Old Mon, Aug-14-2017, 04:45:56 PM   #1
dunkman23
dunkman23's Avatar
Reputation: 0 dunkman23 is on a distinguished road
Default 100 Degree Day - Car overheards 3/4 mark with AC on.
ANyone experience this problem? If its over 100degrees and I have my AC running, the car overheats to the 3/4 mark. Once I turn off the AC, it slowly goes back down to the 50% mark. All other days the temperatures are good.
My guess would be the Clutch Fan going bad?
2002 BMW ///M3 6mt TiAg /Imola - APEX ARC-8/PSS - BILSTEIN PSS10
1993 BMW ///E34 Touring - OBD1 S52 - 5sp MT, 3.23 LSD - SOLD
1997 BMW ///E36 Sedan -
2012 BMW ///E70 MSport -
Jump to top dunkman23 is offline   Reply With Quote
Old Mon, Aug-14-2017, 04:46:41 PM   #2
Drewster
Drewster's Avatar
Default Re: 100 Degree Day - Car overheards 3/4 mark with AC on.
Your guess is probably correct
Old Mon, Aug-14-2017, 08:35:06 PM   #3
m3elmo
Reputation: 0 m3elmo is on a distinguished road
you also have an aux fan - so want to make sure that aux fan is working (electric on front).
what is the condition of your water pump, clutch fan, coolant.
Danny
Jump to top m3elmo is offline   Reply With Quote
Old Mon, Aug-14-2017, 08:53:18 PM   #4
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
it will hit 3/4 on 100* days running JUST the aux fan...
Topo Chico
Old Mon, Aug-14-2017, 09:30:10 PM   #5
lmtfi
lmtfi's Avatar
How old is your radiator?
Old Mon, Aug-14-2017, 10:32:17 PM   #6
icecream
Registered Apples
icecream's Avatar
3/4 Mark is not neccessarily over heating. Mine went right up to the red Mark on along steep grade in 100+ temps.
Does it happen all the time?
Also, lots of people run no fan without issue so I personally would look elsewhere for an issue first. Radiator not blocked, proper (and fresh) coolant mixture,
Old Mon, Aug-14-2017, 10:46:35 PM   #7
PITT M3 RR
PA
PITT M3 RR's Avatar
This,
I see the same behavior on REALLLY hot days, I chalk it up to an inefficient rad after all these years of use. Parts just need maintained, that's all. BMW says anywhere between the two dots its okay as well. On really cold nights, the needle drops to the first dot.
S54 E36 BUILD
Old Mon, Aug-14-2017, 11:43:32 PM   #8
MysticM
MysticM's Avatar
Reputation: 0 MysticM is on a distinguished road
Mine started doing the same thing, while driving in 100-120 degree temps. refreshed my cooling system and the needle has not exceeded the half way mark. even with AC on max.
05 Mystic Blue Metallic 6-SPD
Headers, AA Exhaust, AA Tune, Evosport Pulleys, GC Street/School, AS SSK
Jump to top MysticM is offline   Reply With Quote
Old Tue, Aug-15-2017, 03:51:58 AM   #9
RunwayM
Reputation: 0 RunwayM is on a distinguished road
What specifically did you replace during your system refresh, everything?
Jump to top RunwayM is offline   Reply With Quote
Old Tue, Aug-15-2017, 03:08:36 PM   #10
Steve M3
They have kits, or you can buy it piece by piece. Personally, I replaced the water pump, fan, fan clutch, hoses, thermostat, temp sensor and a few other odds and ends when my car hit just over 100k miles. I haven't replaced the radiator yet, but it's something else for you to consider. I live in a hot environment and my car rarely goes past the middle mark unless I'm in really heavy traffic, in which it goes just barely past that mark.
Jump to top Steve M3 is online now   Reply With Quote
Discussing 100 Degree Day - Car overheards 3/4 mark with AC on. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
