Old Mon, Apr-09-2018, 12:18:03 AM   #11
maruscmn
maruscmn's Avatar
Reputation: 0 maruscmn is on a distinguished road
Default Re: 996 Brembo Rebuild Kit - Dust Boots / Seals
Originally Posted by Radekxpl View Post
I'm in process of rebuilding my 996 Brembos as well did some research, I have found these kits made by stoptech made for track duty high-temp dust boots and seals. here is front kit
Front 40/36 mm
https://rover.ebay.com/rover/1/711-5...7&toolid=20008
Rear 30/28mm
These kits come with everything needed for front and rear axles, no need to buy separate for each wheel, at this price point I don't think there is a better deal out there.
Jump to top maruscmn is offline   Reply With Quote
Old Mon, Apr-09-2018, 03:05:13 AM   #12
Dougsic
Reputation: 0 Dougsic is on a distinguished road
My experience with Stoptech dust seals on Brembo calipers hasn't been good.
I know they "should" fit. Spent better part of day trying to fit the dust seals on Brembo F50 calipers. Cleaned the dust seal grooves with Brake-Kleen using Q-Tips and toothpicks. Cleaned the brand new Stoptech seals squeaky clean.
Dust seals wouldn't stay seated. Properly sized and purchased from Dave Z. Piston seals worked fine.
Gave up on Stoptech dust seals. Ordered Brembo seals. New Brembo seals slid right in place and stayed seated with no drama. Can't explain why but I was warned by others and they were right.
Just my .02 worth.
Jump to top Dougsic is offline   Reply With Quote
Old Mon, Apr-09-2018, 06:12:32 PM   #13
umichchris
Reputation: 0 umichchris is on a distinguished road
more specifically im looking for the part number for the 40mm front caliper piston (the larger of the two).
i have searched high & low but i cannot find a good source for the accurate part numbers for them.
i see a full set of stainless steel pistons for like $160 bucks via one site, but i only need one and the rest would be a waste of $$$
Jump to top umichchris is online now   Reply With Quote
Old Sun, Apr-15-2018, 01:38:24 AM   #14
umichchris
Bump for those who may know..
Old Sun, Apr-15-2018, 04:09:17 PM   #15
robgill
I'd rather be at the track.
robgill's Avatar
Reputation: 0 robgill is on a distinguished road
I ordered mine from FCP Euro:
Front Kit
Rear Kit
My '02 E46M Build Thread
Jump to top robgill is offline   Reply With Quote
Old Mon, Apr-16-2018, 01:23:40 AM   #16
umichchris
Thanks for the reply but I'm not looking for the seal. Everyone keeps replying with the seals...I need the 40mm PISTON.
Again, I'm looking for the piston itself...NOT the replacement rubber seals. Thanks guys!
Old Mon, Apr-16-2018, 03:22:06 AM   #17
Ace280
Reputation: 0 Ace280 is on a distinguished road
Please take a look at my post, I was talking about replacement pistons.
SGT Coilovers, Turner Motorsports Sway Bars, Mason Engineering Rear Strut Brace, Front Strut Brace, Hotchkis Rear End Links, RE Short Shifter, The Orginal Vince Bar
Power Mods - RE Pullies, Fan delete, TTFS Tune, Euro Header, Euro Cats, B-Line Intake, Borla Muffler, AFD E85 kit, 3.91 diff
Jump to top Ace280 is online now   Reply With Quote
Old Mon, Apr-16-2018, 06:51:59 AM   #18
mrgizmo04
mrgizmo04's Avatar
Everyone is replying with dust boots/seals because this is the name of the thread and what OP was looking for, however, replies 8,9,10 can be used for pistons, in fact reply 9 gives you the part number of the PISTON...
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Thu, Apr-19-2018, 11:27:04 PM   #19
umichchris
Mea Culpa, i missed that.
i used that info to order the piston, it should arrive today. thanks all!
Discussing 996 Brembo Rebuild Kit - Dust Boots / Seals in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
