Old Mon, Apr-16-2018, 08:40:22 AM   #11
maynard423
maynard423's Avatar
Reputation: 0 maynard423 is on a distinguished road
Default Re: Clutch Woes
I donít have that. After hours of research and sound clips Iíve ruled the noise at idle to be chatter produced from the fly wheel. I didnít think 2lbs would make that much of a difference but I was wrong. I think Iím ruling out the TOB as well. That leaves an imbalance issue to explain the vibration/noise when shifting. Iím going to contact the manufacture and see what they say.
05 M3 6MT Carbon Black Vert
Jump to top maynard423 is offline   Reply With Quote
Old Mon, Apr-16-2018, 08:49:21 AM   #12
mrgizmo04
mrgizmo04's Avatar
Yeah that vibration is not tob.
Clutch setup is very different from stock, going from dual mass sprung flywheel and solid disc to single mass lighter flywheel and sprung clutch disc.
Light flywheel vibration "issues" happen at higher rpm (5k+), so this might still be something else...
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Mon, Apr-16-2018, 08:55:19 AM   #13
maynard423
maynard423's Avatar
Thatís where Iím stuck. I wish someone who has a similar set up could drive it and give me a comparison. The issue happens right around 3200-3500 rpm. I previously said 2800 but I paid closer attention today. It seems to be worse after the car is warm as well.
Discussing Clutch Woes in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
