Old Fri, Apr-13-2018, 07:30:19 AM   #21
rovert604
rovert604's Avatar
Default Subframe surprise
I had that issue just like OP. But I caught those after we welded all the major stuff right at the subframe mounting points. I had extensive cracks that were large and made their way several inches.
If you have a buddy to help you stop drill and weld, then the extra time it takes to get at the cracks shouldn’t be that time consuming. We did the welding to seal up all my damage and it didn’t take much time to fix up. The most time was spent epoxy sealing everything up and waiting for it to dry/cure. You really want good coverage to protect from water and rust.
The wheel well edges were coming apart on one side of my car. The sheet metal is really thin there and you’ll want to grind away a lot of the sealant because the heat transfer is fast and starts to light the sealant on fire. LOL. We just took our time on that part to create minimal heat by zapping opposite sides until all was joined.
You can drive your car but keep throttle control smooth and ginger. Accelerate like you’re a Toyota Corolla with one spark plug not working. lol. Whatever cracks that have formed, will just start to keep getting bigger as your rear diff twists the subframe upon throttle and engine braking. You’ll need to use more welding material to seal the tears and possibly end up with more stop drills throughout. Get the fix done as soon as you can and don’t wait too long.
Because of where your sheet metal is separating, you’ll want to make sure that is very very well dried out if you continue to drive it in wet conditions. You’re asking for rust to happen if it is not 100% dry before welding the separation shut.
Good luck!
--Trevor in 604--
Vancouver, BC, Canada
Old Fri, Apr-13-2018, 02:51:44 PM   #22
Kdubski
Kdubski's Avatar
Default Re: Subframe surprise
Originally Posted by Kleedzine View Post
any reinforcement done before this crack?
No reinforcement performed. I'm getting ready to do it in a few months. The subframe mounts are clean of cracks.
Old Mon, Apr-16-2018, 03:15:52 PM   #23
Kdubski
Kdubski's Avatar
Update:
Got the car on the lift. Rear left wheel well has a separation of 6-8". Trunk on the driver side has slight creasing from the RACP movement, and there is a significant crack in the right to the right of the rear left mount.
More extensive than I thought after all was cleaned up and inspected.
Old Mon, Apr-16-2018, 03:54:54 PM   #24
Adrian S
Adrian S's Avatar
Reputation: 0 Adrian S is on a distinguished road
South Africa
Wow, doesn't sound good at all. All the best with the repair!
2003.5 BMW M3 Coupe 6MT
2004 BMW 330i M-sport 6MT
Jump to top Adrian S is offline   Reply With Quote
Old Mon, Apr-16-2018, 04:59:01 PM   #25
Radekxpl
Radekxpl's Avatar
Reputation: 0 Radekxpl is on a distinguished road
Poland
Originally Posted by Kdubski View Post
Update:
Thats not good at all, are you still planing to attend the Ax in Mass next weekend?
2006 M3 Silver Grey
Mod list: TTFS Custom Tune, Headers Sec 1 AR20, M-Track Mode programmed, IAT relocated, Upadted cam bolts with S62 pressure springs and diaphragm, sub-frame reinforced foam/epoxy Vince bar & plates, CDV delete, F10 M5 shift knob, CSL diffuser, black chrome grillies, smoked corners tinted windows, asymmetrical mirrors, Hardwired Bell Pro 300, D/A pulleys, AVANT-II, Dinan CAI, SDW RTAB, Eibach pro-kit/Koni shocks, GC Street Camber Plates, Beisan Oil Pump Disk, ECS camber arms, N15 SPAL 2049 fan, Micro-blue rod bearings, ZHP .712 Yellow tag rack.
Jump to top Radekxpl is offline   Reply With Quote
Old Mon, Apr-16-2018, 05:19:59 PM   #26
Kdubski
Kdubski's Avatar
No autox or driving until this is fixed. Will probably start the work in 2-3 weeks.
Old Tue, Apr-17-2018, 04:28:33 AM   #27
woody100
woody100's Avatar
Reputation: 0 woody100 is on a distinguished road
Just got mine back from Redish Motorsport they do a thorough inspection and this video might help you identify exactly where they suffer cracks
Nearly all cars have some form of cracks or spot welds go
Jump to top woody100 is offline   Reply With Quote
Old Tue, Apr-17-2018, 05:03:20 AM   #28
EricSMG
40 something
Identical to mine. Stripped it down and stiched the arch.
Old Tue, Apr-17-2018, 06:08:47 AM   #29
M3_Pilot
My car already has plates welded in, but this makes me want to get an x-brace to really tie up the rear.
2004 Jet Black/Cinnamon 6MT
Jump to top M3_Pilot is online now   Reply With Quote
Old Tue, Apr-17-2018, 07:11:18 AM   #30
HassanEido
HassanEido's Avatar
Lebanon
Plates only move the load to the next weak link, the wheel arches. Get a brace.
Mods:
Modified stock airbox,afe plastic intake elbow Afe prodry drop in, electric fan conversion,SSV2 catless headers, custom 2.5" dual sec1, custom sec2 2.5" dual with e9xM X pipe, SuperSprint Race inspired custom section 3,tms pulleys,Cat Cams 280 272, custom dyno tune, csl box to be installed sooooonn
357.7 whp 283.5 wtq
Custom exhaust thread and dyno:
http://m3forum.net/m3forum/showthread.php?t=569086
Cams thread and dyno:
http://m3forum.net/m3forum/showthread.php?t=554439
Custom cf airbox thread:
http://m3forum.net/m3forum/showthread.php?t=595180
Discussing Subframe surprise in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
