Old Thu, Apr-12-2018, 03:24:24 PM   #11
DanAvoN7
Reputation: 0 DanAvoN7 is on a distinguished road
Default Re: Subframe surprise
Originally Posted by bigjae1976 View Post
I can’t see anything let alone a crack?
Turn the brightness up on your iphone screen
Kdubski it's not good and you will have to wire brush the underbody to remove the seam sealer and see how extensive the cracking is. It likely extends past the visible cracks in the sealer. Also check the trunk area for cracks/separation near the rear strut towers.
04 BMW M3 6spd - Alpine White/Black
Apex ARC-8 w/ Hankook Z214, Apex ARC-8 w/ BFGoodrich R1, MCS 3-way Coilovers, GC Race Camber Plates, PFC BBK, Turner Camber Arms, Turner Sway Bars, Turner Subframe bushings, Turner Solid Diff Bushings, Turner Solid RTAB, Turner Solid Control Arm bushings, Treehouse Racing FCAB, Reinforced Subframe, OS Giken LSD, Rogue Engineering Transmission Mounts, SGT Headers, SGT Section 1, AFE Stage 2 Intake, EPIC Tune, Dinan Exhaust, Bimmerworld Airdam/Splitter/Dive Planes, Bimmerworld V2 Wing, TC Design Roll Cage, Racetech RT4119, Scroth Profi 2 Harness
NORCAL Rod Bearing/Vanos/Valve Adjustment/Inspections Member Feedback
Jump to top DanAvoN7 is offline   Reply With Quote
Old Thu, Apr-12-2018, 03:27:16 PM   #12
I still think it might be overlap of the seam sealer and dirt. I would vigorously clean it.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · no nav · no xenon · no anything · JOURNAL
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 63mm · SS V1 S pipe 63mm + 200 cell HFC · OE sect 2 60mm · SS Sport 60mm · BMW Motorsport 4.10 · Besian · RE pullies/fan delete · WPC rod bearings · TMS Camber & Subf plates · RE Trans Mounts · AKG poly SUB/DIFF 95a · SDW RTAB · ZHP knob + UUC DSSR · GroundControl S/A (Koni/Eibach 376/440) + tall RSMs · OE CSL trunk · APEX 75mm Studs · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · Brembo 996 36/40 345mm Textar · Pioneer DEH-80PRS · Eclipse PA5422 · CDT HD-6 + WS-100i · CDT EX-530 · 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 · PPI 1600.4 · CDT HD-6 + HD-100 · CDT EX-530 · Clarion 10"
Old Thu, Apr-12-2018, 04:07:38 PM   #13
Kdubski
Kdubski's Avatar
it's confirmed separating by a local specialty shop. I just want to know how to weld this correctly to hold me over until I do plates this fall.
Old Thu, Apr-12-2018, 04:33:24 PM   #14
HassanEido
HassanEido's Avatar
Lebanon
That wont work. U likely have a failure in the trunk and between the racp panel. U need to do all of this now
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
364.1 whp 287.8 wtq
Old Thu, Apr-12-2018, 04:41:24 PM   #15
Radekxpl
Radekxpl's Avatar
Reputation: 0 Radekxpl is on a distinguished road
Poland
HassanEido is correct, fixing just this part won't solve anything, all needs to be done at once because all the other components will get worse with time causing
more extensive repair which involves alot more time and $$$
2006 M3 Silver Grey
Mod list: TTFS Custom Tune, Headers Sec 1 AR20, M-Track Mode programmed, IAT relocated, Upadted cam bolts with S62 pressure springs and diaphragm, sub-frame reinforced foam/epoxy Vince bar & plates, 996 Brembo brakes PFC 08 pads, CDV delete, F10 M5 shift knob, CSL diffuser, black chrome grillies, smoked corners tinted windows, asymmetrical mirrors, Hardwired Bell Pro 300, D/A pulleys, AVANT-II, Dinan CAI, SDW RTAB, Eibach pro-kit/Koni shocks, GC Street Camber Plates, Beisan Oil Pump Disk, ECS camber arms, N15 SPAL 2082 fan, Micro-blue rod bearings, ZHP .712 Yellow tag rack.
Jump to top Radekxpl is offline   Reply With Quote
Old Thu, Apr-12-2018, 06:21:28 PM   #16
bigjae1976
Lol...easy there! Y’all must be some serious BMW nerds to catch those cracks from a pic.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Thu, Apr-12-2018, 06:31:23 PM   #17
Fhcrubarb
Fhcrubarb's Avatar
Reputation: 0 Fhcrubarb is on a distinguished road
Definitely check inside the trunk for cracks, lift the carpet and it'll be pretty obvious.
Here is my thread as a point of reference
http://www.m3forum.net/m3forum/showthread.php?t=588333
Jump to top Fhcrubarb is offline   Reply With Quote
Old Fri, Apr-13-2018, 02:19:34 AM   #18
Kdubski
Kdubski's Avatar
Would riveting the ridge make any sense? Seems like welding catches the ridge, but riveting would act like the spot welds did and old the 2 panels together.
Old Fri, Apr-13-2018, 02:44:45 AM   #19
Ace280
Reputation: 0 Ace280 is on a distinguished road
I had a crack similar to the one you have and when I did not re-enforcement I found 2 of the subframe mounting points had cracks. One I could see during the inspection and one I did not see until I dropped the subframe. I would fix it ASAP and not drive it much more. If the cracks get to big the cost to fix goes way up.
Koni Shocks, Eibach Springs, Turner Motorsports Sway Bars, Mason Engineering Rear Strut Brace, Rogue Engineering, Rogue Engineering Rear Shock Mounts, Front Strut Brace, Hotchkis Rear End Links, BMW Short Shifter and now it is time for the power mods
Jump to top Ace280 is offline   Reply With Quote
Old Fri, Apr-13-2018, 05:13:51 AM   #20
Kleedzine
Reputation: 0 Kleedzine is on a distinguished road
any reinforcement done before this crack?
2002 BMW E46 M3 (daily toy)
2014 Toyota Camry hybrid-SOLD
2002 Subaru WRX frenkenSTI - SOLD
2009 Subaru WRX - SOLD
2004 Lexus IS300 - R.I.P
2002 Honda Civic SI - TRADE
Jump to top Kleedzine is offline   Reply With Quote
Discussing Subframe surprise in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
