Old Thu, Apr-12-2018, 04:29:21 AM   #1
Kdubski
Kdubski's Avatar
Default Subframe surprise
Subframe cracks caught me by surprise this week. Had the rear passenger wheel off and caught this. Mounts are good but the RACP is not.
Can someone who has dealt with this chime in on how to weld It?
Sent from my SM-N950U using Tapatalk
Old Thu, Apr-12-2018, 04:48:45 AM   #2
Apex_3472
Reputation: 0 Apex_3472 is on a distinguished road
Default Re: Subframe surprise
Someone can correct me if I'm wrong - but I do believe that is a different panel than the carrier panel. Also its hard to see with those pictures, is it a true crack in the metal or just seam sealer peeling?
oi64.tinycom/j9rkb4.jpgpic.
Jump to top Apex_3472 is offline   Reply With Quote
Old Thu, Apr-12-2018, 05:11:39 AM   #3
Yes, this area is very tricky as there are ridges and seams that can look like cracks. You need to really clean it and closely inspect it.
That doesn't scream obvious crack to me, but it might be. I just want to confirm that it can look like a crack but not be in those areas.
/// 2004 SilberGrau M3 ∑ Coupe ∑ 6MT ∑ slicktop ∑ manual seats ∑ no nav______________________JOURNAL
-Evolve-R Alpha N ∑ Evolve CSL CF Airbox ∑ Eventuri Scoop ∑ AP Headers ∑ Euro cat sect 1 ∑ Dinan sect 3 ∑ BMW Motorsport 4.10 ∑ Besian ∑ D/A pullies/fan delete ∑ WPC rod bearings
-TMS Camber & Subf plates ∑ RE Street Trans Mounts ∑ AKG poly SUB/DIFF ∑ SDW RTAB ∑ ZHP knob + UUC DSSR ∑ GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk ∑ APEX 75mm Studs ∑ Sportline 8S 18"x8.5/9.5" ∑ MPSS 245/275 ∑ ss brake/clutch lines
-Pioneer DEH-80PRS ∑ Eclipse PA5422 ∑ CDT HD-6 + WS-100i ∑ CDT EX-530 ∑ 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 ∑ PPI 1600.4 ∑ CDT HD-6 + HD-100 ∑ CDT EX-530 ∑ Clarion 10"
Old Thu, Apr-12-2018, 06:06:54 AM   #4
Adrian S
Adrian S's Avatar
Reputation: 0 Adrian S is on a distinguished road
South Africa
It's actually quite common - in most of the Redish videos they find a crack in the seam sealer on the left-rear wheel arch. They stitch weld it in addition to all the other reinforcement work.
2003.5 BMW M3 Coupe 6MT
2004 BMW 330i M-sport 6MT
Jump to top Adrian S is online now   Reply With Quote
Old Thu, Apr-12-2018, 07:37:13 AM   #5
schoonerm3
Reputation: 0 schoonerm3 is on a distinguished road
Ireland
That is 100% separation between the inner arch panel and the RACP. This is exactly what the likes of the Vince brace is designed to alleviate.
You will also have 4-5 or more areas in need of attention trust me. I have seen my fair share
Jump to top schoonerm3 is offline   Reply With Quote
Old Thu, Apr-12-2018, 09:12:26 AM   #6
HassanEido
HassanEido's Avatar
Lebanon
Had this happen to me. Seam weld it, X brace it, or vince bar it,then forget about it
Mods:
Modified stock airbox,afe plastic intake elbow Afe prodry drop in, electric fan conversion,SSV2 catless headers, custom 2.5" dual sec1, custom sec2 2.5" dual with e9xM X pipe, SuperSprint Race inspired custom section 3,tms pulleys,Cat Cams 280 272, custom dyno tune, csl box to be installed sooooonn
357.7 whp 283.5 wtq
Custom exhaust thread and dyno:
http://m3forum.net/m3forum/showthread.php?t=569086
Cams thread and dyno:
http://m3forum.net/m3forum/showthread.php?t=554439
Custom cf airbox thread:
http://m3forum.net/m3forum/showthread.php?t=595180
Old Thu, Apr-12-2018, 12:15:46 PM   #7
Kdubski
Kdubski's Avatar
It caught me off guard as I check my mounting points often. I took it for alignment and they said my frame is shifting from this small separation.
They also said weld a plate in for this separation. What other areas should I check for?
Old Thu, Apr-12-2018, 12:39:33 PM   #8
Kdubski
Kdubski's Avatar
They also said weld a plate in for this separation. What other areas should I check?
Old Thu, Apr-12-2018, 01:02:25 PM   #9
Drewster
Drewster's Avatar
Subrame mounts (clean them first..), and trunk floor.
Old Thu, Apr-12-2018, 02:19:55 PM   #10
bigjae1976
I canít see anything let alone a crack?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Discussing Subframe surprise in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
