Old Sat, Apr-14-2018, 02:51:03 PM   #1
midnighted
Reputation: 0 midnighted is on a distinguished road
Default Longer radiator screw
I'm replacing my CSF radiator due to a leak on the side core. I got a replacement CSF radiator and I am having the same issue I did with the previous one.
When mounting the radiator and a mishimoto fan bracket, I can't mount both at the same time. The screw for the passenger side is too short and constantly pops out if I do. So I just mount the radiator and have the fan held in with the two bottom screws and a top lip that comes with it.
Does anyone know where I can source a longer screw for that side?
Sent from my Pixel 2 using Tapatalk
Jump to top midnighted is offline   Reply With Quote
Old Sat, Apr-14-2018, 03:28:55 PM   #2
robgill
I'd rather be at the track.
robgill's Avatar
Reputation: 0 robgill is on a distinguished road
Default Re: Longer radiator screw
This is the longer screw.
It's just a self tapping screw, you can probably find something close enough at Home Depot.
My '02 E46M Build Thread
Jump to top robgill is offline   Reply With Quote
Old Sat, Apr-14-2018, 04:00:11 PM   #3
midnighted
Right that's the one I'm using, it just isn't long enough to run through both the radiator and fan bracket
Old Mon, Apr-16-2018, 08:02:00 PM   #4
E30User
Reputation: 0 E30User is on a distinguished road
Is the CSF and Mishimoto bracket considerably thicker, where it's obvious a longer-than-stock screw is required? I haven't installed either of those yet, but it seems like it would be a common issue. Sorry if this sounds silly, but are you sure there's no mixup with the screws at the other mounting points(I'm pretty sure I've done this once)?
Jump to top E30User is offline   Reply With Quote
Old Tue, Apr-17-2018, 02:57:51 PM   #5
midnighted
It appears to be slightly more thicker. I can get it to screw in, but there isnt enough threads for it to catch completely, so it'll just pop out with little force if I use the original screw with both the rad and fan bracket. And it is the longer screw that is normally used for the passenger side.
Discussing Longer radiator screw in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
