Old Tue, Apr-03-2018, 09:43:19 PM   #1
ski3doo
ski3doo's Avatar
Reputation: 0 ski3doo is on a distinguished road
Default 996 Brembo Rebuild Kit - Dust Boots / Seals
Need to rebuild calipers and looking for Brembo Dust Boots/Seals 36/40 in front 28/30 in rear. I understand its hard to come across Brembo's rebuild kits
Any recommendations apprecaited!
Thanks,
Saad
Jump to top ski3doo is offline   Reply With Quote
Old Tue, Apr-03-2018, 09:50:51 PM   #2
C///M
Default Re: 996 Brembo Rebuild Kit - Dust Boots / Seals
Thanks,
Saad
P0lar used to sell the high temp stoptech seals for a great price. Not sure if he still does, but I'd send him a message.
Jump to top C///M is offline   Reply With Quote
Old Wed, Apr-04-2018, 02:17:21 AM   #3
Radekxpl
Radekxpl's Avatar
Reputation: 0 Radekxpl is on a distinguished road
Poland
I'm in process of rebuilding my 996 Brembos as well did some research, I have found these kits made by stoptech made for track duty high-temp dust boots and seals. here is front kit
Front 40/36 mm
https://rover.ebay.com/rover/1/711-5...7&toolid=20008
Rear 30/28mm
These kits come with everything needed for front and rear axles, no need to buy separate for each wheel, at this price point I don't think there is a better deal out there.
2006 M3 Silver Grey
Mod list: TTFS Custom Tune, Headers Sec 1 AR20, M-Track Mode programmed, IAT relocated, Upadted cam bolts with S62 pressure springs and diaphragm, sub-frame reinforced foam/epoxy Vince bar & plates, CDV delete, F10 M5 shift knob, CSL diffuser, black chrome grillies, smoked corners tinted windows, asymmetrical mirrors, Hardwired Bell Pro 300, D/A pulleys, AVANT-II, Dinan CAI, SDW RTAB, Eibach pro-kit/Koni shocks, GC Street Camber Plates, Beisan Oil Pump Disk, ECS camber arms, N15 SPAL 2049 fan, Micro-blue rod bearings, ZHP .712 Yellow tag rack.
Jump to top Radekxpl is offline   Reply With Quote
Old Wed, Apr-04-2018, 02:45:22 AM   #4
SamGrant951
SamGrant951's Avatar
Reputation: 0 SamGrant951 is on a distinguished road
Racing brake:
http://www.racingbrake.com/category-s/7498.htm
86 951 - VEMS
95 M3 LTW - S54 http://www.bmwmregistry.com/detail.php?id=15735
17 GTI
Sold: 97 M3/4/6 Byzanz, 99 M Coupe, 02 M Coupe
Jump to top SamGrant951 is offline   Reply With Quote
Old Wed, Apr-04-2018, 04:31:18 AM   #5
Argentic
Argentic's Avatar
Reputation: 0 Argentic is on a distinguished road
Bulgaria
I have them in stock
Jump to top Argentic is online now   Reply With Quote
Old Sun, Apr-08-2018, 08:09:50 AM   #6
umichchris
Reputation: 0 umichchris is on a distinguished road
Trying to find a part number for the 40mm caliper piston for the front brake...anyone know?
Can’t find a us based source to buy a single replacement..
Jump to top umichchris is offline   Reply With Quote
Old Sun, Apr-08-2018, 08:10:56 AM   #7
umichchris
Canít find a us based source to buy a single replacement..
Old Sun, Apr-08-2018, 02:00:05 PM   #8
Ace280
Reputation: 0 Ace280 is on a distinguished road
I am having a hard time finding the part number I bought but he is the website I bought them from. You can find it with searching for the car the brakes came off of.
https://www.carpartsdiscount.com/
Koni Shocks, Eibach Springs, Turner Motorsports Sway Bars, Mason Engineering Rear Strut Brace, Rogue Engineering, Rogue Engineering Rear Shock Mounts, Front Strut Brace, Hotchkis Rear End Links, BMW Short Shifter and now it is time for the power mods
Jump to top Ace280 is offline   Reply With Quote
Old Sun, Apr-08-2018, 02:09:01 PM   #9
Ace280
I found the part number for the one I bought 146.40029. I replaced all the pistons since the centric and the stock ones look different.
Old Sun, Apr-08-2018, 07:47:40 PM   #10
mrgizmo04
mrgizmo04's Avatar
Another good source: https://www.zeckhausen.com/catalog/index.php?cPath=82
That page is for bbk, but if need for specific car on which Brembos came from the factory, can search by that too (per the note on top of that page).
'85 528e 164k miles (sold)
'05 M3 6MT coupe
All DIY: 330 ZHP steering rack, diffsonline 4.1 diff with rem polish, E60 short shifter lever, AKG black diff bushings/subframe bushings, Rogue rtab, Rogue RSM with reinforcement, WPC rod bearings, Beyer driveshaft, full SS (SS stepped V1, catted S1, resonated S2, SS sport), Sachs clutch/flywheel, rear main, VANOS bullet proofing with anti-rattle, valve adjustment, cooling refresh.
Discussing 996 Brembo Rebuild Kit - Dust Boots / Seals in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
