Old Fri, Apr-13-2018, 07:39:02 PM   #1
maynard423
maynard423's Avatar
Reputation: 0 maynard423 is on a distinguished road
Default Clutch Woes
Ok...OE clutch went out at 81k. The disc shattered. I bought the DKM replacement that ECS sells. This comes with a steel, lighter single mass flywheel and a sprung clutch. Fly wheel is exactly 2 lbs lighter than the OE DM. Install went great with no issues. I bought an OE pilot bearing, OE Sachs TOB (You could see where the BMW had been dremeled off), brass pivot pin and and new clutch fork/spring. A new OE slave cylinder was installed as well with brand new ATE fluid.
Initial startup was flawless. Goes smoothly into first,second and third under 2800 rpm. After 2800 when depressing the clutch and changing gears I can a feel vibration, pulse. Almost like a rotational force. Itís so hard to explain what I feel and put it into words. This happens with all gears.
At idle, with the clutch pressed nothing happens at all. If I press the throttle past 2800 the pedal vibration, pulse appears. Iím pretty much at a loss here. Any suggestions would be great.
05 M3 6MT Carbon Black Vert
Jump to top maynard423 is online now   Reply With Quote
Old Fri, Apr-13-2018, 09:21:13 PM   #2
exodus454
Reputation: 0 exodus454 is on a distinguished road
Default Re: Clutch Woes
Vibration through the clutch pedal?
05 ZCP - 6MT >> CPI Stepped Headers - Magnaflow cats & 1 Cherrybomb - Meisterschaft Titanium - CSL software - Eibach pro kit - 15mm rear spacers - BW studs - GC Hybrid FCABS - BW Spherical RTABS - TMS front bar
Manual Leveling - Factory Xenon - Nightbreakers - ZKW-R lenses
Jump to top exodus454 is offline   Reply With Quote
Old Fri, Apr-13-2018, 09:54:54 PM   #3
maynard423
maynard423's Avatar
Yes. At the very bottom of travel.
Old Fri, Apr-13-2018, 10:20:27 PM   #4
Ramp1
Ramp1's Avatar
Reputation: 0 Ramp1 is on a distinguished road
Does it happen in neutral if you press the clutch and rev the engine up to 5 or 6k? Or does it only happen in a gear or if the car is moving?
If it happens sitting still in neutral i would say it’s the clutch or FW out of balance and you just can’t feel it at low rpms.
Jump to top Ramp1 is offline   Reply With Quote
Old Fri, Apr-13-2018, 10:25:16 PM   #5
95bullet
95bullet's Avatar
Reputation: 0 95bullet is on a distinguished road
On my old m3 if I rested my foot on the clutch it would vibrate a little. Nothing ever happened to it. Clutch is probably just slightly out of balance.
Jump to top 95bullet is offline   Reply With Quote
Old Sat, Apr-14-2018, 01:03:26 AM   #6
maynard423
maynard423's Avatar
If it happens sitting still in neutral i would say itís the clutch or FW out of balance and you just canít feel it at low rpms.
It happens in neutral with the clutch pressed and RPMs above 2800. Itís happens when shifting with RPMS above 2800.
Old Sat, Apr-14-2018, 05:46:02 AM   #7
ricol33t
Reputation: 0 ricol33t is on a distinguished road
Any single mass will introduce a lot more vibration and noise. Additionally the setup can be imbalanced if it wasn't balanced properly from the factory.
Jump to top ricol33t is offline   Reply With Quote
Old Sat, Apr-14-2018, 11:15:34 AM   #8
maynard423
maynard423's Avatar
I wish I knew if this was just the product of the fly wheel
Old Sun, Apr-15-2018, 09:31:45 PM   #9
maynard423
maynard423's Avatar
Hypothetically if the TOB was bad:
A: It would be noisy with the clutch pedal down.
B: It would be noisy with the clutch pedal up.
Old Mon, Apr-16-2018, 07:33:51 AM   #10
mrgizmo04
mrgizmo04's Avatar
A.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Discussing Clutch Woes in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
