Old Wed, Apr-11-2018, 09:07:33 PM   #1
GermanCars7
Reputation: 0 GermanCars7 is on a distinguished road
Default SMG to Manual coding near chicago
Hello,
I have just swapped my '03 M3 to manual and need to get it coded. I would like to know if anyone has any suggestions for someone here in the Chicago area?
Thanks!
Jump to top GermanCars7 is offline   Reply With Quote
Old Wed, Apr-11-2018, 09:12:50 PM   #2
aa240sx
aa240sx's Avatar
Reputation: 0 aa240sx is on a distinguished road
Default Re: SMG to Manual coding near chicago
didn't see any posts here about your process to convert so I assume you had a shop do it? if you did diy or have a shop do it, did you find the power to be down?
what was your swap conversion experience like?
- 2003 M3 Coupe - Alpine White - 6 speed - RTD Short Shifter, Enkei RPF1's on Hankook V12 staggered, Macht Schnell Intake, Eisenmann Exhaust, Koni's on Vogtland springs, Status Gruppe front lip.
- 2008 Mercedes Benz R350 - stock
- 2002 330i - Gray Metallic - 5 speed sport package - stock
Jump to top aa240sx is offline   Reply With Quote
Old Wed, Apr-11-2018, 10:13:24 PM   #3
Volke
Reputation: 0 Volke is on a distinguished road
Talk to Alex at Performance Eurowerks in Buffalo Grove. It's easiest to get a hold of him by just dropping by the shop.
Peter
Mechanical Engineer
Jump to top Volke is offline   Reply With Quote
Old Thu, Apr-12-2018, 03:14:43 AM   #4
alpineskiman
Reputation: 0 alpineskiman is on a distinguished road
You could also try Brian at EP3 in St Charles. Super responsive via Facebook messenger.
//2002 PY // Ohlins // Titan7 // Cobra // Ground Control // RTD // Bunch of Other Stuff // Track Stance //
IG: @snorkel_machine
Jump to top alpineskiman is offline   Reply With Quote
Old Thu, Apr-12-2018, 03:29:33 AM   #5
ultimatemj
Ive had good experiences (and response) from https://zimamotorsports.com
They were doing a transmission swap on another e46m3 when they were doing my e46m3 subframe reinforcement~
2004 JB/Blk SMG | 2nd owner | Purchased in 2008 w/24k miles
Key maintenance done: Subframe reinforced | WPC Rod bearings | Beisan Vanos lockdown + chainguide
Refesh maintenance done: Suspension & Driveline rubber replaced | CSB | viton CPV | Coils + plugs+ O2s | Waterpump + Thermostat | Belts & pulleys
OE+ additions: Evolve CSL airbox | Supersprint Exhaust | PE tune | OE CSL trunk | 18 VMR 710 w/PSS | EU2pc Brakes | Koni+Dinan springs| Valentine1 w/StealthOne | Stereo build log
Jump to top ultimatemj is online now   Reply With Quote
Old Thu, Apr-12-2018, 03:58:51 AM   #6
yiadrifter
Reputation: 0 yiadrifter is on a distinguished road
I just recently completed my conversion. If you have access to NCS Expert and WinKFP, takes less then 10 minutes to do the coding.
Jump to top yiadrifter is offline   Reply With Quote
Old Thu, Apr-12-2018, 04:02:37 PM   #7
JohnVu
Reputation: 0 JohnVu is on a distinguished road
Buy this tool from Martyn which is only about $20. It has a clean GUI and allows you to change a lot of general parameters without having to get into the nitty gritty of NCS Expert and WinkFP. All you have to do is select "Manual Transmission" from a drop down menu then flash it over. It shouldn't take you more than 15 minutes to read, modify, and flash everything. Also, Martyn has really great customer service as he has always replied within a few hours to any of my questions. Here is his thread: http://www.m3forum.net/m3forum/showthread.php?t=508807 . Good luck!
Jump to top JohnVu is offline   Reply With Quote
Old Thu, Apr-12-2018, 07:33:00 PM   #8
ATB88
Reputation: 0 ATB88 is on a distinguished road
^ wow that looks like a game changer -- was getting worried about figuring out the whole coding section of my planned 6MT swap, seemed like a pretty big headache!
Jump to top ATB88 is offline   Reply With Quote
Old Thu, Apr-12-2018, 08:19:18 PM   #9
nickpiper12
nickpiper12's Avatar
Reputation: 0 nickpiper12 is on a distinguished road
Performance Eurowerks in Buffalo Grove will take care of you! Just stop by.
2003.5 E46 M3 SMG | Alpine White/Black
2000 E46 "M3T" 6MT | Steel Grey/Tanin Red
2011 E91 Touring Sport 6AT | Alpine White/Chestnut Brown
Jump to top nickpiper12 is offline   Reply With Quote
Old Mon, Apr-16-2018, 03:48:47 AM   #10
GermanCars7
Thank you so much for all the responses! I have already been in contact with Alex, but he has not gotten back to me; it is great to know that the best way to get to him is by dropping by! I had already used the ECUWorks tool, but it did not fix the manual swap coding. Also, I did the swap by myself.
Discussing SMG to Manual coding near chicago in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
