigjae1976
Iíve found that when one coil pack goes, the other 5 are getting close. Youíll end up killing 2 or 3 more.
Iíd just replace all 6.
Discussing On track Temporary Limp Mode in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
