Old Thu, Apr-12-2018, 07:55:58 PM   #1
stack
The STIG
stack's Avatar
Reputation: 0 stack is on a distinguished road
Poland
Default DSS axle instal
Whatís up everyone
I got some built axles from DSS to mate to my custom Turner Motorsports Differential.
But I am having a hard time removing the old axles
Does any one have any tips or tricks
I am using a hub extractor from autozone
Even the threads on that gave up
Here are the new bad boys
Any help would be great
I donít have a air compressor or else I would be air hammering the crap out of it.
04 E46 M3/ 95 E36 M3
Jump to top stack is offline   Reply With Quote
Old Thu, Apr-12-2018, 08:07:51 PM   #2
ebmw21
Reputation: 0 ebmw21 is on a distinguished road
Default Re: DSS axle instal
Cold punch and a bigger hammer
BBS LM | ST suspention | B-Line Intake | AP V1 | Rouge Sec2 | CPI Rasp Terminator | Headers | CSL SMG Coding |
CSL Bumper | Beisan Vanos Rebuild |
Insta: @jstrattn
Vancouver BC area ECUWORX coding avalable.
Jump to top ebmw21 is offline   Reply With Quote
Old Thu, Apr-12-2018, 08:51:41 PM   #3
PITT M3 RR
PA
PITT M3 RR's Avatar
Has it moved at all? You could drop the arm and move to a press
S54 E36 BUILD
Jump to top PITT M3 RR is online now   Reply With Quote
Old Thu, Apr-12-2018, 09:17:45 PM   #4
Drewster
Drewster's Avatar
Bigger hammer. Use the old nut to keep it from deforming if you need to
Old Thu, Apr-12-2018, 09:17:55 PM   #5
stack
The STIG
stack's Avatar
Poland
Thatís gonna be my last resort
I gave up for today.
Give another go with my pops tomorrow
Hopefully with some progress photos
Old Thu, Apr-12-2018, 09:58:25 PM   #6
PITT M3 RR
PA
PITT M3 RR's Avatar
I got ya, I have a solid steel rod the exact diameter of the splines I used as a buffer so I didn’t mushroom the end when I did mine. BFH and that worked...if you can get acetone and ATF in there mixed, that should help
S54 E36 BUILD
Old Thu, Apr-12-2018, 10:28:31 PM   #7
icecream
Registered Apples
icecream's Avatar
I might be confused but Can you put a 3 jaw puller on it and press it out since it is detached from the diff?
Old Fri, Apr-13-2018, 12:15:30 AM   #8
NevEragon
Reputation: 0 NevEragon is on a distinguished road
When I did my wheel bearings, I couldn't get my axles out with an air hammer even. I had to use a special press that bolts onto the hub.
Jump to top NevEragon is offline   Reply With Quote
Old Fri, Apr-13-2018, 09:04:07 PM   #9
qualicas
qualicas's Avatar
From the picture it looks like you have the axle pushed back so the end is flush to the hub. It should be very loose at this point. Just getting it to break free is the difficult part. If it is still not moving freely, check that it isn't hitting something on the back side. As someone suggested get a big 3 jaw puller and it will push it out. Hammering will just get you all sweaty and do damage.
Old Fri, Apr-13-2018, 09:19:41 PM   #10
WALKD_U
WALKD_U's Avatar
Just sell me your axles
2005 AW/IR M3
BMB Stage 4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Discussing DSS axle instal in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
