Old Sun, Apr-15-2018, 01:32:35 AM   #1
M3_#67
Reputation: 0 M3_#67 is on a distinguished road
Default Another S54 Build article
This is about a year or so old and there are plenty of build threads and experiences with the S54 but still a good read even though it's a F/I build.
http://www.enginelabs.com/engine-tec...-michael-essa/
'02 Imola Red on Black
Jump to top M3_#67 is offline   Reply With Quote
Old Sun, Apr-15-2018, 02:25:00 AM   #2
oceansize
oceansize's Avatar
Default Re: Another S54 Build article
Good read, particularly for me as it links to the original build that uses the same ESS supercharger I currently have. I've been thinking on a water/methanol setup and they discuss the AEM kit. See how this summer goes. Thanks for posting.
2003 M3 Convertible SMG w/Hardtop
KW V2 Coilovers
ESS VT1-475 Gen 3 Supercharger
Stoptech Brakes
MRR GT-1 Wheels
TTFS SMG Tune
Rogue Eng. Diablo Exhaust w/ SS Tips
Rogue Eng. Rasp Pipe
Redish Reinforcement Plates
Polyurethane Rear Subframe Bushings
Polyurethane Differential Bushings
Beisan Oil Pump Disk
Old Sun, Apr-15-2018, 01:04:47 PM   #3
Ramp1
Ramp1's Avatar
Reputation: 0 Ramp1 is on a distinguished road
What’s the benefit of aftermarket valves on the S54? Are they lighter or stronger? I have never heard of OE valves failing without being smacked by a piston.
Jump to top Ramp1 is offline   Reply With Quote
Old Sun, Apr-15-2018, 01:45:53 PM   #4
FK
Originally Posted by Ramp1 View Post
Whatís the benefit of aftermarket valves on the S54? Are they lighter or stronger? I have never heard of OE valves failing without being smacked by a piston.
Lighter and stronger.
Article is also old. Thought he blew the motor again.
Old Sun, Apr-15-2018, 02:00:40 PM   #5
kokgo20
kokgo20's Avatar
Good read
Build thread
Old Sun, Apr-15-2018, 02:54:16 PM   #6
Ramp1
Ramp1's Avatar
So unless you wanna rev to 9k lighter and stronger isnít really needed since there are hi-boost cars running stock valves that work fine reving to 8k
Old Sun, Apr-15-2018, 06:19:19 PM   #7
Brian N
wubalubadubdub
Brian N's Avatar
I think some like the Ferrea also flow better? I know SliM3 has some on his built engine.
-My Journal-
Jump to top Brian N is online now   Reply With Quote
Old Mon, Apr-16-2018, 03:29:50 PM   #8
stash1
Hey Brian, yeah, I believe that both ST and Ferrea valves flow marginally better than factory valves out of the box, and I believe that Ferrea valves come w/a 30* back cut, but some head porters perform additional mulit-angle back cuts to the valves/seats as well...whether or not flow is enhanced is best determined on a flow bench. Some swear by only 3 angle cuts while some prefer 5 to maximize airflow. Unfortunately you just never see that data floating (to support which is best) around anywhere as these guys tend to be all secret squirrel and stuff.
I do know that Ferrea in particular offers 3 different grades of valve material and the S54 valves are manufactured using the highest of the 3 grades...so it would make sense that they are in fact more fatigue resistant. But again, I only see these being necessary in all but the most extreme street/track builds or for max FI applications, where valves are subjected to the harshest environment.
'04 AW/IR...Not Stock
Discussing Another S54 Build article in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
