Old Mon, Apr-16-2018, 01:59:12 AM   #11
mikerob
Reputation: 0 mikerob is on a distinguished road
Default Re: DSS axle instal
And get yourself some better jack stands...the one I see in the picture is scaring me...
Mike
Cary, NC
Current Ride
- 2006 BMW M3 Cabriolet, Euro Headers and Cats, SuperSprint Sport Exhaust, 3.91 Gears, ZCP Front & Rear Brakes, TTFS Tune, Mason Eng Clutch Pedal
Past Ride
- 1991 BMW 325i (E30) Cabriolet, Stock European Exhaust (w/o Cat), Bilstein Shocks and Struts, Hella Ecode Headlights
- 2000 BMW 323i (E46) Sport Touring, 330i Front Calipers & Rotors, Bilstein Shocks and Struts, SAP Delete, Sirius Receiver, HID/Projector Headlights.
- 1994 BMW 325is (E36) S50 Engine, Schrick Cams, Custom Chip, 3.46:1 LSD Final Drive, 330i Front Calipers & Rotors, (Lots of Modifications)
- 1987 BMW 325is (E30) European ECU and Camshaft, M3 Suspension, Headers with Custom Exhaust.
Jump to top mikerob is offline   Reply With Quote
Old Mon, Apr-16-2018, 03:32:29 AM   #12
stack
The STIG
stack's Avatar
Reputation: 0 stack is on a distinguished road
Poland
LOL
I placed extra ones under the subframe.
So I gave up on the axles, simply because I broke a jaw puller and 2 axle extractor tool sets from autozone.
They are melted in there, I was going to remove the whole arm, but I am certain they will come out with the bearing. So I am dropping her of at my trusted shop, where they will do the bearings as well.
I really wanted to write up a nice DIY.......oh well.
04 E46 M3/ 95 E36 M3
Jump to top stack is offline   Reply With Quote
Old Mon, Apr-16-2018, 02:10:44 PM   #13
You can buy a tool at any auto parts stock that bolts to the wheel studs and then presses out the axle. I would put nuts on, first, the secure the rotors!
Old Mon, Apr-16-2018, 04:18:11 PM   #14
stack
The STIG
stack's Avatar
Poland
that's what I used.
The threads broke on the cheap tool.
Old Mon, Apr-16-2018, 04:29:54 PM   #15
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Isle of Man
Originally Posted by stack View Post
that's what I used.
You grease them first on the main bolt?
Andrew
Current - '05 Interlagos E46 M3 SMG Delete 6MT Coupe - 3350lbs
911 Journal/Build Thread
No fun no care
Old Mon, Apr-16-2018, 04:41:55 PM   #16
aznniche
aznniche's Avatar
I used a similar tool that didn't fit directly on the hub. I aligned the bolt to the end of the axle and used a bfh to whack away. It finally budged after about an hour.
Old Mon, Apr-16-2018, 04:58:44 PM   #17
mikerob
Also note, that in your first picture, it looks like the splined shaft is at an angle...ie more gap on the top than on the bottom. If the shaft became tilted as you applied pressure on it, it may be effectively wedged in the hole - and the harder you hit the end of the shaft, the more it wedges against the side...just a thought. Let us know how the story ends...
Mike
Cary, NC
Current Ride
Past Ride
Old Thu, Apr-19-2018, 09:05:30 PM   #18
sddynamix
sddynamix's Avatar
Reputation: 0 sddynamix is on a distinguished road
I used a 7 ton two jaw puller and an 8 lbs sledge. Tighten, smash, tighten, smash (use an impact gun to tighten). Made quick work of it.
Jump to top sddynamix is offline   Reply With Quote
Old Fri, Apr-20-2018, 01:28:19 AM   #19
WuBai
Five Spiced and Lovin' It
WuBai's Avatar
I distinctly remember this as being a two day long stint in pure, insufferable, Hell. By far the worst time Iíve ever had working on the M. Lots of good advice on this thread OP. I ended up breaking several tools from AutoZone that I rented and mixing and matching parts to make it work. The job was so bad that the relief of it being over didnít even make up for the anguish. Hang in there buddy, youíll be happy once itís done!
Old Fri, Apr-20-2018, 02:14:22 AM   #20
stack
The STIG
stack's Avatar
Poland
So I gave it to my shop which had a nice industrial size puller. They did it one two three.
So I decided to make one my self at work
I am a automotive technician for an Airline actually.
Sucks I canít bring my car in to work on,so much better than my dads driveway.
I made this bad boy from leaf spring U bolts
And some thick metal I found laying around the shop.
And I will probably never use it for axles
But it will come in handy once in a while for something
Discussing DSS axle instal in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
