Old Wed, Aug-10-2016, 10:52:05 PM   #31
stogybear
stogybear's Avatar
Reputation: 0 stogybear is on a distinguished road
Armenia
Default Re: Best Daily Driver Suspension?
I have the Bilstein PSS9 and love it. You could maybe get a used set for under 1000?
2005 AW M3 - 6MT - Bay Area
Jump to top stogybear is offline   Reply With Quote
Old Wed, Aug-10-2016, 11:15:46 PM   #32
SleeveofWizard
SleeveofWizard's Avatar
Reputation: 0 SleeveofWizard is on a distinguished road
I know its out of your price range, but KW V1's are absolutely amazing. They can be a little "harsh" I guess from what I've been told by passengers in my car. But these came on the car when I bought it three years ago. So they have a lot of miles on them and still perform very well especially at the autocross I go to monthly. You could probably get a used set for around a grand or less. When these are done, I'm going back to what I ran on my E30. Koni Yellows, and Eibach Race Springs.
Jump to top SleeveofWizard is offline   Reply With Quote
Old Wed, Aug-10-2016, 11:45:12 PM   #33
icecream
Registered Apples
icecream's Avatar
Originally Posted by oleg232000 View Post
So I am looking to replace my stock suspension.
I am not planning to track the car. I would like it lowered a bit for the stance and look (maybe 1" to 1.5"). I am in LA, so there are plenty of potholed streets.
One of the options I was looking at is the DINAN/JRZ setup. They are not coilovers, but I was questioning whether a full coilover would be too aggressive for a car that never sees the track? Thing is with the DINAN setup, its only lowered .5". Wondering if you can even see the difference aesthetically speaking?
Money is an issue. I am not trying to go over $1000. I have found the bilstein PSS setups for around that price range. Just dont know if its worth it, and even if I could afford it, will the car be way to stiff?
Thanks for any input
I did Bilstein b4 and eibach springs. Check out my lost here.
http://www.m3forum.net/m3forum/showt...post1067462589
Drop is perfect for daily dury and it handles/rides well. Plus it's under $400 for four shocks, not bad.
Old Thu, Aug-11-2016, 01:19:54 AM   #34
Malloy
Reputation: 0 Malloy is on a distinguished road
This 100%.
Originally Posted by AK_Topwise View Post
At that price point I really think Koni yellows and Eiback Pro-Kit is impossible to beat.
My car started out with OEM suspension went to ST Coilovers and now Koni/Eibach. The Koni yellows are much better than the OE dampers and the Eibach pro-kit is a subtle drop (perfect height out front 13.5" howver the rear could go lower as it only sits at 13.75" on my car which gives it a rake reverse of stock).
I found the ST coilovers looked great as I could dial in the exact ride height I wanted BUT they were super crashy over any bump in the road, this was no good where I live as the roads are brutal and I was in need of a more comfortable/compliant setup that could soak up the daily bumps.
I have the Konis set at 1/4 turn firm up front and 3/4 turn firm in the rear, however they rode just perfect at the softest setting.
If I could do it again I may have gone with the H&R springs as they go lower in the rear and around the same out front. A lot of feedback on the forum hear said that they were too low for the Koni damper travel and they would end up bottoming out quite often, after a year on my current setup I may have hit the bumpstops once or twice, so I doubt going another 3/8" lower in the rear would have made any difference.
Hope this helps you out a bit. In my personal opinion and based on my experience with my car over the past 6 years there is no budget coilover (around $1000) that is going to make the car better, it will look great but ride quality will suffer big time! You need to spend big money on coilovers to get the benefit they provide so if you are not constantly changing your ride height what is the point?
Jump to top Malloy is online now   Reply With Quote
Old Thu, Aug-11-2016, 02:38:22 AM   #35
M3 dude
yep konis and eibachs.
otherwise you can get a coilover like MCA which use digressive valving. they're 2k AUD but better equation for USD.
they can be valved for comfort. my 'race' valving with 8kg front 11kg rear springs is smoother than any pss10 or kw v3.
the 'comfort' valving is meant to be better than oem
Jump to top M3 dude is online now   Reply With Quote
Old Thu, Aug-11-2016, 03:22:21 PM   #36
anth
Reputation: 0 anth is on a distinguished road
Guys, is Fortune Auto all that bad?
I totally hear you on the fact that all these reviews are subjective - which is the only caveat to the reviews I've read on them, which seem to be literally all good.
To me its between these and the tried/true Koni/Eibach setup. 90% nice weather DD, 10% HPDE at Mosport here in Toronto.
Just don't want the rear sitting lower than the front..
Jump to top anth is offline   Reply With Quote
Old Thu, Aug-11-2016, 03:42:43 PM   #37
HassanEido
HassanEido's Avatar
Lebanon
I wonder why no one suggested the GC kit! Its basically konis with coilover sleeves and eibach springs with control arm reinforcemet for about a grand .http://www.ground-control-store.com/...ion.php/II=541 . Percect if you ask me. Forget Chinese and Tai stuff if you want an actual improvement over stock
Old Thu, Aug-11-2016, 04:21:34 PM   #38
Cha5en
Reputation: 0 Cha5en is on a distinguished road
Default Best Daily Driver Suspension?
because they're hardware gets awfully noisy and their kits aren't valved for anything remotely close to comfort. Not to mention the owner is an asshat
Jump to top Cha5en is offline   Reply With Quote
Old Thu, Aug-11-2016, 04:23:11 PM   #39
AK_Topwise
Reputation: 0 AK_Topwise is on a distinguished road
The problem with koni/eibach pro-kit is not the rear sitting lower than the front it is actually the opposite. The rear will sit higher than the front by about 0.25". The stock setup has the rear sitting lower than the front by approx 0.25".
TiAg 2005 E46 ///M3 18" VMR VB3 / Macht Schnell Stage 1 Intake Kit / Status Gruppe Tuning Headers, Section 1 & Titanium Tip Muffler / Evolve-R Tune / Koni yellows / Eibach Pro-Kit / Rogue Engineering RTAB's + RSM's / AutoSolutions 30% SSK / ICONZ CSL Style CF Front Lip (painted matte black) / ICONZ CSL Style CF Rear Diffuser / Matte black grills & gills / Matte black roundels & emblems / Tinted taillights / Smoked corners & reflectors / Tinted windows
Jump to top AK_Topwise is offline   Reply With Quote
Old Thu, Aug-11-2016, 04:29:13 PM   #40
Accurate
Discussing Best Daily Driver Suspension? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
