Old Fri, Mar-23-2018, 04:56:45 PM   #1
ClutchKickChris
Reputation: 0 ClutchKickChris is on a distinguished road
Question S54 Clutch Switch Confusion
Hey guys so long story short I have a S54 swapped E36 M3 with MSS54HP, CSL tune and 6spd 420G and it's awesome. Only issue is sometimes when starting from a stop and transitioning the clutch the car wants to stall. The RPM's will drop to 5-600RPM and I'll have to "catch it" in time or it will actually stall.
Talking with my tuner he has told me I need to add the OEM clutch switch to my car since it changes the IACV duty cycle. Doing some research it looks like there were 2 styles of this, one with simple on/off switches and later years using an actual hall effect sensor built into the clutch slave cylinder.
Since my donor vehicle was an 06 vert I am trying to figure out the correct switch and wiring, and if it will actually make a difference to the clutching performance.
The older Z3M S54 EWD I have (attached) shows this is a 3 wire switch, +12V, Gnd, and output. Is this the correct one? If anyone has the 05/06 EWD please post it.
Any info is appreciated. Engine bay pic for attention
Jump to top ClutchKickChris is offline   Reply With Quote
Old Fri, Mar-23-2018, 06:40:44 PM   #2
Pnick
Pnick's Avatar
Default Re: S54 "clutch switch" confusion
There is a slight difference. Yours fall under "DME Motor Electronics MSS54 as of 2001_03.
Old Fri, Mar-23-2018, 08:40:31 PM   #3
ClutchKickChris
Got it thanks.
So does the clutch switch apply 12V or Gnd to pin 20 X60002?
Also is it open or closed circuit when the clutch is depressed (pushed down)?
Old Sat, Mar-24-2018, 01:03:19 PM   #4
Pnick
Pnick's Avatar
I'm not really sure whether it is "voltage applied" or might could be a feedback/signal to the DME since it is a "Hall Effect" switch. Voltage is applied across the 5A fuse and ground X217
Old Sat, Mar-24-2018, 01:37:54 PM   #5
PenguinScotty
PenguinScotty's Avatar
Reputation: 0 PenguinScotty is on a distinguished road
Austria
Glad i found this thread. Started noticing the same issue with my 2002, sometimes the RPM dropping and even stalling if i don't catch it.
Time for a new switch.
Love these forums!
'98 E36 M3 Evo - Techno Violet, '02 E46 M3 - Titansilber
Jump to top PenguinScotty is online now   Reply With Quote
Old Sat, Mar-24-2018, 02:21:41 PM   #6
The year doesn't matter - all the DMEs see more or less the same signal regardless of what style switch you use. On an E36, it's probably easier to retrofit the Z3M style setup and wire it as per the Z3M. For coding, put it in "E36" mode, by setting 0x6 and 0x8006 to 08 (default should be 20). That will configure the DME to work a bit better in E36 generation cars. Together, that should stabilize your idle RPMs.
If I remember correctly, the top switch is the one that's wired to the DME. And the part number you want is 61318363710 despite it being labeled a "start lock" switch. The bottom switch (also same part number) is used for the clutch interlock on US cars.
Old Sun, Mar-25-2018, 02:54:07 AM   #7
ClutchKickChris
Thanks terraphantm. What exactly is the "E36 coding" doing that makes it better?
Edit:
I should also probably set this too right? Any advantage for me to hook up gear position switch in series?
Set K_SKRAFTS_CONTROL (0x4028 in MSS54, and 0x802A in MSS54HP) to "2" (tells DME clutch switch is wired directly to the DME instead of in series with the "gear position" sensor in the transmission)
Old Sun, Mar-25-2018, 03:17:57 AM   #8
Yeah you should do that too.
E36 mode sets it so the DME works a bit better with E36 generation electronics. DME doesn't look for a coolant output temperature. It doesn't look for a torque value from the AC compressor, instead it calculates it on its own. It won't throw an error for the gear recognition sensor not being there (in combination with the K_SKRAFTS_CONTROL change). There's probably a few other minor differences too
Old Sun, Mar-25-2018, 05:21:54 AM   #9
STAATS
STAATS's Avatar
Somewhat off topic and more for a laugh then adding any value to this actual topic but I just wanted to point out the hilarious coincidence that your Screen Name is "ClutchKickChris" and the issue you are having is with your clutch haha... sorry it just made me chuckle... hope you get it sorted out, looks like other more useful people than I have already given you the details you need.
STAATS
Old Mon, Apr-16-2018, 03:37:33 PM   #10
Bert ///M3
Reputation: 0 Bert ///M3 is on a distinguished road
Netherlands
Stumbled upon this.
I have no clutch switch wired to my DME in a E36 at all. Can I set K_SKRAFTS_Control to something else, ie 0 if I have no clutch switch at all? (Euro cars have no start interlock switch) default is 01
And what about E36 mode? I would think 0x6 and 0x8006 is correct for MSS54HP, but for regular MSS54, do I change both 0x6 and 0x4006? (Both default to 20)
Jump to top Bert ///M3 is offline   Reply With Quote
Discussing S54 "clutch switch" confusion in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
